    SketchyPhysics Alpha
    90 Posts 26 Posters 27.1k Views 26 Watching
    • N Offline
      not registered yet
      @cphillips said:
      Hey Chris, where can I download SketchySolids Toolbar and how do I drag objects? I ot a LOT of trouble with that.
      SketchySolids is part of SketchyPhysics.
      There are instructions and a tutorial on dragging on the homepage:
      Error 404 (Not Found)!!1
      (code.google.com)
      I got this really bad error here. Can you help me?
      Invader Zim
        CPhillips
        That picture is almost unreadable. But I think the problem is you don't have the files in the right place. Follow the instructions here:
        http://code.google.com/p/sketchyphysics/wiki/LatestVersion
          Masta Squidge
          If the "staticmesh" creates an object that followed the actual geometry of whatever it is, wouldnt it make sense simply to make all objects mesh objects though not static?
          wouldnt that do away with all the work of having to change each item, and fix the problem with making a closed torus into nothing more than a cylinder from the viewpoint of the program?
          Im sure there is a reason for it, but wouldnt it be easier to work with if all object were made as "mesh" objects that follow the geometry of the item, then you would only need to assign static, frozen, or ignore values to each item.
          Also, as was posted before, pressing "Ctrl-Z" while in a simulation causes objects to "explode" and move around the scene. Its not easy to fix.
          AND, sometimes when i make a floor when the "default" scene is acticve, then delete the default floor to play with the four objects, after they go out of the boundary of the default scene floor, they drop through the newly placed floor (yes its a solid object) while items i have made have no trouble with it at all.
          All in all, very nice work.
          Oh, and by the way:
          Hi guys!! Im new here (obviously) and am currently in the process of being miserable with this plugin, and the two videos i have seen on it dont teach me anything more than how to place a hinge and stack up objects during a simulation.
          If anyone would like to perhaps give me a hand with this, i would be grateful, as any "tutorials" that i find dont really teach me anything.
            CPhillips
            Sorry, I just noticed this post.
            The problem with "static mesh" objects is they can't move. That is why all the other shapes exist. The closest to what you suggest is "convex hull". But it isnt perfect and a lot slower.
            I fixed the ctrl-z problem in the next version due in the fall. Ill look into the other bug.
            As for tutorials: I haven't updated the ones on the website because most people are posting models to 3dwarehouse.
            http://sketchup.google.com/3dwarehouse/search?q=sketchyphysics&styp=m&scoring=d
            You can also ask for help in the SketchyPhysics forums:
            http://groups.google.com/group/sketchyphysics/topics
            Oh, and by the way:
              Masta Squidge
              Thats why I mentioned the idea of making a "Mesh" option to go along with static mesh. While Static Mesh is, well, static, Mesh would not be static.
                CPhillips
                Ah. I didn't write the physics engine (Newton). I just wrote the part that connects it to Sketchup. Newton doesn't support dynamic meshes to keep it fast.
                • N Offline
                  namza
                  look at this one !
                  http://sketchup.google.com/3dwarehouse/details?mid=3033656328c1e705ca614abb1a17f2c8&prevstart=228
                    bellwells
                    namza,
                    WOW. I love that you can rotate the image during play.
                    Ron
                      Masta Squidge
                      I think i downloaded the wrong one... The only link I found seems to have no mention of any sort of new cool things. This (the one i downloaded) seems to be the same as what I had before. 😳
                      Can anyone lend a hand?
                      • boofredlayB Offline
                        boofredlay
                        @namza said:
                        look at this one !
                        Now that is cool.
                          CPhillips
                          New version is still a month or so away.
                            Masta Squidge
                            Oh... well how do I get the alpha? Or can I not because Im not in a certain group?
                              CPhillips
                              The last release was Jul 7. Its here:
                              http://code.google.com/p/sketchyphysics/downloads/list
                              I noticed when I went to find the link that is has been downloaded over 24,000 times. When I was writing it I was thinking I would be lucky to get a few hundred. 😄
                              • AdamBA Offline
                                AdamB
                                re: weighing stuff.
                                In the past I've had some good success using Physics systems by calculating the volume of an object and using some density parameter to figure some mass. The volume of a closed object is as I describe in this thread:
                                404 Not Found
                                (www.sketchucation.com)
                                I used to figure density from the materials the object used (which tended to be correct as they're often used to drive sound / particle-puffs on collisions.
                                • E Offline
                                  eldar
                                  hi! i was wondering if there's a way to lock the pose in SketchyPhysics, maybe with an example i can explain myself (english is not my first language) i downloaded the model of the robot arm, open the model, push the play physics button and start to move the fingers and made a cool pose, but when i finish and use others sketchup buttons the pose is lost, my question is: there is a way to not lose this pose or save it, stay with the worked pose and continue working with the tools of sketchup, draw something, etc? (maybe save in a layer?)
                                  This is very important also in my work as an architect to design solar protection windows and stuff like this. Amazing tool by the way, thanks!!
                                    Julius
                                    i don't think so...anyway wait for CPhilips'answer.
                                      CPhillips
                                      I understand. That should be possible. Ill add it to my list.
                                      You could do something similar now if you take advantage of a bug. Just save the model while the simulation is running. It will save it in the posed position.
                                      • E Offline
                                        eldar
                                        CPhillips thanks for considering the idea and sorry for my late answer, as you said save the model is the solution, for me this open a lot of new possibities like make a simple skeleton to a design character and pose the figure in contex to make a draw... all inside sketchup instead to learn and buy poser (i know poser is a much more powerfull program but it's only for this then i needed)
                                        ...one more question is in yours planes to add a feature to make the sketchyphysics an executable? (.exe) something like blender with his gamengine, it will be very cool to have a feature like that, view and walk to the model from a human point of view, open doors with the sliders, jump to a selected scene, all of this without the possibilty to edit the model. this two tools will combine perfect with this idea: a bake ligth tool inside sketchup http://www.youtube.com/user/adambillyard and a video texture http://www.youtube.com/watch?v=rfr8cLZNvWg
                                          StarWarsKnower
                                          Hey, just an idea for the next SketchyPhysics, (love the boyancy by the way), could you make it so you make a line and the object attatches itself to that line. You can click and drag it to move along that line. I mean like a slider, except you can make the line bent and curved. Or the same but more like a piston where you can choose how far along the line your object is. Good luck with the next SP, and I hope you take my idea into consideration.
                                          Also, my dad is from ImaginationTechnologies, and is working on a 3D chip at the moment, and he loves your work.
                                          Thx
                                          StarWarsKnower 😉
                                          Mike
                                            CPhillips
                                            Sorry for the delay, I just noticed this post.
                                            I would like to do a joint like you describe. It would make a LOT of things possible. I have tried a few times but haven't figured out how to make it yet. Its a bit more complicated than it sounds.
                                            Thx
                                            StarWarsKnower 😉
                                            • 4 / 5
