    Ruby Tutorial: How to create and add a component from Ruby
    15 Posts 7 Posters 9.4k Views 7 Watching
      lewiswadsworth
      @gaieus said:
      Seems to me that maybe we should create a "Ruby tutorial subforum" here.
      Thanks Todd!
      I agree...that would deal with a great many of the problems that new users have with rubies. The available Ruby texts you can buy do not deal with the implementation of Ruby in SketchUp.
      --Lewis
      [Lewis Wadsworth]
      col sporcar si trova
        tomot
        I find these little "Ruby snippets" very helpful. they are a great way to learn to code in Ruby.
        I have another idea for a snippet. Using the Cube as a basis that Todd started with above.
        How do I code a radial array of cubes about a central point?
        tia
        [my plugins](http://thingsvirtual.blogspot.ca/)
        tomot
        • TIGT Online
          tia
          Look into my "Grow.rb" script to see how to do all types of matrix arraying etc - Move, Rotate and Scale of copies...
            tomot
            I revisited the Cube this afternoon:
            I added a dialog box, 2 sub-menus.
            One for a component cube, the other
            for a grouped cube. Then added some color
            and transparency statements.
            Thanks TIG I will have a look at grow.rb
            btw: using the component cube first , followed by grow.rb
            and then changing any component cube creates some interesting effects.
            Box0.rb
            tomot
              tomot
              I'm still doing some further investigating into components used in Ruby
              The attached Ruby could produce 2 options for component editing, by adding a sub menu.
              What works now is that each component in the group can be edited on its own
              What does not work!
              Editing one component in the group , and had have the other 8 follow the same editing changes.
              I hope someone can have a look at the code, I cant seem to find the right component code lines.
              tia
              Box4.rb
              tomot
              • TIGT Online
                If you make a component and place it several times then anything you do to one instance affects all of the others - unless you use 'make_unique' on it first. Using groups and copying them avoids this, BUT a recently noted but undocumented quirk in the SUp Ruby coding means you must use 'make_unique' on a group as you copy it... otherwise that copy is treated as an 'instance' (just as if it were a component anyway !!!) and then both might change as you alter one...
                  tomot
                  I'm wondering why you would suggest Make_unique
                  I was copying similar code from JoistTool.rb which allows for
                  component editing of the type I'm looking for.
                  Yet JoistTool.rb does not contain any Make_unique code.
                  I'm wondering if the Upto statements are causing a problem?
                  tomot
                  • TIGT Online
                    But the Joist and Rafter tools make a component that is repeatedly copied AND if you subsequently edit one of them then they all change ! If you want parts that are unconnected then use Groups - but make each unique - as I said within a script they can be viewed as clones of the same thing and they'll edit together, but doing an edit in the "real world " has each of them treated as a single entity...
                      tomot
                      OK, I really don't understand at this point how or where I'm going to introduce make_unique, into my existing script. I have the following inserted before the 1st upto statement
                      definitions = model.definitions
                      component = definitions.add
                      entities = component.entities
                      followed by:
                      trans = Geom::Transformation.new
                      entities = model.active_entities(component, trans)
                      after the cube has been drawn
                      What I cant wrap my head around is:
                      Both my script, Box4.rb and JoistTool.rb create copies of 3d entities.
                      JoistTool.rb uses t=Geom::Transformation.translation to make copies
                      while, Box4.rb uses Upto to make copies.
                      Obviously these copies are treated differently in Ruby?
                      causing JoistTool.rb work, and Box4.rb not work?
                      (I'm sorry for my thick head)
                      tomot
                      • TIGT Online
                        Try using groups as an alternative...
                        entities=model.active_entities
                        group=entities.add_group
                        gents=group.entities
                        gents.add_line(pt1,pt2)
                        gents.add_face(pt1,pt2,pt3...)
                        etc, all made inside the group NOT model
                        then transform group etc
                        group1=group.copy
                        group1.make_unique
                        transform group1 etc
                          tomot
                          I'm re-reading your comments, and somehow I get the feeling we are misunderstanding each other.
                          I think I'm responsible for that misunderstanding at the very beginning.
                          your response to my question about the joist and rafter tools is a case in point.
                          I quote you:
                          "But the Joist and Rafter tools make a component that is repeatedly copied AND if you subsequently edit one of them then they all change !"
                          What I quoted above, is exactly what I would like my script to do. I'm not looking for parts that are unconnected, as you talk about in the remainder of your quote.
                          I would like all of the cubes that my script repeatedly copies/generates, to be made a component, so that if I then edit one all the rest will change.
                          tomot
                            Koos Brandt
                            I know it is nearly a year later, but your code is not doing what you think it is doing.
                            Box4 does the following logically:
                            It creates a component def
                            Then you add 1 face to it and pull the face to make a block
                            then you add this component as an instance
                            then you add another face to it and pull it making block 2
                            then you add another instance. But you also update the original instance to now have two blocks
                            and so on
                            if you set it to have 3 by 3 blocks you get 9 components all the same with each nine pulled faces inside it. The inside blocks are not component instances, the are merely blocks (pulled faces) inside the component.
                            If you select the block at the end of the process and move it you will see there are more blocks underneath it.
                            If you wanted to do what you intended, you needed to create a new component def each time you enter the upto loop.
                              tomot
                              Its one of the things I have not been able to resolve.
                              I will give your suggestion a try, in the near future.
                              thanks!
                              tomot
