    KT
    49 Posts 9 Posters 8.9k Views 9 Watching
    • david57D
      david57
      Here's a try with KT, with the same model, since i don't have
      the time to mass produce them.
        rcossoli
        te roof and trees are great!!!!
        THREEDIMENSIONSWEB dot COM
        • david57D
          david57
          He a try at KT 2008 on a model made last year. Background is a cutout png made
          with gimp.
          • G
            goodonline
            I really like the roof in the first image. It looks like you created it from actual geometry, not a bump map..
            Nice work!
            Robert Good
            http://www.digitalnursery.net
            • david57D
              david57
              Yes goodonline, roofs were modeled with SU.
              • david57D
                david57
                Here's another, looks like a doll house.
                • david57D
                  david57
                  A push pull on the right side.
                  • soloS
                    Very nice and clean images.
                    • david57D
                      david57
                      Using setting #8 for rendering.
                      Here's another style. Needs glass on the radius.
                      • david57D
                        david57
                        Messed it up. Deleted parts of mullions on the right by mistake.
                        • K
                          kwistenbiebel
                          Hi David,
                          Looking better and better.
                          A good ground texture will make this more alive.
                          I like the crispness of the images so far. Keep those coming.
                          • david57D
                            david57
                            Thanks kwistenbiebel.
                            Here's a ground view.
                            • david57D
                              david57
                              • david57D
                                david57
                                Used KT's Instancing tool to populate a sphere with leaves.
                                • GaieusG
                                  Really cool idea. and generally speaking, the plants give a nice extra to the images (although the treeline seems to be a bit flat and too roughly cutout)
                                  • david57D
                                    david57
                                    A try at 8 spheres. The one to the far left, was my first test tree.
                                    the leafs are to large and to sparce.
                                    • GaieusG
                                      Nice hedges can also be created this way...
                                      • david57D
                                        david57
                                        Yes hedges and grass, but havent tried grass.
                                        Working here on a deserted island, hopeing not, to see what's his name
                                        walking through here, in his birthday suit.
                                        • majidM
                                          majid
                                          hi all /david .
                                          i tried KT Brush over a bush i separately inserted and merged whit a leaf, and here is the draft render result , maybe it is good for mid-distance foliages . u may improve this idea using flowers ... bushes , trees ...or people ..
                                          3rd test
                                          • david57D
                                            david57
                                            Tried Clipmaping of leafs, but couldn't get the right results.
                                            • 1 / 3
