    Making an image of what's on the screen...
    19 Posts 9 Posters 1.3k Views 9 Watching
    • N
      not registered yet
      utiler,
      Something that most folks aren't aware of is that Alt-PrtScrn (in Windows) captures just the current window, not the entire screen.
      Personally, though, I like the screen capture utilities that come with PaintShop Pro and CorelDraw. The one in Corel is probably more powerful--more options for capturing specific screen elements like menus and child windows and cursors and so on. It's a stand-alone utility with a taskbar icon and can save images to the clipboard or to disk. However, I prefer the one in PaintShop Pro; it's simpler, with fewer options, but still fairly capable. It pulls images directly into a concurrent session of PaintShop, where you can crop them, enhance them, resize them, and export them in the image format of your choice.
      -Gully
      • utilerU
        utiler
        Cheers Gully where does Alt print screen go when executed? did not work for me.....
        Just Curious...
        • N
          not registered yet
          To the clipboard. Should work. I just tried it.
          -G
          P: Gully Foyle
          • B
            Baker518
            Gai, I have used your method of creating a sphere, your tut is a bit fast on one or two points. My problem is that my sphere keeps coming up with holes in it, top and bottom. What am I doing wrong?
            Don't worry about things you have no control over. Worry is a lack of Faith!
            • GaieusG
              Mike,
              One possible cause is that you are modelling in very small scale. When it comes to millimetres, Su tends not to fill very small faces with the follow me tool.
              Scale your model up by 10 (or even 100) times (depending on the scale), make the sphere and re-scale it to the size you need.
              • B
                Baker518
                Gai, that worked great. Thanks.
                Another question, how did you shift the inference in your tut without moving? Is there a shortcut I missed?
                • GaieusG
                  If you mean the rotate tool, I just place it, click one and before releasing, start pulling in a direction (in this case along the red axis - but it can be any line or guide lie or even a "free" direction). Then release the mouse button (the axis is now closed and won't change) and pick the point of rotetion and rotate.
                  If that's not what you mean, explain, please.
                  • B
                    Baker518
                    That did the trick, much easier than roaming around the screen waiting for it to change then holding down the shift key
                    Thanks....Mike
                    • Mike LuceyM
                      Mike Lucey
                      A, give this little utility a try out,
                      http://toolbox.vmn.net/godownload.php
                      Mike
                      • utilerU
                        utiler
                        Thanks Mike, will give it a chop......
                        A
                        Just Curious...
