    Change default material
    5 Posts 2 Posters 958 Views 2 Watching
    • BurkhardB
      Burkhard
      It is possible to change the default material of the box within this script to opacity 30% automaticly?
      ...and set the value for the z-axis to -10cm
      Burkhard
      box_pos.rb
      http://www.ia-plus.de
        @burkhard said:
        It is possible to change the default material of the box within this script to opacity 30% automatically?
        Burkhard
        values = [100.cm, 100.cm, 100.cm, 0.cm, 0.cm, -10.cm]
        new_material=model.materials.add("Burkhard_Material")
        new_material.color=[128,128,128] ### a mid-grey, adjust to suit...
        new_material.alpha=0.5 ### 0.5=50%, 1=opaque
        entities.each{|e|e.material=new_material if e.typename=="Face"}
        • BurkhardB
          Burkhard
          Thanks TIG,
          but there's no change in the prompt box. I'll set the value to -10
          and the box dimensions to 3oo. The prompt window shows default settings : 100 and 0.
          ... and where do I have to copy these new material files. My tries show no results.
          thanks again Burkhard
            @burkhard said:
            Thanks TIG,
            Here's a 'tweaked' version of the script. Read the ### parts to see what I've done. I added the material part in near the end after the faces are made, AND made the 'def' within a 'Box' class and then split the dialog variables as @xxx so they are defaulted at the first go but they are then remembered as last set during that session.
            box_pos[1].rb
            • BurkhardB
              Burkhard
              Works well here.
              Thanks a lot TIG. These credits are yours πŸ˜‰
              Burkhard
