    Green Toaster's Car Sketches
    745 Posts 45 Posters 200.4k Views 45 Watching
      GreenToaster
      The other skill set to develop is bringing the images in your head to life (in drawings or in 3D). For some that's easy, because they can "recall" those images very clearly and project those images into their "canvas". So modeling or drawing becomes like tracing. I sometimes have that vision and I can work from that.
      Yes, so true. My favorite illustration instructor when I was in college used to say "If you can't see it in your head you won't see it on paper" - this was before personal computers did CAD, early-mid 80's.
      MZ, I really appreciate your comments, links, and models. I think another missing link is the lack of time I spend devoted to a single project. It's difficult as I have "many irons in the fire", so to speak. I would really love to either find and devote a large chunk of time to a single project - or - pick a project and keep "chipping away" until it's "done" - as another great Industrial Designer from Detroit said "Details are EVERYTHING".
      If you really want something you won't ever stop pursuing it.
        GreenToaster
        The proportions are way off - nose too short, back end too long - many areas are "wrong" but this is a departure for me - a good learning experience. The next one will be better.
        Like my wife said, "Honey, you should remove the blindfold when you draw the next one."
          GreenToaster
          . . . another quickie - just trying something a little different . . . even though I'm not really getting "better" with this, at least I'm still working at it . . .
          • I Offline
            Ivan K
            Hi, I'm new here, stumbled through looking for any more tips to easy smooth edges. I started out with modifying to the point it wasn't the same car as well. I've wanted to be a care designer. I've been modifying the component "Car_Sedan" on the 3D warehouse. I finally decided to stop procrastinating and Use what i knew to make the car more original.
            It takes work to the the curves the way i want them, but I'm looking for new ideas on how to makes even cleaner lines...seems like people are modeling in other programs. I use sketchup from beginning to end. 😒
            BTW GreenToaster i like your seats. Can you tell me how you made them?
              GreenToaster
              The seats were just "eyeballed" - no dimensions just did a quick profile, extruded, chop, pull, done - very quick. Attached is the seat file - I have no idea what the dimensions are - might be "in the ball park"
              seat.skp
              • I Offline
                Ivan K
                cool.
                For shapes other than blocks for cars i just use the sandbox, but Sketchup recognizes gravity and lays the material in only one direction so you have to make multiple parts of the cars.
                Error 404 (Not Found)!!1
                (sketchup.google.com)
                http://img.photobucket.com/albums/v25/BangO/download.jpg
                The curvature of this bumper is smooth, the light seats are what's kind of blocky, but i just made some Contour lines like on a topography plot, and layed them like i wanted to create the bumper. i then turned the bumper upwards, wheel well portion towards the ground, on the Z axis. and applied the material. it draped over fine. a bit of intersect to cut the holes out and that's all she wrote.
                I do fenders pretty much the same way. always lay them down like the ground. so the curvature is similar to a hill or mountain. takes a good bit of practice to find out what works and what doesn't but it's worth it.
                  GreenToaster
                  . . . this opens up a whole new world - I guess it's obvious by my models, I don't use many of the tools & techniques that are available . . . something new to play with! I'm happy!
                  Thanks for the info!
                  • CraigDC Offline
                    CraigD
                    @greentoaster said:
                    The proportions are way off - nose too short, back end too long..."
                    Not for a rear engine sports car! πŸ˜„ I think the proportions are pretty good! ....think Pantera, Ford GT 40, or some Lamborghini's and you'll see these same proportions.
                    Keep at it and enjoy the journey!
                    Cheers,
                    - CraigD
                    Google SketchUp
                      GreenToaster
                      Here's my first ultra-quick attempt using this technique (new to me). I love it - makes me wonder what else have I yet to discover about this stuff - lots, probably.
                        GreenToaster
                        . . . pretty much more of the same . . . I'm doing these much, much quicker than I used to . . . fun!
                        • jenujacobJ Offline
                          jenujacob
                          GT! ur a natural when it comes to doin these!! its been a pleasure seeing ur models!!!
                          would u ever share them with us???? πŸ˜„ πŸ˜‰
                            GreenToaster
                            The last one is 712K - the size limit to upload is ~1/2 GB, so I don't know how to share the files. I've never put anything on the 3D warehouse - is that an option?
                            These files are "sloppy", meaning, I often eyeball stuff instead of using exact dimensions, so, I'm really embarrassed by their "unprofessional character".
                            Can I zip them up and post a zipped file?
                              GreenToaster
                              . . . is there a cure for this . . . could I be addicted to modeling cars . . . this is what I call an 8 minute quicky (imported wheels & tires) . . .
                                jenujacob
                                u can zip them up and post it here... 3d warehouse is also another option...
                                ur cars are cute.. a different genre infact.. πŸ˜‰
                                have u seen this which was posted recently???
                                • boofredlayB Offline
                                  boofredlay
                                  GT, just follow this thread and upload your files to Kelly's server. He has ton's of space.
                                  http://www.sketchucation.com/forums/scf/viewtopic.php?f=77&t=760&st=0&sk=t&sd=a
                                    GreenToaster
                                    I followed the link but it provided a message indicating the service was no longer available.
                                      boofredlay
                                      Ahhhh, a link that did not get updated. That first link in the topic went to a page on the old board. I updated it, now have a go.
                                        GreenToaster
                                        Okay, I'll try zipping them up and posting them at another place - I don't understand how to follow the directions - create a new network blah, blah, blah.
                                        Here's another experiment . . . didn't turn out very well . . . good learning experience though . . .
                                          boofredlay
                                          @greentoaster said:
                                          • I don't understand how to follow the directions - create a new network blah, blah, blah.
                                          I don't know why but that just made me crack up. πŸ˜†
                                          Why don't you think your latest did not turn out that well. You got those fenders smooth man. Keep movin' on πŸ˜„
                                            GreenToaster
                                            . . . practice doesn't make perfect, practicing it the right way makes perfect . . . at least, that's what I always tell my students . . .
                                            With no pun intended, I feel like I'm just spinning my wheels, making no progress - although - I did learn something really cool today and hope to be using this newfound technique often (dragging vertices (sp?)) . . .
                                            • 37
                                            • 38
                                            • 1 / 38
