    Cedar shakes on a wall
    7 Posts 3 Posters 3.0k Views 3 Watching
      rhankc
      does anyone have a cedar shake pattern or material for a wall application?
      Hank
        rhankc
        Yes James, Thank you , I try to keep a camera with me these days but I havent made any pics of shakes. this is a good start.
        Hank
          mike d
          here is another one
          http://www.sketchucation.com/forums/scf/sas/Components/roof1(HAWTHORNE).jpg
          The grass is always GREENER on the roof.
            rhankc
            thanks to you too, Mike.
            Hank
              rhankc
              OK guys, I have these made these into a material, and they will apply . I cant get the size of them to change before applying to a surface, James shingle is 2"w x 2 3/4" high, and Mike's shingle is 3/4"x1". When I change them is SU with the scale tool, I get a larger area of the small shingles.
              Will someone give me a hint? Do I have to change the image size in jpg properties? Thanks
              Hank
              • KrisidiousK Offline
                Krisidious
                select the material in the material browser
                then selcet the edit tab, here you can edit the size and distortion and the color hue of the image... as well as some other things...
                By: Kristoff Rand
                  rhankc
                  Thanks Kris,
                  I was scaling the individual shakes to about 10" x 7" and the original image didn't seem to be changing, but scale the original image x 10 and... life is good. thanks
                  I appreciate all the help and time.
                  Hank
