    Fry- Indigo- Vray- Kerkythea- Maxwell- Podium (added page2)
    57 Posts 32 Posters 41.7k Views 32 Watching
    • FrederikF
      Frederik
      I'm not altogether sure I like what you're implying.
      Sorry - but I don't know what or how you're interpreting what I've been writing...
      I'm not trying to imply anything here... All I'm saying is that based on the fact that the engine running under the hood of Podium v. 1.5.1 is KT, the result should be fairly identical, but this is not what I've seen in this test... πŸ˜‰
      ... mainly because Podium is not using the exact same Kerkythea engine as in KT.
      πŸ˜• πŸ˜• πŸ˜•
      TBD - you know that the core is identical, but maybe the settings are different, which's then showing in the result...
      Nevertheless, I said that it should be very close to identical..! πŸ˜‰
      Cheers
      Kim Frederik
      • StinkieS
        Stinkie
        Clearly, if I've misinterpreted what you said, then an apology is due. Consider this one.
        If.
        • FrederikF
          Frederik
          No worries, Stinkie... πŸ˜‰
          Cheers
          Kim Frederik
          • StinkieS
            Stinkie
            Allrighty then. Apologies! 😳 πŸ’š
            • N
              notareal
              I have to add that it's fairly pointless to made deep conclusions with these kind of comparisons, there always so much differences with render engines - even scenes and camera settings can be different, unintentionally. Passion towards one engine can lead different results. Anyhow, it's always interesting to see what one can do with different render engines. Usually in the end - conclusion is clear - use one that you happy with. β˜€
              • N
                notareal
                πŸ˜• πŸ˜• πŸ˜•
                I think difference do come from five different element, missing parts; handrail and 2th floor windows & interior and some missing stone decorations, different grass (or it's mapping), different tone mapping, different image size/ratio and far different render method. Podium uses Photon Mapping, if I have understood right, and with KT Kwistenbiebel used new MLT/BPT, that was not cooked long enough to clear noise. MLT/BPT is actually best suited for difficult indirect lighting conditions, that have hard to produce caustics, blurry reflections... what ever.
                Sorry for bad photoshopping, but had to add those missing handrail&window parts and change image size to reveal how great difference those do made. I remove this if needed.
                edit: oops... now I see I missed 1st floor handrail too. 😳
                • K
                  kwistenbiebel
                  As a note, this thread is not meant to be a comparison as it was stated in the first post.
                  :('This is not meant as a comparison thread between render engines. Just an exercise on using them.'
                  Looks like some of you are making it into one ... πŸ˜‰
                  • N
                    notareal
                    That was not my intention. I tried to emphasis that render engine comparisons are fairly pointless - but seems to have failed. Anyways what can be done with different render engines is interesting to see, that is what I understood you did, and did it well. But was it interesting to see that small changes in the scene and image cropping can made a huge difference.
                    • K
                      kwistenbiebel
                      I agree...
                      Some images probably could have been improved. I just used the (sometimes limited) knowledge on each render engine I currently have....
                        spadestick
                        Pardon me kwistenbiebel, but how does it work that the handrails can get left out during export to KT? are they on a different layer?
                        To me, they're all nice, all good enough to eat!
                        • N
                          nomeradona
                          kwist,
                          that last podium render... WOOWWOWW. how much more now when the V2 is release..
                          • bigstickB
                            bigstick
                            For me, the most relevant piece of information - render time is missing. Fantastic and really interesting comparison, and it shows that all these engines can produce great results. The time taken to get there, including export, setup and render time is possibly the most relevant to anyone wondering which application might be best for them. Makes you wonder how the other SU engines (irender, IDX renditioner and Podium V2 πŸ˜‰ ) will compare!
                            • GaieusG
                              @bigstick said:
                              For me, the most relevant piece of information - render time is missing...
                              http://www.sketchucation.com/forums/scf/viewtopic.php?p=42116#p42116 πŸ˜‰
                              • FrederikF
                                Frederik
                                @bigstick said:
                                Fantastic and really interesting comparison...
                                I'm starting to get slightly dizzy... πŸ˜’
                                I would still love to have this scene... πŸ˜‰
                                Would it be possible for you to share it, Chris..??
                                Cheers
                                Kim Frederik
                                • marked001M
                                  marked001
                                  damn... really really impressed with that Podium render!! i'll say it again..i really really need to start playing with this.. <runs to the podium site>
                                  http://www.revision21vis.com
                                  instagram: revi21on
                                  • bigstickB
                                    bigstick
                                    Oops! I ought to have known that he wouldn't have omitted this information. Shame on me! 😳
                                    • K
                                      KennyL
                                      You didn't include the render time for Podium.
                                      Ken
                                      Clothes make the man. Naked people have little or no influence in society.
                                      • E
                                        engin1
                                        Hi kwistenbiebel,
                                        The render with Podium is very nice. Could you tell us please what settings you used on Podium and Sketchup?
                                        Thanks a lot
                                        • FrederikF
                                          Frederik
                                          πŸ˜† In three month time, this thread is 5 years old...
                                          Looking forward to see if Chris (aka kwistenbiebel) can remember the settings after such loooong time... πŸ˜‰
                                          Cheers
                                          Kim Frederik
                                          • srxS
                                            srx
                                            πŸ˜„ Old memories...I'd like to see Thea render...
                                            www.saurus.rs
                                            • 3 / 3
