    Didier's cloud.rb
    6 Posts 3 Posters 1.7k Views 3 Watching
      Well, apparently "adressed" to Didier himself...
      Didier,
      1. This is a wonderful tool but I cannot get it run in SU 6 (therefore I need to do it in SU 5 - which would not be a problem but others are interested in it, too).
      2. I found out that when either x or y value is 0, the script just leaves that line of points out (I don't know of 0 z value because I haven't used data with that).
      Could you, please, look into these things?
      Thanks...
      • N Offline
        not registered yet
        Will you tell me where to download? 😳
        [Invader ZIM]
          Invader, I made a sticky topic/post in the Ruby Depot here:
          301 Moved Permanently
          (www.sketchucation.com)
          It's on Didier's site. Have fun!
          • Didier BurD Offline
            Didier Bur
            mmmkay
            If I understand well, I must install V6 πŸ˜• (never use it after I tested it ) ?
            I'll have a look at this πŸ˜†
            But: what does it do when you launch it on V6 ?
            Regards,
            DB
              Ah, thanks, Didier for dropping in (it was some kind of a "bait" writing your name into the subject field πŸ˜„)
              Well, without any error messages, it just does nothing at all. No cloud of points. I noticed it previously, too, and posted it in the RIP forum for you and you excused yourself with the same thing - no SU6 installed "yet".
              well, here's a link to the GG Forums (it has arisen there lately, too).
              Thanks for dealing with it (and/but see also that "Point 2" in my post above, please; that's happening in SU5 - since in SU 6 nothing is happening).
                Didier Bur
                OK, I've posted the new version of cloud.rb at the depository:
                -better dialog box (more user-friendly).
                -better layer support
                -more delimiters, sample of file line provided in dialog box
                -invalid file detection, more than 3 data per line detection,
                -select your X Y Z coords columns when more than 3 data per line in the input file
                -option to "flatten" the data (Z=0)
                Tested with V5 and V6. works like a charm πŸ˜›
                Gaieus, when you say "it does nothing", maybe it does build the cloud anyhow: did you do a "zoom extents" after the command has ended, or did you look at the status bar to see the message when it imports the points ?
                If it fails, please send me the input file.
                Cheers,
                DB
