    Green Toaster's Car Sketches
    745 Posts 45 Posters 285.3k Views 45 Watching
    • G
      GreenToaster
      Okay - thank you, I'll try it - I think I (finally) understand how you did it.
      I'll post my experiment on Friday.
      Thanks again,
      Brad
      If you really want something you won't ever stop pursuing it.
      • ely862meE
        ely862me
        here is a little part from my new concept car, as i was talking u must make the wires after that fit them of cource u must have in mind the desifn of the car else u can t do a car, right? the position of the weels is taken from another concept of mine and i modified a litlle the lenght
        Elisei (sketchupper)
        Come and See EliseiDesign
        • boofredlayB
          boofredlay
          Using Bruce's method (a bit higher poly) and playing with This Script I generated these. πŸ˜‰
          • G
            GreenToaster
            %(#000080)[Thanks all! I was able to figure out what I call "bubble shaping" where the sphere is squished, cut, & so forth (see my "bubble" car on or near the first page of this thread) but thanks very much modelhead for sharing that with everyone - a great techinque.
            ely862me, that's really nice you posted those images and included some explanation. I've never modeled anything before using that technique although today I tried without much success.
            There is no doubt that stiching a model together is most accurate but not many of us have that kind of time luxury.
            Yes, this looks like a time consuming approach - I'm used to other tools, but I'm not an expert with the cool looking stuff: surfaces! πŸ˜‰ I've been using Pro/E for years and my surfacing capabilities aren't well developed. I'm looking forward to getting this technique down.
            I'm not very confident I can figure out how to "see" the model first - your words are very true and I believe some people have a natural ability to do this sort of thing where some do not. I clearly am in the latter category. I can "chop & chisel" flat surfaces all day - easy - but creating those beautiful smooth amorphic surfaces - wow, very impressive. Your images and words are very helpful & encouraging. I'm going to try again with something simple later tonight.
            Boofredlay, that's a very nice script but I'm not sure how I could use it yet - thanks for posting it and showing the very nice examples.
            Happy Sketching,
            Brad]
            • boofredlayB
              boofredlay
              Brad, the script is excellent for creating a thickness of an odd shape. Look at the solid one of the two shapes. This could prove very useful in making many car components FWIW.
              Cheers.
              • G
                GreenToaster
                Boofredlay, thanks, I'll play with it.
                Here is my first "real" attempt at stitching (is that what I'm doing?).
                I can see how this is going to be lots of fun - a few questions:
                [1] --> Does it look like I may be on the right track?
                [2, 3, & 4] --> I have SketchUp Pro - doesn't it have high quality rendering built in? How do I take my very rough hood and make it "nice" and smooth? Do I just add more triangles?
                Thanks,
                Brad
                πŸ˜„
                bw_stitchy_hood_01.skp
                • G
                  GreenToaster
                  . . . 2nd attempt . . . just playin' around, nothing serious - this has some interesting possibilities for sure.
                  I wanted to take a circular surface and blend it quickly into two conics . . . I have lots to learn . . . but it's fun.
                  • ely862meE
                    ely862me
                    i know and i agree that my tehnique takes time but look what i can do with it,sincerly i can t imagine to make cars helped by spheres or else of cource if u play a lot with it u can do nice thingsplatforma +roti6.jpgplatforma +roti7.jpg
                    u ll see soon this car in warehouse i must finish the interior,front and rear lights and some little things
                    • ely862meE
                      ely862me
                      this is not finished but i couldn rezist to not take a picture
                      • G
                        GreenToaster
                        I think your work is outstanding.
                        I agree 100% - very inspirational, artistic, and very cool!!!
                        I'd be very happy to be at your level of modeling & creativity - so, I'm going to press on and learn how.
                        Thanks ely862me!!!
                        • G
                          GreenToaster
                          Here's a quick attempt at this technique - there is much to learn, like what is smoothing - when should it be used - why can't I see my surface edges anymore?
                          AND - I just discovered arcs are dimension driven so it's easy to change them quickly!!! Wow, that's a nice feature.
                          • GaieusG
                            Brad,
                            Until you start "handstitching" an arc (and thus ruining its curve entity), you can always hover over its middle endpoitn and modify its bulge. So just quickly draw the arc in the direction you desire and you can play with its bulging later (often you cannot pull it up enough because of some disturbing inferencing).
                            • G
                              GreenToaster
                              Thank you Gaieus - great to know that, very helpful.
                              Here's a file (attached) where I'm trying some more new things. I could see with 3 or maybe 400 hours of doing this, I could begin to understand it well. :rolleyes:
                              Happy Sketching,
                              Brad
                              bw_car_0481.skp
                              • ely862meE
                                ely862me
                                well done,i see u going in a good direction
                                • G
                                  GreenToaster
                                  Thanks - coming from you that's very encouraging!
                                  Here's a hood for a car I was working on - again, just trying to master the simple stuff. I couldn't resist creating a quick scoop.
                                  I've also been quickly reminded that making use of layers is very helpful as well as keeping a copy of the pre-smoothed groups of surfaces by using components - I can't figure out how to change surfaces after smoothing is done otherwise.
                                  I'm having trouble moving endpoints of surfaces - when I grab one, the red/green/blue axes don't lock . . . very puzzling . . . so I end up grabbing what I want to stretch, punch, or move and copy it over, create some construction geometry, make the change, then move it back - there's gotta be a better way.
                                  Thanks,
                                  Brad
                                  • GaieusG
                                    Brad,
                                    You can always turn on hidden geometry (View menu) and work with your softened/hidden lines as with "normal" ones.
                                    Also when I'm moving endpoints, after clicking on them (but before moving), the axis lock with the arrow keys alwas work.
                                      remus
                                      very nice, i especially like the little 'e' badge.
                                      greentoaster, youve come so far! i really must try and learn some of the things your doing here, maybe then i could start making models that are closer to the quaity of yours.
                                      • ely862meE
                                        ely862me
                                        the e badge is coming from my name elisei(elisha-us language,eliseo-spanish language)
                                        • soloS
                                          Ely that’s an awesome model.
                                          However, as great as your model is and to some extent very relevant to the topic and all you have jacked many threads with your images. Please start a new thread with your fantastic looking cars and maybe an explanation as to how you achieved them.
                                          As just posting images in this thread which is an evolutionary portfolio almost of GT's work kind of kills it.
                                          • ely862meE
                                            ely862me
                                            again i make a misstake
                                            • 37
                                            • 38
                                            • 4 / 38
