    Plugins Drop Down menu is wrong
    20 Posts 7 Posters 2.5k Views 7 Watching
    • philemP Offline
      philem
      HI,
      I Hope you can help me and that this is the right place for this problem.
      I got a new computer over Xmas, have been putting programs back in including Sketchup.
      I have been re-populating the Plugins folder with the scripts I had before and some new ones. Tonight when I opened SU and clicked on the plugins menu the drop down list has changed, (I have attached a screen shot.)
      The house builder, Jim Foltz, Layer Manager, Projection,Scripts,SoapSkinBubble, Balustrade_Components,Bez Patch, Dalauney, Filter, and Util items don't work but all the others do.
      What happened and how can I fix this?
      Thanks in advance
      Philip
      Just do it, it might be fun.
        Did you save your old folder content totally and just copied everything back after installing SU?
        Note that some scripts need other scripts also to work well - as well as some go into the Tools folder.
        I remember something about the sketchup.rb but cannot really remember what the problem was.
        Anyway, I move your topic to the Ruby Discussions for greater attention by the ruby gurus...
        Some screenshots of the content of your plugin folder would be nice, too (the "plural" is for as I can see, one would not be enough...) 😲
        • philemP Offline
          philem
          Thanks Gaieus.
          I did save my folder and tried to copy everything back but the S%*T hit the fan, so I started again, I made a back up as per the instructions for putting in the RUBYSET plugin.
          I have attached the plugins folder screenshots.
            Now I'm not a ruby guru but afaik the SoapSkinBubble should go under the Tools folder for instance. There might be other issues, too - I should check my plugins folder to compare with yours (that will take some time though).
            • CadFatherC Offline
              CadFather
              Hi Philip, some scripts go to the tools folder - if still in trouble, and after looking at the pics i can see you have a messy folder (if such thing can be said for the SU plugins folder!) i would make a new empty plugins folder and place the rubyset contents there, same for the tools folder - then start SU to check for errors and if not start adding your other scripts in the plugins folder.
              • urgenU Offline
                urgen
                Philip,You require and apply all this??? 😲 😲 😮
                --pupil forever...------
                • philemP Offline
                  philem
                  Hi cadfather.
                  You are right, the Plugins folder is a little messy, but there isn't at the moment (as far as I can tell) a ruby that will allow you to make subfolders to put the Ruby's in to keep it tidy.
                  I had made a back up of the Plugins and Tools folders for installing the Rubyset script.So I moved the Plugins and Toold folders to a temp folder, moved the original Plugins and Tools folders back into Sketchup, Started Sketchup and all is back the way it was.
                  Will now start adding scripts as I need them and see what happend from there.
                  Thanks again.
                  • philemP Offline
                    philem
                    Hi Urgen,
                    I understand your question.
                    I am a fairly new user to Sketchup, and visit these forums daily, and reading the Ruby Scripts postings I get the Ruby's that I think will make my learning and usage of Sketchup a more enjoyable experience, BUT, I may have gpne overboard. lol...
                      I have a lot more rubies than I usually need. Whatever I don't use, I just rename the extension of so they don't clutter my Plugin menu that much. When I need them, just rename them back.
                      • philemP Offline
                        philem
                        Sounds like a smart plan
                        • jujuJ Offline
                          juju
                          I suppose you could also use the organizer ruby available from Smustard to help order your plugins.
                            azuby
                            Anybody programming Sketchup extensions should use the Extension class. A good way to program an extension with this class could be: Use a "loader", which should be saved directly to the Plugins / Tools directory. In this file you set up your Sketchup extension. Put your Sketchup extension code to another file in a subfolder of the Plugins / Tools folder. If you would put it diretly to Plugins / Tools, it would be loaded automatically. But with the subfolder and the Extension Ruby class Sketchup can decide whether to load your Sketchup extension. This is needed for extensions, which can be switched on and off via menu "Fenster > Voreinstellungen > Erweiterungen" (should be: "Window > Preferences > Extensions"). Switching off extensions take effect after a Sketchup restart. This way you do not need to edit the file name of the Sketchup extensions as Gaieus mentioned.
