    Ruby scripts
    6 Posts 4 Posters 1.4k Views 4 Watching
      jhenry
      About ruby plugins? I am having no luck installing them. Do I need a ruby downloader? Such as ruby on rails. I followed the tutorial for loading but doesn't seem to be happening. How do I verify? Thanks for help
      James the "newbie"
        todamgood4U
        You just put the ruby in the C:\Program Files\Google\Google SketchUp 6\Plugins and then restart sketchup. They should appear in a drop down menu from top or right click depending what they are.
          jhenry
          Thanks for reply. I really need the make faces script but it won"t load. doses progressbar need to be loaded first?
          James
          • boofredlayB Offline
            boofredlay
            James, some of the scripts show up in the Plugins dropdown, others in the Tools dropdown and yet others are "right click" tools.
            The Makefaces is in the Tools Dropdown. Select your lines then go to Tools and you should see it there. At least that is where mine is.
            Hope this helps. 💚
              jhenry
              Thanks Eric, I,ll keep looking
              James Henry
              • E Offline
                ehaflett
                James, if you're getting an error about the progress bar when you run a script you may want to download the progressbar.rb script and put it in your scripts directory with the rest. I noticed a couple scripts that I downloaded from smustard.com use it.
