    KT
    49 Posts 9 Posters 5.9k Views 9 Watching
      kwistenbiebel
      Hi David,
      Looking better and better.
      A good ground texture will make this more alive.
      I like the crispness of the images so far. Keep those coming.
      • david57D Offline
        david57
        Thanks kwistenbiebel.
        Here's a ground view.
        • david57D Offline
          david57
          • david57D Offline
            david57
            Used KT's Instancing tool to populate a sphere with leaves.
              Really cool idea. and generally speaking, the plants give a nice extra to the images (although the treeline seems to be a bit flat and too roughly cutout)
              • david57D Offline
                david57
                A try at 8 spheres. The one to the far left, was my first test tree.
                the leafs are to large and to sparce.
                  Nice hedges can also be created this way...
                  • david57D Offline
                    david57
                    Yes hedges and grass, but havent tried grass.
                    Working here on a deserted island, hopeing not, to see what's his name
                    walking through here, in his birthday suit.
                    • majidM Offline
                      majid
                      hi all /david .
                      i tried KT Brush over a bush i separately inserted and merged whit a leaf, and here is the draft render result , maybe it is good for mid-distance foliages . u may improve this idea using flowers ... bushes , trees ...or people ..
                      3rd test
                      • david57D Offline
                        david57
                        Tried Clipmaping of leafs, but couldn't get the right results.
                        • david57D Offline
                          david57
                          • david57D Offline
                            david57
                            Tree Trunk, Branches,and 10 Leafs were made with a Blender script called Gen3.
                            Made Components with Trunk, Branches, and only 10 Octagon Leafs in SU.
                            The same Ten Leafs were used for the Hedges, but smaller.
                            • david57D Offline
                              david57
                              Two more.
                              • david57D Offline
                                david57
                                Here,s another render.
                                • david57D Offline
                                  david57
                                  Model in the background was not made by me.
                                  Model can be found at
                                  http://archidom.net/ddd/model_S.htm
                                  • david57D Offline
                                    david57
                                    Needs Pillars or Columns under the radius.
                                    • david57D Offline
                                      david57
                                      Trying to figure this one out, before a render. Need to remove the door ways
                                      on the first floor, they look like men and women restrooms.
                                      • david57D Offline
                                        david57
                                        • david57D Offline
                                          david57
                                          Here's a Progressive Path Tracing. I could'nt get rid of the arched door ways. I didnt
                                          have the guts.
                                            Never mind. Toilets/bathrooms are always needed.
                                            But how come that tree is growing from the pavement? 😲
                                            Nice render BTW
                                            • 2 / 3
