    Radius challenge
    23 Posts 7 Posters 3.7k Views 7 Watching
      rsw
      @rodentpete said:
      double click the top face, then select follow me and click on the fillet. You'll then have to delete any excess faces around the top.
      Got me thinking now as this doesn't work so well with a steeply curving top surface, a problem I think I've come up against before, like in this .skp:
      http://www.rsw3d.co.uk/sketchup/bevel1.jpg
      and ends up with a bulge like here:
      http://www.rsw3d.co.uk/sketchup/bevel1a.jpg
      I worked out a long way around of getting it how I wanted it, but just wondered how others might do it?
      http://www.rsw3d.co.uk/sketchup/bevel1b.jpg
      Richard
      • chippwaltersC Offline
        chippwalters
        Thanks everyone for the many answers to this. For some reason, the email notifier didn't kick in and I only now went and looked here. I'll check the various techniques out and get back to you!
        Currently working with Cross-Reality technologies
          chippwalters
          Gaieus, what I meant to say was 'fillet'.
          rsw, yes, exactly. How did you do that? When I extrude along the face path, it doesn't close the top of my mouse. Do you hand stitch?
          Pagan, I tried to download your .avi twice, but for some reason my WMP won't play it. Says it encountered an error and had to quit. Some special codec perhaps?
          Rodentpete, I did as you suggested, and now I have the 'fillet' but it's open on the top. Any way to force it to 'skin' the top as well?
            Pagan
            Forget about video,it's look like it's not what you need. 😒
            Just download K-Lite Mega Codec Pack,contain almoust all needed video and audio codec.
              SchreiberBike
              I played with it a little and couldn't come up with any real quick way of doing it. The only thing I did which made it go quicker was to first cut it into quarters and delete three of those quarters.
              Then I made the largest "rib" a component and copied it down the form. I tried scaling each new rib and I tried just moving each rib down to the right level. It didn't make a big difference in the final product. Then I deleted the original object and exploded my new components so I had a wire frame of sorts of the ribs.
              Then I rather than stitch each rib together, I used the "skin.rb" ruby to do the stitching, but doing it by hand wouldn't have taken much longer since the ruby's output needed to be cleaned up afterwards.
              Then copy and scale by -1, put the two quarters together. Repeat that once to connect the two halves and it's done.
                Pagan
                Here,use this if is good to you or rearange it.
                [attachment=0:1wh77c3s]<!-- ia0 -->Untitled.skp<!-- ia0 -->[/attachment:1wh77c3s]
                • W Offline
                  watkins
                  Dear Richard,
                  How did you produce the shape in your third image. Could you put together a small tutorial?
                  Thanks,
                  Bob
                    SchreiberBike
                    @watkins said:
                    Dear Richard,
                    Thanks,
                    Bob
                    I'm not Richard, and he may have a better way, but here's a tutorial on how I did it.
                    It seems amazingly complex when I write it all out, but it was simple and quick enough when I was doing it.
                    Tutorial for the "This .skp"
                      Pagan
                      Hi SchreiberBike,in your tutorial you mention:
                      Explode all the components.
                      Use the Skin.rb ruby to connect the faces and to
                      clean up the excess lines.
                      Could you explaine what you mean and how you do that with Skin.rb ruby.
                      Thanks.
                      http://dhost.info/pagan//emo/004.gif
                        Hi Pagan,
                        Here you can find different versions of the skin.rb.
                        It will alsoput a toolbar onto your work area (you may need to activate it from the View > Toolbars menu). Select either the faces (if you have them) or the lines/edges and run the script. Play with it a little bit until you have a grip on it (sometimes it seems to bee a bit tricky).
                          Pagan
                          [quote="Gaieus"]
                          Thanks,wonderful,didn't know for this.Make easyer a lot's of thing.
                          http://dhost.info/pagan/emo/287.gif
                          • W Offline
                            watkins
                            Dear SchreiberBike,
                            Thanks for for putting together the tutorial. I will have to give it some thought.
                            Kind regards,
                            Bob
                              rsw
                              A quick tutorial on how I created the image in my last post and the first image I posted. This was really just an experiment to see how/if a shape could be chamfered and does not work for every shape.
                              A - Create your basic shape and group it:
                              http://www.rsw3d.co.uk/sketchup/bevel/bevel1.jpg
                              http://www.rsw3d.co.uk/sketchup/bevel/bevel2.jpg
                              you can see in this example there are not all lines carry on across the whole object, thus there are no 'ribs' as in SchrieberBike's example
                              B - Create your radius
                              http://www.rsw3d.co.uk/sketchup/bevel/bevel3.jpg
                              C - Create a flat plane below your object and using the sandbox tools drape your object onto the flat plane
                              Edit: There shouldn't be any need for this step instead keep a copy of the shape of the object when you create it, but this way would be good for more complicated shapes created from lots of intersections etc.
                              http://www.rsw3d.co.uk/sketchup/bevel/bevel4.jpg
                              D - Delete excess geometry, move your created radius down to here and offset the shape inward to the points of the radius
                              http://www.rsw3d.co.uk/sketchup/bevel/bevel5.jpg
                              E - Copy the top of the shape up to the points of the radius (similar to idea as above)
                              http://www.rsw3d.co.uk/sketchup/bevel/bevel6.jpg
                              F - Push pull every other section of the offset shape (step D)
                              http://www.rsw3d.co.uk/sketchup/bevel/bevel7.jpg
                              G - Intersect the shapes created in step E, and then delete the geometry from step F
                              http://www.rsw3d.co.uk/sketchup/bevel/bevel8.jpg
                              H - Delete excess geometry so you are left with the top cap and contours for the chamfer
                              http://www.rsw3d.co.uk/sketchup/bevel/bevel9.jpg
                              I - Use skin.rb to skin the chamfer
                              http://www.rsw3d.co.uk/sketchup/bevel/bevel10.jpg
                              J - Explode all the geometry, soften/smooth edges (its also worth deleting any coplanar geometry to tidy things up a little)
                              http://www.rsw3d.co.uk/sketchup/bevel/bevel11.jpg
                              Heres the model as well bevel.skp
                              Richard
                                chippwalters
                                Wow Richard, that is ingenious. Thanks a bunch for your clear and concise explanation!
                                  rsw
                                  Just been experimenting with this, and it works well for more complicated shapes also:
                                  http://www.rsw3d.co.uk/sketchup/bevel/bevel_complex1.jpg
                                  bevel_complex.skp
                                  This was done the same way as above, except it was rotated so the front face with the bevelled/chamfered edges faced upwards.
                                  Richard
                                  • W Offline
                                    watkins
                                    Dear Richard,
                                    Many thanks for the tutorial.
                                    Regards,
                                    Bob
