    [SKM Bug]Material attributes within SKM files
    11 Posts 6 Posters 2.2k Views 6 Watching
      tomasz
      Whaat I have tried to answer your question at GG (!Β£Censored to protect your privacyCensored to protect your privacy"Β£!) but THEY HAVE LOCKED IT. I have received a message saying 'you cannot reply to this message.' !!!!
      So I will do it here! 😑
      On Mar 26, 11:25 pm, whaat wrote:
      Still haven't found the answer to this question. Can someone from Google look into this?
      They don't care about freeware exporters.
      I have tried to save my attributes assigned to the material. What I have found that SU saves attribute but without content...
      Skm files are zipped XML files + PNG as a thumbnail.
      In rhe document.xml you can find:
      <mat:material colorBlue="64" colorGreen="64" colorRed="64" colorizeType="0" hasTexture="0" name="Silver" trans="0.5" type="0" useTrans="0" xmlns:n0="http://sketchup.google.com/schemas/1.0/types">
      <n0:AttributeDictionaries count="1">
      <n0:AttributeDictionary count="1" name="su2kt">
      <n0:Attribute key="kt_mat" type="11"/>
      </n0:AttributeDictionary>
      </n0:AttributeDictionaries>
      </mat:material>
      There is no CONTENT although attribute has been saved.. <n0:Attribute key="kt_mat" type="11"/>
      We could add manually the content but I don't know how and it is not easy inside zipped file...
      Should it look like:
      <n0:Attribute key="kt_mat" type="11" value="Greeting from KT-team"/>
      Cheers
      Tomasz
      http://www.sketchucation.com/forums/scf/sas/Ruby/GoogleG.png
        Tomasz,
        GG automatically locks topics that haven't been "active" (replied to) for 30 days. I have no idea why...
        • KrisidiousK Offline
          Krisidious
          well we won't lock your topic... Promise! we'll even Bump it.
          By: Kristoff Rand
            Jim
            Hmm, I thought I answered a similar post (from you?) many months ago. I experimented with assigning attributes to materials. If I remember, I was able to do it.
            And if I also remember, it didn't work for you?
              tomasz
              Kristoff, thanks for bumping πŸ˜„
              Jim, it was Whaat who was looking for solution. Now I have tried as well to attach attribute dictionary to a material AND saving it to SKM file. As provided sample shew the attribute distionary "su2kt" was saved but the "kt_mat" key was empty.
              Tomasz
              • W Offline
                Whaat
                Tomasz,
                Thanks for looking into this (although I know if this problem can be solved, it will benefit both of us πŸ˜‰ ). I have given up on this at the moment although if there is an easy solution, that would be great!
                Right now, material properties for SkIndigo can be saved as IGM files which can be loaded back into SketchUp fairly seamlessly. This file format also has the advantage that it can be imported by other programs like 3DSmax.
                I still don't understand how Jim can get the attributes to save but we can't. Hope you can help us with this one, Jim! Thanks!
                  Krisidious
                  theres Whaat... I knew he was around here somehwere.
                  By: Kristoff Rand
                    gata
                    At the moment, there's a 60 day thread posting period at GG forums. That annoyance is on a list of things to fix for the SU forum.
                      tomasz
                      Gata, thanks for info.
                      I have done a test and simple attributes are being saved!
                      <n0:Attribute key="kt_mat" type="10">Test</n0:Attribute>
                        <mat;material colorBlue="0" colorGreen="0" colorRed="0" colorizeType="0" hasTexture="0" name="New" trans="0.5" type="0" useTrans="0" xmlns;n0="http://sketchup.google.com/schemas/1.0/types">
                          <n0;AttributeDictionaries count="1">
                            <n0;AttributeDictionary count="1" name="su2kt">
                              <n0;Attribute key="kt_mat" type="10">Test</n0;Attribute>
                            </n0;AttributeDictionary>
                          </n0;AttributeDictionaries>
                        </mat;material>
                      It looks we have to translate all unprintable characters into \nn form ( string.dump ).
                      I will let you know about success or failure πŸ˜„
                      Tomasz
                        Krisidious
                        looking forward to knowing more...
                        By: Kristoff Rand
                          tomasz
                          Here are my findings in relation to attributes assigned to the SKM file:
                          • SU will not save an attribute containing an array or hash
                          • SU will save multiple keys within single attribute dictionary .. but will load only first! 😞
                          In attached sample there are three keys saved:
                          <n0:AttributeDictionary count="3" name="su2kt">
                          <n0:Attribute key="kt_lib_path" type="10">TEST1</n0:Attribute>
                          <n0:Attribute key="kt_map" type="10">KT MAP</n0:Attribute>
                          <n0:Attribute key="kt_mat" type="10">KT MAT</n0:Attribute>
                          but only first kt_lib_path will be loaded 😞
                          I am afraid only a fix from Google would help.
                          Tomasz
                          http://www.sketchucation.com/forums/scf/sas/Ruby/Silver.zip