                            Code for the "loader":
                            require 'sketchup.rb'
                            require 'extensions.rb'
                            filename = File.basename(__FILE__)
                            if(not file_loaded?(filename))
                              ext = SketchupExtension.new "EXTENSION NAME", "SUBFOLDER/FILE.rb"
                              ext.description = "DESCRIPTION"
                              ext.creator = "YOUR NAME"
                              ext.copyright = "COPYRIGHT"
                              ext.version = "VERSION"
                              Sketchup.register_extension ext, true
                              file_loaded filename
                            azuby
                            *error initus :: Blocks | CurrentDate | d/Code | extensionmanager | FFlipper | HideEdges | MeasuredArea | ModelHistory | PluginsHelp | PronButton | SAWSO | SCP | SU²CATT
                            Bad English? PM me, correct me. :smile:**
                            • philemP Offline
                              philem
                              > end
                              azuby
                              I have great respect and admiration for you (as Gaius put it "Ruby Guru's") and
                              I mean this with the utmost respect, but what is all this in layman's terms, as a fairly new user this seems way over my head, but, if understood, could be very usefull..
                              Philip
                                azuby
                                There's nothing special with programmers 😄 You also can become one of us 😄 Here's your first attempt:
                                Choose one of the Ruby scripts in your Sketchup Plugins / Tools folder, which you do not need often. Copy it to the Desktop (to be able to restore it later). Now create a folder in the Plugins / Tools folder; i.e. the choosen Ruby script was "abc.rb" it's clever to name the folder "abc" Move the "abc.rb" into the new folder. Create a new text file (with Notepad) in your Plugins / Tools folder, maybe "abc.rb", but better "abc_loader.rb" (or "the_simpsons.rb" 😄 ). Copy the code I wrote down to that file AND replace the upper-cased terms. In the "abc" case it could be:
                                  ext = SketchupExtension.new "Philip's ABC Plugin", "abc/abc.rb"
                                  ext.description = "Philip's ABC Plugin is just an example on how to program Sketchup Ruby extensions."
                                  ext.creator = "Philip"
                                  ext.copyright = "Oh well, ask me again in some years..."
                                  ext.version = "47.11"
                                  Sketchup.register_extension ext, false
                                Save the file, (re-)start Sketchup, look into the Preferences I mentioned in my last posting. The "true" / "false" in the third-last line says Sketchup: Do not load this extension by default. So the checkbox for the extension in the Preferences isn't checked.
                                azuby
                                • philemP Offline
                                  philem
                                  > end
                                  azuby
                                  Hi azuby
                                  I had a go at this, (I still have a bit to learn 😄), but I will keep plugin till it sinks in 😄
                                    RickW
                                    There's been some previous discussion on where to load scripts. The previous consensus was to locate things in the Plugins folder, and leave the Tools folder for SU internal files. I understand about the ability to load/unload things using extensions, but it adds a layer of complexity for some users who would be better served with other solutions.
                                    RickW
                                    [www.smustard.com](http://www.smustard.com)
                                      azuby
                                      Well, if you think, renaming script files is more user friendly against a simple checkbox ... go on 😄 (especially for user not beeing admin on their machine). They won't "feel" the "layer of complexity" if programmers would switch-on their -> extensions by default. Using "Tools" and/or "Plugins" folder seems to be a secret of Google and should be less important to users.
                                      azuby
                                        RickW
                                        Just commenting that there had been previous discussion, and what it entailed. 😄
                                        The "other solutions" implied Organizer, not renaming or relocating files. 😉
                                        RickW
                                          azuby
                                          I spoke about Gaieus' idea of renaming files for disabling their contained Ruby plugins some postings before - not about the Organizer (because we know what wents wrong with the Menu class and so on). A Plugins (or Tools) menu with 4711 entries communicates to me: "The user has very, very, very complex modells and really needs all these plugins" or "The user thinks, the plugins might be useful, but he has resigned and accepts, that his Sketchup isn't really slim as it could be" And I think, each developer should care about his "victims" 😉 that they have as much comfort as possible. That's the reason why I support the idea of exceptions instead of having "only" "scripts" Most of our "scripts" are tools and plugins (and all in all: extensions), so we should provide them this way.
                                          azuby
                                            RickW
                                            I don't think we disagree about anything. I may have misread one of your posts, thinking you were saying to put downloaded .rb files into the Tools folder, and that's what prompted my first post here. If you didn't mean to say that, then my comment was irrelevant. 😄
                                            Regards,
                                            RickW
