    Easy digital watercolor
    83 Posts 25 Posters 152.6k Views 25 Watching
      canoek
      Pixero - wow! that is really impressive. could you post your method please 😄
      Ross - i like your work. i followed your thread awhile back, when you were experimenting with different techniques with the vespa. looks really good.
      regards,
      jb
        PKast
        Pixero,
        Very good. You're watercolor and Ross' earlier one in the post are very impressive results from just plain jpegs. If you would be so kind as to share your technique that would be great.
        Best,
        PKast
          mirjman
          here's my shot at it, with line overlay and a "find edges" layer on the poster layer. its not coming out as soft as some of the other posts here, maybe its because of the lines
            mirjman
            here's another try with lightened up linework
              Ross Macintosh
              Cool! 😎
              I really like that last one! Looks great!
              Regards, Ross
                canoek
                mirjman - i really like the last one too. really cool look. post more.
                jb
                • boofredlayB Offline
                  boofredlay
                  Very nice... as was said, the last one 👍
                  • PixeroP Offline
                    Pixero
                    My method isn't a "one click" solution. I use very different settings depending on the image but the basics is:
                    First color correct the image to brighten and saturate it a bit to make it look more like a painting colorwise. Then I usually use surface blur filter to get rid of some detail. (I Make most changes on a copy of the latest layer to be able to paint back detail with a layermask if needed.)
                    Then I apply some filters on the surface blurred layer. It can be water color, drybrush or paint daubs or poster edges depending on image. I then mix between different effects with layer masks and also applies the paper texture above. Usually scaled up 200-300%. I Also use bits and pieces from real watercolor painings to get the typical watercolor looks like blooms. Then I Use some photoshop brushes for some spatter effects to get those tiny human mistakes that help selling it as a painting.
                    Collageing and filtering in Photoshop is the best we can do until Moxi is ready: http://visgraph.cse.ust.hk/MoXi/ 😲
                    • sk.lionS Offline
                      sk.lion
                      @majid said:
                      and here is the PR render of the first subject . i did it not too tight , the floor bump is too heavy , and the TV & vase & plants R not good at all ... btw here it is
                      Nice, i like the lighting in this picture, it looks so realistic. Thanks for uploading these pictures.
                      • majidM Offline
                        majid
                        thanks SK LION
                          mirjman
                          another post per request, this time on a photo i found online. i also included the layer stack at the end. remember majid's rules- this is a "one touch" solution with no human judgements in the process.
                          one note is that photoshop filters act according to absolute pixels in an image, that means you will get different results with bigger or smaller base photos, so try to resize them at the beginning to get consistent results. this image was originally 1800x before i cropped it so you could see the detail
                          for this I used photoshop cs3 and a free plugin called carravaggio by xero
                          1. copy background layer, apply filters in this order: surface blur to get rid of brick texture detail, gaussian blur, colored pencil set layer to "multiply" mode 90% opacity
                          2. copy the water puddles layer, apply find edges filter, set to "multiply" mode 50% opacity
                          3. copy the background, apply suface blur and caravaggio filters
                          4. make a new layer, apply render>clouds filter, apply render>fibers filter and scale in the horizontal direction ~200%, add a layer mask and apply render>clouds filter to the layer mask. set to "overlay" 25% opacity
                          5. create paper layer per pixero's directions above (thanks!!!) set layer to "multiply" mode
                          6. copy paper layer, set to "soft light" mode 75% opacity
                          after that you can adjust contrast/saturation to fit your taste, but the previous steps get to you to a good point in about 10 seconds. I'd be interested to see if anyone else has success with this method...
                          • majidM Offline
                            majid
                            thanx so much , i'll try it , BTW i have ps 8 !! .
                            • majidM Offline
                              majid
                              hi dear all
                              thanks to mirjman .
