    Green Toaster's Car Sketches
    745 Posts 45 Posters 200.4k Views 45 Watching
      GreenToaster
      I think your work is outstanding.
      I agree 100% - very inspirational, artistic, and very cool!!!
      I'd be very happy to be at your level of modeling & creativity - so, I'm going to press on and learn how.
      Thanks ely862me!!!
      If you really want something you won't ever stop pursuing it.
        GreenToaster
        Here's a quick attempt at this technique - there is much to learn, like what is smoothing - when should it be used - why can't I see my surface edges anymore?
        AND - I just discovered arcs are dimension driven so it's easy to change them quickly!!! Wow, that's a nice feature.
          Brad,
          Until you start "handstitching" an arc (and thus ruining its curve entity), you can always hover over its middle endpoitn and modify its bulge. So just quickly draw the arc in the direction you desire and you can play with its bulging later (often you cannot pull it up enough because of some disturbing inferencing).
            GreenToaster
            Thank you Gaieus - great to know that, very helpful.
            Here's a file (attached) where I'm trying some more new things. I could see with 3 or maybe 400 hours of doing this, I could begin to understand it well. :rolleyes:
            Happy Sketching,
            Brad
            bw_car_0481.skp
            • ely862meE Offline
              ely862me
              well done,i see u going in a good direction
              Elisei (sketchupper)
              Come and See EliseiDesign
                GreenToaster
                Thanks - coming from you that's very encouraging!
                Here's a hood for a car I was working on - again, just trying to master the simple stuff. I couldn't resist creating a quick scoop.
                I've also been quickly reminded that making use of layers is very helpful as well as keeping a copy of the pre-smoothed groups of surfaces by using components - I can't figure out how to change surfaces after smoothing is done otherwise.
                I'm having trouble moving endpoints of surfaces - when I grab one, the red/green/blue axes don't lock . . . very puzzling . . . so I end up grabbing what I want to stretch, punch, or move and copy it over, create some construction geometry, make the change, then move it back - there's gotta be a better way.
                Thanks,
                Brad
                  Brad,
                  You can always turn on hidden geometry (View menu) and work with your softened/hidden lines as with "normal" ones.
                  Also when I'm moving endpoints, after clicking on them (but before moving), the axis lock with the arrow keys alwas work.
                    remus
                    very nice, i especially like the little 'e' badge.
                    greentoaster, youve come so far! i really must try and learn some of the things your doing here, maybe then i could start making models that are closer to the quaity of yours.
                    • ely862meE Offline
                      ely862me
                      the e badge is coming from my name elisei(elisha-us language,eliseo-spanish language)
                      • soloS Offline
                        Ely that’s an awesome model.
                        However, as great as your model is and to some extent very relevant to the topic and all you have jacked many threads with your images. Please start a new thread with your fantastic looking cars and maybe an explanation as to how you achieved them.
                        As just posting images in this thread which is an evolutionary portfolio almost of GT's work kind of kills it.
                        • ely862meE Offline
                          ely862me
                          again i make a misstake
                            GreenToaster
                            This technique opens up a whole new world . . . somewhat time consuming - figuring it out as I go, never really done this before - even though I'm trying to avoid it, some of the surfaces get complicated quickly.
                            • ely862meE Offline
                              ely862me
                              a typ for u, i usually work with a half,only when i make some principal wires i doble it, i draw the lines and after i remove it again, u reduce the work on half,but if i look carefuly i see that u did this already 😄, another type:u make the arches then divide them in how many segments do u want(more segments=more polys=more accurate=more time spent on a car),after dividing clear a segment and replace it with a line(do this with all segments)
                                GreenToaster
                                yes - good tips, thanks
                                at this point, I'm not very concerned with high quality and accuracy - just trying to figure out this technique. I know the example above is very "rough."
                                Happy Sketching,
                                Brad
                                  GreenToaster
                                  Okay . . . I am loosing my patience for the stitching method so . . . I whipped out another super-quicky . . .
                                  Cheers,
                                  Brad
                                  • marked001M Offline
                                    marked001
                                    i havent kept up with this thread...so forgive me if this has been mentioned.. but definitely check out justin's blog for help with modelling vehicles, etc... go through the archives and look for some videos where he's recorded his modelling process.. his techniques are extremely helpful.. i just started modelling my first 'vehicle' and coudlnt have done it without his blog.... http://www.giantmonster.tv/giant/?page_id=182
                                    http://www.revision21vis.com
                                    instagram: revi21on
                                      GreenToaster
                                      Thank you marked101.
                                      Here's another one I did while teaching today . . . beats workin', eh?
                                      Happy modeling,
                                      Brad
                                        GreenToaster
                                        . . . little tweaking . . .
                                          GreenToaster
                                          . . . shaping the front some more . . .
                                            GreenToaster
                                            . . . attempted interior components: seats, steering wheel, dash . . .
                                            • 37
                                            • 38
                                            • 5 / 38
