    Privacy & the Upper story deck
    26 Posts 15 Posters 2.8k Views 15 Watching
      Charlie__V
      @sorgesu said:
      The picture says it all. There is no privacy either on the deck or on the lawn with these houses. Can you think of something that would work with the usual suburban bylaws and provide privacy for these houses both on the deck and in the back yard?. I know that we are not allowed fences that are taller than 6 feet and that is already what they are. I'm not sure but I don't believe we are permitted to build permanent structures on the side of the decks.Pretend that money is not object, I'm just conjecturing here for the fun of. Would I be allowed to plant fully grown pine trees on either side? I bet there are shadow casting restrictions. The backyards face South, BTW.
      I'd be really interested in some really creative ideas. Don't spare the expense
      Susan,
      I was merely suggesting something that is common practice to my area.
      Simply put,Privacy walls(No Glass/other) on ONE Side of each property.
      Oh, and I know bylaws are usually such a riveting read, that you just can't put them down...do like I do, and read them in the "library".... wink..wink.
      Seriously though, given your apparent setbacks you may already have a privacy wall requirement.....look for this in the bylaws.
      I wish you the best in your endeavors.
      Edit:
      Susan....are your bylaws for a private community?...try contacting the ARB...ARC on this matter.
      C
        tomsdesk
        I suppose yet another way to go is to fill your backyard with such offensive activities that your neighbors are searching the bylaws...think National Lampoon Vacation(s)!
        2.5D Trees & Shrubs!
          remus
          you could try putting up a lightweight trellis and then getting a creeper to grow up the side of the house onto the trellis. Quite a long term solution though ๐Ÿ˜›
            bcoleman001
            Susan, can you post your model? If you can, I'll drop a few in and then figure out how to post it back for you.
              sorgesu
              The model is too big. I tried to simplify as much as possible. Hmm. Maybe with just one house. Let me see. Yup, that works. Here is the one house. Thanks much.
              upperstory_deck2.skp
              Susan Sorger
              Former Seller Hand Rendered Entourage
              Former Canadian Authorized Training Centre, SketchUp
                Stu
                Susan I think it's time to have a friendly chat with your neighbours and explain to them that every action [peeking at you on the deck] has a reaction [not necessarily equal and opposite]
                And I'm sure there will be nothing in your local regulations about having a couple of six pounders on you rear deck.
                http://www.landesign.com.au
                • tinanneT Offline
                  tinanne
                  ๐Ÿคฃ
                  Executive Director : American Society of Architectural Illustrators
                  AIP 30 Competition opens soon. ASAI.org
                  Architectural Rendering
                  • Joe WoodJ Offline
                    Joe Wood
                    Darn, been wracking my brain to come up with a nice solution for you Susan, but with
                    Bylaws like you have, this is tough. (have you checked them yet, no permanent structures?)
                    A pergola/patio cover structure helps some for when people are looking down on you, especially if you do planting, or roll down screens on the sides. I show bamboo roof covering but even fairly open 2x2s or 2x4s latticework give good screening when viewed from an upper angle.
                    My most recent deck had a similar issue with needing to screen out a street to one side. For shade I did a Patio Cover, and for the screening I made a simple Bamboo Screen and fairly open Privacy Railing for that one side.
                    http://woodsshop.com/PROJECTS/Mill/Finish/a2.htm You don't really need either to be solid, blocking out the view. Even your typical wood latticework gives you a pretty good sense of privacy.
                    More pics of that project http://woodsshop.com/PROJECTS/Mill/MillDeck.htm
                    I think you should do what Ross suggested, and go ask some questions. Seems to me that if all three of you neighbors request to be able to add some privacy, the rules could get changed. I've never heard any rule against permanent structures as long as they conform to the Setback Rules. Charlie has the best ideas with screens all on the same sides, but they'd only need to be maybe 5' 4" tall.
                    Joe Wood
                    woodsshop.com/
                      angusog
                      Don't know if this is feasable or even if the products are avaulable to you Susan, but here in Aussie land, a common pratice and shade solution from sticky beaks and the sun is to use shadecloth, semi transparent netting similar to flyscreen doors, although the fabric used is a more complicated and stronger version, and I am sure you and some of our designer peope could place it more aesthetically.this can be installed as a non permanent fixture, the shadecloth being attached to the posts with adjustable turnbuckle connections. anyway just a wee idea from down under
                        bcoleman001
                        Susan,
                        I apologize for taking so long to get back to you. Here's what I was suggesting. You can do the same one both sides of the deck as needed. Hopefully your neighbors will be ameanable to a plan similar to this. You can always plant your trees in a hedge a little closer together if they won't.
                        Tree Privacy Planting
                          guite
                          Interesting topic with lots of ideas pouring in. Even so, as I scan down the page, if the preceding post had an image, my thought process would have flowed smoothly into it.
                          So, I think we should encourage posting of screen shots, so that basic information is visually available in the forum page itself. Downloading and opening attachment would be for getting more detailed insight or saving the file. Think convenience and saved bandwidth.
                          Sorry to be off topic, but relevant nonetheless, IMHO.
                          Guite
                          • 2 / 2
