    XNormal--free program for elaborate bump mapping
    4 Posts 3 Posters 5.6k Views 3 Watching
    • L
      lewiswadsworth
      For various reasons I was researching bump maps and I discovered this free progam:
      404 Not Found
      (www.xnormal.net)
      As far as I can tell, this program allows you to create a "normal map" (which is a kind of elaborated bump map) from an existing, textured and mapped 3D model in various formats.
      Here's the full explanation of what a "normal map" does:
      http://en.wikipedia.org/wiki/Normal_map
      The idea, with particular relevance to gaming and animation where you need to have both detail and a low-polygon count, is that you can basically apply the normal map made from the high-polygon-count model to a lower-polygon model and largely maintain the appearance of high-count detail in renderings and animations made using that lower-count model.
      Now, this is not going to work in SketchUp, but you could output your SketchUp model in some format xNormal will take, create the normal map, and then in some other program reduce the polygon count of the model and apply that normal map to make your animations faster to render. I noticed while going through the most recent update of Blender that it has the ability to apply normal maps to meshes, and I'm sure things like Max and Maya can as well.
      It will be weeks before I have the time to try this out, and I frankly don't get a lot of calls to produce animations. So I thought I would throw this out in the hope that someone will have a chance to do something neat with it and presumably show us.
      col sporcar si trova
        arvmehta
        Another program for normal maps
        Site not found · DreamHost
        The owner of this domain has not yet uploaded their website.
        (www.crazybump.com)
        • L
          lewiswadsworth
          I like the Crazybump programmer's sense of humor...instead of progress bars the program simply displays, "Puny humans will have to wait."
          Weirdly minimal website, though.
          • GaieusG
            @lewiswadsworth said:
            ...Weirdly minimal website, though.
            True but the software speaks for itself. There is the initial video and the forums with looots of amazing posts.
