    Sponza style
    31 Posts 12 Posters 5.7k Views 12 Watching
    • boofredlayB
      boofredlay
      I have seen your Spongebob renderings. I bet your boys loved that!
      • Al HartA
        Al Hart
        Nice work! šŸ˜„
        Can you post the .SKP file?
        Or send it to al.hart AT renderplus DOT com?
        I would like to try IRender Nxt's new indirect lighting algorithm with it.
        Thanks,
        Al Hart
        IRender nXt from Render Plus
        • soloS
          I sent it to your email, good luck and pls post the results.
          • soloS
            http://img230.imageshack.us/img230/3302/ivyrendernm2.jpg
            Blooming-glow
            http://img220.imageshack.us/img220/9642/ivytooph0.jpg
            Just a question, my image is 800x600, but seems to be cropped...see signature..??
            • GaieusG
              The board is optimized for 1024 screen resolution.
              This board is cropping these images while the old board exploded the style (the post was wider than the others)
              What is better?
              • soloS
                Thanks Coen
                I will scale my renders accordingly in future.
                • Al HartA
                  Al Hart
                  Thanks for helping me find the SKP model.
                  I rendered it with the new IRender nXt engine, using HDRI illumination rather than the sun, and indirect lighting effects.
                  http://www.renderplus.com/pdf/images/sponza2.jpg
                  Al Hart
                  • david57D
                    david57
                    The one's with the plant, looks exellent. Had never seen this renders before.
                      maleemk
                      I used to be a Accurender fan ( the core behind the IRender nXt ) but now i am mush disappointed about it's development. In old times it was way ahead its time ( remember Radiosty ) but now it's lacking a lot. see the above pic, how can you compare it even with podium. forget about the big brothers like Mexwell, Vray, Fryrender,KT, Indigo etc.
                      • Al HartA
                        Al Hart
                        The point of the IRender rendering was that it was done without adding lights, etc.
                        Here are some more Sponza renderings of the same model created by another user:
                        http://nxt.accurender.com/photos/sketchup/images/1889/640x480.aspx
                        http://nxt.accurender.com/photos/sketchup/images/1888/640x480.aspx
                        Nxt is much improved for lighting and reflection. But its big value, especially for SketchUp users (who tend to create relatively quick 3D models of things, as opposed to, say, Rhino, which is used for much more complex models), is that it can make really good renderings with no effort - using the "High Dynamic", automatic lighting. And if you take the time to add a little reflection, it can be quite stunning.
                        See the nXt gallery for more samples: http://nxt.accurender.com/photos/
                        Also, (for the record), IRender nXt is not based on the old AccuRender engine, but on an entirely new engine, which is doing some really impressive things.
                        Al Hart
                        • jeff hammondJ
                          i didn't want to start a new thread for sponza in glass so i'm just doing a little hijacking here :)... can you email the skp to me as well?
                          http://homepage.mac.com/jeffhammond/.Public/suforum/sponza.jpg
                            sepo
                            Could not resist myself šŸ˜‰
                              richcat
                              Sepo love it 🤣
                                mauritzbotha
                                This Sponza was rendered using the Mac version of IDX-Renditioner.
                                Sponza with IDX Renditioner
                                Mauritz Botha
                                • Al HartA
                                  Al Hart
                                  I'm not sure I have your email address.
                                  Send an email to
                                  http://wiki.renderplus.com/images/d/d3/Support-email.PNG
                                  and I'll send your the .SKP
                                  i didn't want to start a new thread for sponza in glass so i'm just doing a little hijacking here šŸ˜„... can you email the skp to me as well?
                                  Al Hart
                                  With your input, this post could be even better šŸ’—
                                  • 2 / 2
