Component edit - hide/unhide toggle button?
Is there a faster way to access the "hide/unhide rest of model" while editing component function than to go through the menu?
I switch back and forth often and it would be nice to have a toolbar button or keystroke command to toggle this option.
ummm im not sure if i get what u mean but this is what i interpret your question as:
you can edit the shortcuts to work for you, for instance i use....to hide = ctrl + h
to unhide last = alt + h
to unhide all = ctrl + alt + hthis i find is a good basis for hiding/unhiding easily but its all down to personal preference
(keyboard shortcuts can be editted in
Windows>preference>shortcuts -
Thanks, that offers the simple solution to my question.
What I was referring to specifically was the "view/component edit/hide rest of model" command, and I see that I can assign a key to toggle this feature as well.
Thanks again.
I use "N" for mu shortcut. Why N? It was the next letter on the bottom of my keyboard not in use
I use it constantly.
