    Material Attributes
    14 Posts 7 Posters 2.6k Views 7 Watching
    • Al HartA Offline
      Al Hart
      I finally got around to trying to store some attributes on a material. It worked fine for attributes in my model, but when I saved the attribute as a material and tried to reuse it the attributes were lost.
      [Note: I added some additional detail to this posting after it was originally posted.]
      Here is a Ruby script to place some attributes on a material.
      def test_atts
      		model = Sketchup.active_model
      		material = model.materials[0]
      		material.set_attribute("dict1","att11","value_11")
      		material.set_attribute("dict1","att12","value_12")
      		material.set_attribute("dict1","att13","value_13")
      		material.set_attribute("dict2","att21","value_21")
      		material.set_attribute("dict2","att22","value_22")
      		material.set_attribute("dict2","att23","value_23")
      		material.set_attribute("dict3","att31","value_21")
      		material.set_attribute("dict3","att32","value_22")
      		material.set_attribute("dict3","att33","value_23")
      	end#def
      I can fetch the attributes just fine from the Material in SketchUp:
      But when I load that material into another model and place it on a face, the attributes are wrong.
      Here is the XML code for the attributes from the saved material.
      (This is extracted from the .SKM file saved by SketchUp using WinZip.)
      (They are correct. So I presume SketchUp is not reading these properly when it saves the materials.)
      - <n0;AttributeDictionaries count="3">
      - <n0;AttributeDictionary count="3" name="dict1">
        <n0;Attribute key="att11" type="10">value_11</n0;Attribute>
        <n0;Attribute key="att12" type="10">value_12</n0;Attribute>
        <n0;Attribute key="att13" type="10">value_13</n0;Attribute>
        </n0;AttributeDictionary>
      - <n0;AttributeDictionary count="3" name="dict2">
        <n0;Attribute key="att21" type="10">value_21</n0;Attribute>
        <n0;Attribute key="att22" type="10">value_22</n0;Attribute>
        <n0;Attribute key="att23" type="10">value_23</n0;Attribute>
      - <n0;AttributeDictionary count="3" name="dict3">
        <n0;Attribute key="att31" type="10">value_21</n0;Attribute>
        <n0;Attribute key="att32" type="10">value_22</n0;Attribute>
        <n0;Attribute key="att33" type="10">value_23</n0;Attribute>
        </n0;AttributeDictionaries>
      I saved the loaded material and looked in its XML file and the attributes were messed up.
      (The material was loaded and saved using the SketchUp Materials Window.)
      - <n0;AttributeDictionary count="1" name="dict1">
      Has anyone else run into this?
      SketchUp - are you working on a fix?
      Al Hart
      IRender nXt from Render Plus
      • Didier BurD Offline
        Didier Bur
        How do you export the XML code for the materials ? Maybe it's in this process that there is something wrong ?
        DB
        • AdamBA Offline
          AdamB
          FWIW I use attributes on materials and it "works-fine-for-me" (tm)
          ie Attributes getting serialised works fine - so I agree with Didier, I'd revisit your processing code.
          Adam
          • Al HartA Offline
            Al Hart
            Thanks for the response.
            I go to the SketchUp Material Window and use Save As, and then view the XML after loading the .SKM file with WinZip.
            The .XML is not part of the process, I was just using it to see if SketchUp had saved the attributes materials properly.
            Note: This is not a problem creating materials and saving them into the.SKP file. I wanted to be able to put Attributes on a material, save it in a library, use the material in a different drawing and have the attributes still be valid.
            Here is the process:
            1. Select a SketchUp Material and place it on a face.
            2. Place more than 1 attribute directly on the material.
            3. Use the SketchUp materials window to save the material as a .SKM file.
            4. Start a new SketchUp session and a new drawing.
            5. Select the .SKM material with the SketchUp materials window
            6. Query the material to see if the attributes are still set.
            If you can do all this, I would love to have the .SKM file for the material, and also a new model with a single face in which you have placed the material.
            This would be a great help for me if we could get it to work.
            Al
            Al Hart
              avariant
              Sorry for digging up an old post, but I can't find anywhere the answer to the question posed here, the question I need answered as well.
              When you apply attributes to a material, and save that material as an SKM, the attributes are saved correctly. If you rename the SKM as a zip and examine the document.xml, the attribute dictionaries are all listed, all correct.
              But when you load that material into a new scene and apply it to a face, the attribute dictionaries are not restored correctly. What I've observed is that the number of dictionaries is reported correctly, but each dictionary reports it's name and keys/values as those stored only in the first dictionary. That you get multiple dictionaries with the same name seems a bug straight off the bat. Shouldn't all attributes with the same dictionary name be stored in a single dictionary? I suspect this is a Sketchup bug in loading the attributes from the SKM. Does anyone have any info about this?
              • Al HartA Offline
                Al Hart
                Yes. This appears to be a SketchUp bug. Attributes and Attribute Dictionaries stored on materials are not saved properly in the SKM file and/or not reloaded properly.
                Al Hart
                  avariant
                  Ok. Has this been reported to SU as an official "bug"? It would be very nice to get it fixed some day.
                  • Al HartA Offline
                    Al Hart
                    I didn't report it.
                    I suppose I hoped hey might read these threads.
                    Also, has anyone ever reported a bug and felt that the report had anything to do with the final resolution. Especially a bug like this which does not effect almost anyone? (Except we Ruby programmers who want to store attributes on materials and be able to save and reload them).
                    Al Hart
                      dburdick
                      The problem/bug of saving multiple material attributes with a material is still there but I found a workaround. It seems that the saved .skm material file when loaded will only retain a single attribute parameter. So I packed all the material params into a single string using a single parameter and then saved the material. If I need to do anything with the material attributes, I unpack them into Sketchup attributes at run-time. Kind of a kludge, but it works.
                      • Al HartA Offline
                        Al Hart
                        That will work in some cases, and is a clever solution.
                        One of the things we are trying to do is save multiple images with a material - e.g. a bump map and specular map - in addition to the diffuse map. First we have to convert the binary to ASCII because SketchUp does not handle binary attributes properly, then we run into the problem that SketchUp can only handle about one megabyte (I don't remember the exact limit) per attribute, so we split large images up into several attributes.
                        Al Hart
                          there's a attribute size limit? hm... that would have been useful info to have seen in the manual.
                          binary to ASCII? you mean base64?
                          • Al HartA Offline
                            Al Hart
                            We use HEX sometimes and Base64 sometimes.
                            Try this little example:
                            def test_att(size)
                            	test_string = "A"*size
                            	printf("size; %s test_string.length; %s\n",
                            		size, test_string.length)
                            	model.set_attribute("test_string","test_string", test_string)
                            	test_string2 = model.get_attribute("test_string","test_string")
                            	printf("size; %s test_string.length; %s test_string2.length; %s\n",
                            		size, test_string.length, test_string2.length)
                            end#def
                            If you load it and type in:
                            test_att(100) - works
                            test_att(100000) - works
                            test_att(1000000) - works
                            test_att(2000000) - dumps core
                            Al Hart
                              dburdick
                              Al, are you implying that you've found a way for Sketchup materials to load with multiple attributes attached? If so, can you share the magic of this invention.
                              • Dan RathbunD Offline
                                Dan Rathbun
                                for SketchUp 2017
                                (https://help.sketchup.com/en/article/141303)":2kct16r6]
                                Fixes/Improvements General
                                SketchUp API Release Notes
                                • (Mac) Fixed issue where SKM files lost attribute dictionaries when saved from ā€˜In Model’ to local library.
                                I'm not here much anymore.
