    Printing lines
    scheduled pinned locked moved Newbie Forum
    20 Posts 5 Posters 3.0k Views 5 Watching
    loading-more-posts
    • oldest-to-newest
    • newest-to-oldest
    • most-votes
    reply
    • reply-as-topic
    guest-login-reply
    deleted-message
    • Larry BatesL Offline
      Larry Bates
      New here. Have been using sketchup, or rather learning SU for the past few months. I am a freelancer, again. So I have no experts to help. That's why this forum is so great.
      Ok, now my question. I am trying to print a copy of my model, and some lines won't show. I have saved the model as a view in SU, and exported it as a 2D image saved as a .jpeg. How do I get all the lines to print? I have the styles for lines set to 1 . Thanks.
      Larry πŸ˜’
      one-reply-to-this-post last-reply-time reply quote 0
      • KrisidiousK Offline
        Krisidious
        we'd really need an example of the model... upload your jpeg and show us what is not showing and we can explain.
        By: Kristoff Rand
          Larry Bates
          ok, I'll do so in a while. Thanks/
            Larry Bates
            Ok,
            I'm really inept, how do I upload the file as a link? as it is 5 thou plus KB.
            Larry
              Krisidious
              well just size it down for us to look at... it should keep its form well enough.
              By: Kristoff Rand
                Larry Bates
                do you want the skppy or just the jpeg?
                  Krisidious
                  jpg of the view you're having issues with... crop it if need be to get close...
                  show us what you are not seeing or where you are not seeing it.
                  By: Kristoff Rand
                    Larry Bates
                    ok, this is the jpeg version
                    hang on resiizng
                    http://www.sketchucation.com/forums/scf/sas/Newbie/CopyofUnionParkCompetitionMedium.jpg
                      Larry Bates
                      left face of the tower, floor lines are invisibel above the podium level....If you look closely you can see the endpoints on the corners....
                        Krisidious
                        are those lines on the outside face of the structure?
                        or inside on another face?
                        do you have the "View>Hidden Geometry" check marked?
                        By: Kristoff Rand
                          Larry Bates
                          I don't know, I will have to check it and get back later. I am just going to PS the lines in so I can print it out. But I will need to rectify this for the future. Thank you for your help Krisidious. I really appreciate it. the lines appear to be on the face, but maybe I don't have something set correctly. the walls don' t have thickness, I'm just doing a simple model to use for a perspective guide to do a rendering of.
                          Larry
                            Krisidious
                            play with the settings under "View" things like
                            hidden geometry
                            edge style
                            let us know...
                            By: Kristoff Rand
                              Larry,
                              Are you using the default style or any of those "fancy" ones (like sketchy edges, straight lines etc)?
                              These latter ones tend to hide some of the lines when there are too many of them. If this is the case, change to default style and try to render your image that way to see if there is a difference.
                                Larry Bates
                                hidden geometry
                                edge style
                                let us know...
                                tried that, no better
                                  Larry Bates
                                  @gaieus said:
                                  Larry,
                                  I may have the straight lines on at 1 pixel. I'll give that a go and go back to the default.
                                  Thanks Gaieus, and once again Krisidius also.
                                    Ross Macintosh
                                    Hi Larry
                                    Addressing your problem requires some background info so you can understand what is happening. Sorry if I'm a bit long winded but without some of this background understanding how to get good exports is difficult.
                                    In SketchUp v6 we have two fundamentally different ways to have edges rendered. By default, vector (mathmatically defined by SketchUp's program code) edges are applied. Up until version six those vector edges were the only choice. With version six came a new technology that SU's developers call 'Sketchy Edges'. With them the edges may or may not actually be sketchy and that adds to the confusion. What 'Sketchy Edges' is all about is having edges defined not by vectors but by bitmapped sets of images. The program will in effect use a image of line (and that image can be "sketchy" or not) and use it to display an edge. The system is smart enough to be able to use sets of images showing lines of different lengths and apply them to the image appropriately enough that short edges get displayed with short images and with enough variation that the end effect can really look like it was, say, hand drawn.
                                    SketchUp v6 uses the concept of "Styles" as a way to apply edge and other display-related effects. It is important to understand that the Styles are just a way to allow us to bundle together, reuse, and share particular sets of settings. An individual Style definition may or may not use the image-based 'Sketchy Edge' system. Some are defined with the default vector edges.
                                    Now just to be clear, understand that when vector-based edge display systems are used the approach is really resolution independant as far as the program is concerned. It simply draws lines from endpoint to endpoint. In contrast the 'Sketchy Edge' system is very resolution dependant. Within a Style that has the Sketchy Edges, a set of 'line' images is used. If that particular Style incorporates 15 different 'line' images in it, then the program must render the visible edges in model view using just those images. SketchUp's system for doing that is actually quite sophisticated. It will shrink and stretch those images automatically and generally try to apply the most appropriate image from the set for a particular edge. Now of course it can't actually see the images and so all of this is done automatically using algorithms in the program code.
                                    There are limitations to the system. The big one relates to resolutions. It makes achieving WYSIWYG (what-you-see-is-what-you-get) output difficult. An important aspect to understand is that what you see on your monitor has been processed by your graphics card while what you export doesn't use the graphics card at all -- exports are generated by the SketchUp software. Many users have a tendency when they export an image to assume higher resolution is better and so they crank up the pixel size of their exports using SU's export options. When the 'Sketchy Edge' system is involved the results stop being wysiwyg. The higher resolution means the algorithms are recalculating what 'line' image to display for what edges differently than was done when the display view was originally generated. Hence an export can look different than what we saw on our monitors.
                                    I actually over-simplified the above explanation. The system also has features like applying 'halo', level of detail, profiles, and edge extensions -- things that all have some aspect of being resolution dependant in how they are applied. It is also noteworthy that even before Sketch Edge technology was added in v6 that there have always been differences between exports and what we see on our monitors whenever the resolutions involved are different.
                                    Now for some advice... (finally)
                                    If you want an image that matches what you see on your monitor the best choice is to do a screen capture. You can use the utilities built into your operating system or stand-alone screen-capture software. Some of you will be saying "but Rossy I need higher resolution!" In that case I'd highly recommend you do your screen capture and then use PhotoZoom Pro2 to effectively improve the resolution of your screenshot. (PhotoZoom is available for macs & pc's and is a very useful graphics tool).
                                    You can also try exporting from SU using the "use view size" option although I've found the results less satisfactory than doing screenshots. In my work designing Styles for distribution by FormFonts I have found that the only predictable output is via screenshots. Some styles will export more faithful to what you saw on your monitor than others - but screenshots always seem to work. Crank up your monitor to its maximum resolution and take your screenshot.
                                    In conclusion I'd note to Larry to realize that his use of the '1 pixel' style is in fact using the Sketchy Edge system. If he was using a vector-based edge like is used in SU's "default styles" then he might not have the same export problems.
                                    Regards, Ross
                                      Larry Bates
                                      THANK YOU ROSS!
                                      Now, I know. Your explanation was just what I needed. I did in fact go to the default style, and the wayward lines reappeared automagically. Although not satisfactorilly.(sp?) Of course, now that you say 1 pixel line it makes sense that it is not vector based. Thank you all for taking the time to help me. You guys are great.
                                      Larry
                                        rollin45
                                        Outstanding explanation!!
                                        Clears up a lot of things for me as well. Thank you for the time and effort.
                                        best
                                        rollin'
                                          Krisidious
                                          damn fine Ross... thanks for the extra effort.
                                          By: Kristoff Rand
                                            Ross Macintosh
                                            You are most welcome guys.
                                            Regards, Ross
                                            • first-post
                                              last-post
