    NoTwist using Joint PP
    19 Posts 8 Posters 1.9k Views 8 Watching
      dtrarch
      Bingo
      After a little messing around with Joint PP I did find a basic solution to the old and messy Twisted Sister issue in SU path extrude.
      At last it is really possible to create at least a simple roadway using an inclined path that really stayed level using the JointPushPull ruby set.
      Just a brilliant ruby solution and terrific docs too.
      Many thanks to Fredo6 for this impressive work.
      The basic first shot is attached
      dtr
      No Twist Solution.skp
      • Mike LuceyM Offline
        Mike Lucey
        Yes indeed thanks to Fred06 and to you for the explanatory skps
        Mike
        • JClementsJ Offline
          JClements
          detrach:
          In your .skp you mention choice "J". I don't have that listed in my PullDown menu.
          Has there been newer release of the ruby or is this a typo?
          • jeff hammondJ Offline
            @jclements said:
            detrach:
            "J" is what it says on the tool icon if you have it turned on... there are two icons- both with a push/pull looking graphic and one has a J .. the other has a V
              "J" for "Joint PP" (briefly and roughly perpendicular to faces) and "V" for "Vector PP" (in one direction).
                JClements
                OK.
                I had forgotten about the toolbar.
                J
                • erikBE Offline
                  erikB
                  I am sorry dtarch but I do not understand how you get from the extruded line to the (not twisted) road in your example file ?
                  If I JPP de extruded line I do not get your result. any help ?
                  erikB
                  • soloS Offline
                    Where can I find the extrude vector 2 points ruby?
                    • erikBE Offline
                      erikB
                      Solo,
                      I have a separated ruby that extrudes by vector but I do not remember where I got it. BUT the function is also available in the projection ruby by Didier Bur witch you can find on this forum.
                      greetings, erikB
                      • soloS Offline
                        Thanks for the reply, I will try find the separate ruby, if anyone knows where I can find it I would appreciate the help.
                        • erikBE Offline
                          erikB
                          solo, I looked it up in the ruby and the initial ruby was also by Didier. So I guess I can put it here on the forum since it was a free ruby. If I couldn't please let one of the mod's remove it.
                          greetings erikB
                          extrudelinetool.rb
                          • soloS Offline
                            Thank you, I would never have found it as the name is different to the one I was searching for.
                              dtrarch
                              ErikB
                              Sorry to miss all the problems finding the ruby.
                              FYI I draw a vector in the direction and height needed.
                              It can be anywhere as it is just a reference entity.
                              If snapped to the line to extrude it is a good idea to group the vector reference.
                              You can see it in my first scene.
                              Hope this helps a bit.
                              dtr
                                a4chitect
                                dtrarch which version of the JPP script are you using? because mine doesn't allow to set "normal to blue axis". is it a different version, or am I just doing something wrong?
                                thanks for your perfect workaround for creating 'correct' roads. I suggest using this approach to generate appropriate surface for the road (from simplified road contours) and then draping the exact shape of the road on this surface to get precise road surface
                                  a4chitect
                                  all right - I guess that the 'missing' normal to blue axis is not available in the graphical JPP.
                                  this is what fredo6 says about setting privileged plane in his visual edition:
                                  For Joint Push Pull, you can set the privileged plane by using short cuts Ctrl+Arrow, or just pressing Ctrl to enter a mode where you can specifiy any plane visually.
                                  • erikBE Offline
                                    erikB
                                    I am sorry dtarch, but I still don't get it !
                                    I know how to extrude the line, that is not the problem but how do you get from the vertical plan thus created to the PP road using the ruby ?
                                    I tried all the differt ways to JPP but couldn't reach your result. I clearly missing something ๐Ÿ˜• Any clarification ?
                                    erikB
                                      dtrarch
                                      Hi erikB
                                      Here is the sequence.
                                      1-an inclined curved path was created with grouped vector on z axis to use as the extrude by 2 points path.
                                      2-using the [extrudelinetool] ruby (by 2 vector points) the path was extruded up the z axis.
                                      3-the face created was selected and the [J] icon for the Joint PP was selected using the settings per my post.(use the [tab] to access same.
                                      4-the tool was then used to PP the face and it was done.
                                      โ˜€ ๐Ÿ˜„
                                      Hope this clears things up for you.
                                      dtr
                                      • erikBE Offline
                                        erikB
                                        Thanks dtarch, got it now. It was the crtl-arrows function in conjunction with the jpp that did the trick. Sorry for the hassle.
                                        greetings, erikB
                                          dtrarch
                                          erikB
                                          Glad to help
                                          Of course a no-twist extrude along path would be the real answer but jointPP will work pretty well and glad to have it
                                          dtr
