    Topography into sketchup
    40 Posts 16 Posters 23.4k Views 16 Watching
      Well, make sure to smooth the surface first and apply the drape tool second. If everything works well*, the draped lines separate the surfaces and you should be able to select/paint them separately.
      *sometimes the drape tool won't precisely work and you may need to find the gapes between line segments and close them manually. In these cases turn on hidden geometry to see the original TIN as well and to be able to close them correctly.
        Mr S
        I decided that the best solution, suggested by Gaieus, was to go back to the Data Survey company and ask them to send me data suitable for use in a 3D package. I mentioned that I may be able to use a tool that works with a simple text file.
        I downloaded and installed Cloud V6 with its example.dat file.
        Below I show samples of the example.dat file and the simple text file I was supplied with.
        As you can see they are similar, but Cloud V6 won't process the survey file.
        Error: "Only 1 data per line"
        Any ideas? Any help appreciated.
        Example.dat file:
        -4290.989333,29509.42004,17271.801618
        -4274.989333,29511.005136,17286.136452
        -4289.989333,29488.014542,17264.960225
        -4289.989333,29466.389034,17268.746701
        -4275.989333,29491.061477,17295.038726
        -4274.989333,29469.013192,17287.431288
        -4273.989333,29448.496995,17278.538275
        -4241.989333,29453.771813,17323.717654
        -4242.989333,29494.627943,17327.292103
        -4242.989333,29473.248948,17328.260914
        -4226.989333,29474.834044,17342.595748
        -4209.989333,29476.41914,17356.930583
        -4225.989333,29430.887233,17333.782246
        -4225.989333,29454.714121,17337.286444
        -4239.989333,29409.851506,17322.714357
        -4240.989333,29428.782607,17317.272535
        -4223.989333,29412.202646,17336.406403
        Site Survey.txt file:
        017,NORM
        001FORMAT(3D23.17)
        003,ORDR,4=1,1,2,3,
        080,B000, ,5= 0.0, 0.0,100007703
        0.49837422321267177D+040.49869317927816728D+040.67812740300658106D+02
        0.49794159350231557D+040.49846097107062114D+040.67878910415849163D+02
        0.49776537255463436D+040.49836638683515694D+040.67878910415849163D+02
        0.00000000000000000D+000.00000000000000000D+000.67878910415849163D+02
        080,B001, ,5= 0.0, 0.0,100007703
        0.49547870430138828D+040.50609582792710808D+040.65732765063426058D+02
        0.49568466124033775D+040.50566385791095627D+040.65813697637536023D+02
        0.49590731422961362D+040.50519860486242706D+040.66166417278662365D+02
        0.00000000000000000D+000.00000000000000000D+000.66166417278662365D+02
        080,B002, ,5= 0.0, 0.0,100007703
        0.49512690401388672D+040.50511415069123086D+040.65929156188998277D+02
        0.49550570526746833D+040.50527709423329316D+040.65901904671221885D+02
        0.49558844990824973D+040.50510189197858554D+040.65944131344513437D+02
        0.49520964865466813D+040.50493894843652324D+040.65971382851789116D+02
        0.00000000000000000D+000.00000000000000000D+000.65929156188998277D+02
        080,B003, ,5= 0.0, 0.0,100007703
        0.49547896016676204D+040.50609597659579667D+04-.99900000000000000D+03
        0.49605844595099497D+040.50638011225230885D+04-.99900000000000000D+03
        0.49683981386075220D+040.50676027706360901D+04-.99900000000000000D+03
        0.00000000000000000D+000.00000000000000000D+00-.99900000000000000D+03
        Regards
        Mr S
        • AnssiA Offline
          Anssi
          Mr S,
          It seems to me that Didier's script expects commas as the break symbol and uses a dot as a decimal symbol. Your file has some other method of distinguishing the x, y, and z coordinates, represented, perhaps, by the characters D+0. You might try opening the survey file with Notepad, and replacing all "D+0" s with commas. Maybe all the lines that clearly don't represent 3D coordinates should be deleted too.
          Just a suggestion
          Anssi
          Edit: now that I look at it closer, I am not so sure about how the format could be figured out... Maybe you could ask the supplier.
            GreyHead
            It looks to me as though these lines parse into three numbers: so
            becomes
            0.49837422321267177D+04 0.49869317927816728D+04 0.67812740300658106D+02
            The data in the elevation file looks like this (from a random point):
            4968388, 4982342, 0
            add back in the elevation for this point and you get
            4968388, 4982342, 68.0
            These are like the numbers from the data file so maybe the D+02 is an exponent (a decimal scaling factor). If so then the data file now reads:
            4983.7422321267177, 4986.9317927816728 67.812740300658106
            Roughly scaling off a building it looks as though these are in units of meters or thereabouts.
            I pulled out the valid points (those with three non-zero entries) and parsed them into this format in a text editor. The result is in the attached data file which will import into SketchUp with Didier's cloud script. The result is not exciting - there are eleven almost coplanar points - but looks OK.
            Bob
            elevations.txt
              Seems to be logical (though I'm not sure about them).
              Now can you make an automated way for doing this with all those thousands of points?
              • Didier BurD Offline
                Didier Bur
                Cloud script assumes that ALL lines of the input file are formatted identical, from line 1 to end line, no matter the delimiter.
                So the first line of your file "017,NORM" even if it has a comma delimiter, doesn't have 3 data (x,y, and z) in it.
                Sorry but I didn't coded the script as to parse what is a line of 3D coordinates and what isn't...
                DB
                  GreyHead
                  I don't think that it would be too difficult to clean the script into a form that would be usable by Didier's cloud script - for the short sample I just deleted the lines that weren't xyz co-ordinates. For thousands of lines there are a couple of approaches. Manually I'd probably sort the list (the sequence isn't important), then delete the blocks of junk; import into Excel and parse the lines into three columns, do a couple more sort and deletes and that's it.
                  If the sequence were important, or this were a frequent task then a tool like TextPipe Pro will chew through it.
                  Bob
                  PS If someone can send me the full data file, I'll happily give it a go.
                    I doubt the sequence is important since Didier's sript interprets every line separately and it's all the same which order they are put into the model - the final result will be the same.
                      Mr S
                      I think I will give my brain a rest and learn how to read and write in Sanskrit.
                      Visit: http://en.wikipedia.org/wiki/Sanskrit.
                      Looks a lot easier to me.
                      Regards
                      Mr S
                      • boofredlayB Offline
                        boofredlay
                        If you want to upload the dwg here just put it in a zip folder, or put .rb on the end. Then just tell us you did so and to remove the .rb before opening.
                          russellbeta
                          Just found this:
                          Description: Often the site contour data generated by the surveyor is quite dense (more than 5,000 edges). Attempting to generate a surface using the Sandbox From Contours tool may take a very long time. To speed up the process, you may simplify the contours using the SimplifyContours.rb Ruby script.
                          only problem is, The download doesnt work. am having a hard time finding a working one... anyone have an idea?
                            Where did you try? At the sketchup.google.com site or elsewhere? You may try it in the Ruby Library Depot - I believe Didier has collected all "freebies" from the web. 😉
                            • 2 / 2