                              i tried your method , fixed bugs ( over hi contrast pics) and improved it . i tried it over pictures and also Pure SU output , good result , try this action ( full PS 😎 no more outer filers . (remover rb extention , load from action panel in PS)
                              dwc-o-f.atn.rb
                                mirjman
                                i just ran your action straight through on the same photo see attached. it has a nice texture
                                i am going to study your action some more, but one thing you can try is setting the "paper brightness" on the color pencil filter very high
                                  sintra
                                  Maybe this is me being a little dumb, but i dont have much experience with photoshop. 😳
                                  Could someone please tell me exactly where i need to extract the file to and exactly how it works, maybe a quick step by step.
                                  Kind regards
                                  Darren
                                    mirjman
                                    sintra: the step by step method 😃
                                    1. download majid's file to your computer, and rename the file to remove the ".rb" at the end
                                    2. open photoshop, go to window>actions to bring up your actions palette
                                    3. drag the .atn file that you downloaded onto this palette, the action will now show up on your list
                                    4. open a target image, then highlight the action. push the triangle "play" button and its all automated after that
                                      sintra
                                      Thanks for that buddy, works great 😄
                                      Darren
                                      • majidM Offline
                                        majid
                                        did anyone tried the action? plz test it over SU pure output (not renders) . thanx again
                                          Amfab
                                          Im new here, today actually, and kinda new to Sketchup. It is interesting that this topic is being discussed because I wasn't so happy with some renderings my Architect was doing…
                                          I ended up kinda learning Sketchup over the last month or two to show her the angles I wanted for the renderings. She then did a rough rendering and I wasn't too happy with it so I learned some more Sketchup stuff and in the last day or so I started messing with my Sketchup output in Photoshop... I think Im kinda getting there.
                                          Maybe you guys can add to what I have done, although I don't think that this is as good as some of the stuff I have seen here, (especially Ross’s stuff-wow) but it is all done with SU7 free and PSCS3
                                          Here is what I’m doing:
                                          I output three or four versions, changing styles each time.
                                          I have been using the Sketchup "Sketchup Style builder competition winners" Styles included with the free version of SU7
                                          "Pencil Edges With Whiteout Border. Created by Mark Paschke." Is the one I am using for this.
                                          I output Tiffs:
                                          One with no background, no sky, edges only (for top layer in PS)
                                          One with Sky, Shaded, no edges (for middle layer in PS)
                                          One with Sky, Shaded, with edges (for Bottom layer in PS)
                                          I stack them in layers in Photoshop in the order mentioned above.
                                          On the top I clear out the white so I have only black pencil, I sharpen it up a little
                                          The middle one (the one with no edges) I apply the filter Artistic>Poster edges to generate a few large contrast-ey areas...
                                          Then Noise>Median to smooth and blotch them out
                                          Then if it needs more interest a little “paint daubs”–maybe I didn't use it on this one though.
                                          Then I use diffuse glow on the bottom layer, with no graininess–this makes it pop–I so dig that filter–then I fade it back to a reasonable level after applying.
                                          I mix the layers together, the bottom layer full strength, then somewhere near 30 percent for the middle layer, combining using “vivid light” helps the colors get that over-saturated watercolor color vibe.
                                          I then just adjust the toplayers opacity to make the lines feel sharper.
                                          Then I flatten the image and paint a bit by hand with Bit box’s watercolor brushes (no affiliation–and they are free)
                                          http://www.bittbox.com/freebies/tribute-bb-watercolor-brushes-reach-1000000-downloads/
                                          Anything that is very saturated I paint with the main color at maybe 15% transparency, using the “normal” setting. And I make sure to go outside the objects to get the color running on to other objects.
                                          After I have done that I then run around with the brushes using multiply at 5-10%.
                                          You have to choose different brushes at different sizes and edit them a lot to make it look random.
                                          Anyway, I just thought I would put in my cent an a half
                                          Attached is the watercolor experiment–I darkened up the jpeg because when I was converting the sky was getting washed out, PC gamma people let me know if it is too dark for you.
                                          -Andrew
                                            Amfab
                                            Jan, I just tried your paper, tak så mycket. And by the way using a picture of Sweden isn't fair, as the whole country looks like a watercolor to begin with.
                                            -Andrew
                                            • 3 / 5
