    SU Styles + Render
    28 Posts 15 Posters 4.7k Views 15 Watching
    • soloS
      Interestingly thats the only one with warm color balance, so the blue grey tint of the concrete is less favoured....thanks y'all.
      • GaieusG
        Yes, solo, probably that's why I picked that one. But see, Edson likes the colder version better.
          spadestick
          i love the first 2 of the second post
          • tinanneT
            tinanne
            I like the second of the first post. Nice to see NPR mixed with Podium. Care to share your process?
            Executive Director : American Society of Architectural Illustrators
            AIP 30 Competition opens soon. ASAI.org
            Architectural Rendering
              mateo soletic
              Great images Solo,I love the second three,
              it is difficult to decide, i really love the
              vegetation.
              Concept Illustrations
              • L
                lewiswadsworth
                I do something like this fairly regularly, but with VRay and not Podium.
                col sporcar si trova
                • soloS
                  Lewis
                  I really like that image, it has a great ambiance to it.
                  • L
                    lewiswadsworth
                    @solo said:
                    Lewis
                    Thanks...supposedly it's on (or going to be on) the cover of a book...the idea was to mimic a certain architect's old airbrush style. But I find this sort of NPR/PR combo thing to be really hit or miss...sometimes it works, sometimes it turns into mud, and this is not helped by the quirkiness of the VRay interface. More than half the time, for instance, the rendered view from VRay is slightly different from that out of SU itself, even if I force VRay to use the same resolution and to base its camera on the SU viewport.
                    Out of frustration I've become interested in using other programs (Blender's node renderer and Rhino's Penguin 2.0) that permit one to assign rendering style (in other words, degree of NPR versus the other thing) on an object by object basis. If I survive my client meeting this morning, I want to finally do some tests of these with some basic models at least partially made in SketchUp.
                      DzineTech
                      Lewis,
                      I share your annoyance at the viewport & rendered output mismatch. The only workaround is using a zoom at about 0.7-0.8ish and also low lens shift values if there is a requirement for proper 2 point perspective seeing as that function also isnt replicated correctly in VfSU 😠
                      I do like the style's of both Solo's and your image.
                      • L
                        lewiswadsworth
                        @dzinetech said:
                        Lewis,
                        I'm almost certain I have tried those settings and everything else by this point...I generally resign myself to converting either the SU ouput or the VRay rendering to a Smart Object in Photoshop and then painfully tweaking it with the Warp transform tool until the one overlays the other acceptably.
                        • DanielD
                          Daniel
                          They all look great, Solo. If I had to pick a fav, though, probably the last one - it's not too dark, too bright, and all the detail is there.
                          My avatar is an anachronism.
                            DzineTech
                            @lewiswadsworth said:
                            @dzinetech said:
                            Lewis,
                            It definately works but there is no set of magic numbers for every desired camera/viewport position; its much a case of trial and error till it you are happy with the results. What I did was to test a low quality render with material override on (found in global switches) so that you get a quick result as to how your geometry will be represented in the VFB. As I say the ideal zoom values are around 0.7 to 0.8 and lens shift I think was about 0.1-0.15
                              DAHON
                              Hey Solo,
                              Those look great. The mix of render with linework is very appealing. For the newbies among us, I assume this is blended in Photoshop, and is not raw from Podium ?
                              • StinkieS
                                Stinkie
                                I somehow missed Lewis' post. Looks very appealing.
                                • L
                                  lewiswadsworth
                                  Thank you, but it was very problematic due to both technical and client issues, and I am now thinking that I will not be using VRay again for this sort of thing (and yes, yes, I have tried all those settings, DZine) the next time someone asks.
                                  Anyway, I can do nearly as well with Photoshop and no rendering plugin at all.
                                  Error 404 (Not Found)!!1
                                  (picasaweb.google.com)
                                  Just various Styles output and layered creatively in PS. There is a thread, with some dead links, that refers to the article in which those images were published here:
                                  404 Not Found
                                  (www.sketchucation.com)
                                  • StinkieS
                                    Stinkie
                                    Thanks for the links. I'm not the world's biggest fan of npr rendering, but I find these well-executed. Yes, Pete, so are yours. πŸ˜„
                                    • soloS
                                      DAHON
                                      You are correct, make sure to use 'viewport' size when rendering that way when you export the style you can export as viewport size to and avoid any lining up issues in PS.
                                        DAHON
                                        Thanks for that. . . I'll go off now and try a bit.
                                        • C
                                          CADken
                                          2nd picture in the 2nd post, like everyone else said. Looking good man! great work.
                                          "it seems like everything I do is a work in progress..."
