    Using add_3d_text
    15 Posts 4 Posters 2.4k Views 4 Watching
    • G
      Greg
      Hello,
      I'm using the command add_3d_text to add text to objects. How do you
      change orientation of the text so that it looks like it's on the
      surface of a plane? For example, I'd like the text to display at the
      top and front of a rectangular cube.
      Here is a code snippet:
      top plane
      pt1 = Geom::Point3d.new(x,y,z+h)
      pt2 = Geom::Point3d.new(x+w,y,z+h)
      pt3 = Geom::Point3d.new(x+w,y+l,z+h)
      pt4 = Geom::Point3d.new(x,y+l,z+h)
      edges[0] = entities.add_line(pt1, pt2)
      edges[1] = entities.add_line(pt2, pt3)
      edges[2] = entities.add_line(pt3, pt4)
      edges[3] = entities.add_line(pt4, pt1)
      face = entities.add_face edges
      face.material = m
      t=Geom::Transformation.new(pt1)
      grp=entities.add_group(); grpEnts=grp.entities
      grpEnts.add_3d_text("hey mon", 1, "Arial", false, false, 4.inch,
      1.mm, 0, false, 0)
      grp.move!(t)
      front plane
      pt1 = Geom::Point3d.new(x,y,z)
      pt2 = Geom::Point3d.new(x+w,y,z)
      pt3 = Geom::Point3d.new(x+w,y,z+h)
      pt4 = Geom::Point3d.new(x,y,z+h)
      face.material = m
      t=Geom::Transformation.new(pt4)
      1.mm, 0, false, 0)
      grp.move!(t)
      Thank you.
      Greg
      • T
        todd burch
        Mods, please move this to the Ruby Forum.
        • G
          Greg
          Done.
          • GaieusG
            Yeah, this is definitely ruby stuff.
            BTW welcome, Greg, but what do you mean by "done"?
            • G
              Greg
              Done means I moved the posting to this forum, Ruby Discussions, from the 'Newbie' forum. Actually, I copied this from the 'Newbie' forum to this forum, 'Ruby Discussions'. I don't know how to move a posting.
              Is there a more appropriate forum then 'Ruby Discussions'?
              • G
                Greg
                Just a follow-up to clarify my question: How do I set the (x,y,z) coordinates of the text to control it's orientation?
                I am programmatically assigning 3dtext as pallet labels to the front and top of pallets in a virtual warehouse created from ruby code generated from a c# application accessing inventory data from a SQL database, 2 to 3 thousand pallets.
                Right now, the text just lays flat on an x,y plane. That works for printing text on the top of pallets, but I can't orient the text upright so that it properly prints on the front of pallets.
                I hope this makes sense.
                Thank you.
                Greg
                • GaieusG
                  Ok, I see. I also moved your topic nd then found that you copied it here so I merged the two.
                  No, this is the finest forum for this (in the World? πŸ˜‰ )
                    See my TextTag script that does this. The 3d-text is grouped, it appears at 0,0,0, it's then transformed to where you want it, snapping to faces etc as desired...
                    404 Not Found
                    (www.sketchucation.com)
                    • G
                      Greg
                      Thanks TIG,
                      I actually used your code as a guide to get as far as you see here. But I don't see how to programmatically snap the 3dtext to the front and side of a cubed-shaped object (pallet) without user intervention. I need the application to snap the text to the pallet automatically.
                      Is this the section of your code I should reference for the 'snapto' functionality?
                      %(#FF0040)[compo.behavior.always_face_camera=true if @cfacing=="Yes" ### faces camera
                      if @asnap=="Yes"
                      compo.behavior.is2d=true
                      compo.behavior.snapto=0 ### snaps to Any surface
                      end#if
                      tag=model.place_component(compo)]
                      If so, I can't figure out the relationship between your compo (components) and my grpEnts (entities).
                      Greg
                        After you have auto-placed the grp containing the 3d-text you need to rotate it in Z, then so it's vertical. You need to make a "rotation transformation"...
                        transformation=Geom::Transformation.rotation(anchor_point,vector_axis,angle_radians)
                        e.g. for a right-angle about Z try -
                        rotate=Geom::Transformation.rotation(pointN.[0,0,1],90.degrees)
                        e.g. for a right-angle about Y try -
                        rotate=Geom::Transformation.rotation(pointN.[0,1,0],90.degrees)
                        etc
                        Mess around to find which you need for which group...
                        • G
                          Greg
                          Thanks TIG, I'll do this.
                          Greg
                          • G
                            Greg
                            TIG,
                            I have tried variations of the code but I can't get it to work.
                            %(#FF0040)[txtPt = Geom::Point3d.new(x+w,y,z+(h/2))
                            t=Geom::Transformation.new(txtPt)
                            grpEnts.add_3d_text("hey mon", 1, "Verdana", false, false, 4.inch, 1.mm, 0, false, 0)
                            grp.move!(t)
                            grp = Geom::Transformation.rotation(txtPt,[0,0,1],90.degrees) # these are variations
                            txtPt = Geom::Transformation.rotation(txtPt,[0,0,1],90.degrees) # these are variations
                            rotate = Geom::Transformation.rotation(grp,[0,0,1],90.degrees) # these are variations]
                            I don't understand the relationship of 'Geom::Transformation.rotation(point,vector,angle)' to grpEnts.add_3d_text.
                            What am I overlooking?
                            Thank you.
                            Greg
                            • G
                              Greg
                              TIG,
                              Thanks for your help. The following code 'status = grpEnts.transform_entities t, grpEnts.collect' rotates the 3D-Text:
                              grp.move!(t)
                              t = Geom::Transformation.rotation(txtPt,[1,0,0],90.degrees)
                              This was copied from ldraw.rb.
                              Greg
                                I'd expect this to work for the 't' rotation - note that I prefer to keep things inside parentheses () - although it will work without (usually):
                                grpEnts.transform_entities(t,grpEnts)
                                or for the group rather than it's entities
                                grp.transform!(t)
                                (it's similar to grp.move!(t) ...)
                                Now you just have to copy this group of 3d-text (grp2=grp.copy!) and move! it around the corner and rotate transform! it to suit.
                                In SketchUp Ruby here are often several ways of doing the same complex thing - like transformations -, BUT sometimes there's NOT one way of doing some simple thing !!! For example finding the active section-plane or finding if sections-cuts are currently being shown in the view (something I'm looking at currently) - even the SDK doesn't access these shortcomings in the API...
                                Glad you fixed it.
                                • G
                                  Greg
                                  Thanks TIG,
                                  I'll apply your suggestions and evaluate the results.
                                  Greg
