    Rendered for a friend
    25 Posts 11 Posters 8.0k Views 11 Watching
    • K
      kwistenbiebel
      And a Podium rendering:
      http://i140.photobucket.com/albums/r3/kwistenbiebel1/small7.jpg
      • K
        kwistenbiebel
        Maxwell again 😄
        http://i140.photobucket.com/albums/r3/kwistenbiebel1/small8.jpg
        • K
          kwistenbiebel
          Maxwell:
          http://i140.photobucket.com/albums/r3/kwistenbiebel1/small9.jpg
          • K
            kwistenbiebel
            ....A quick Vray try:
            http://i140.photobucket.com/albums/r3/kwistenbiebel1/small10.jpg
            • K
              kwistenbiebel
              ....And a last one (Maxwell).
              I hope the guy is happy with it.
              http://i140.photobucket.com/albums/r3/kwistenbiebel1/small12jpg.jpg
              • GaieusG
                Just perfect. No wonder I'm glad you have finally registered here!
                  andeciuala
                  i really liked it, very nice and clean renders, i didn't know about that fry render. Congratulations! 😲
                    Nice renders!
                    Which of the render engines did you feel fitted best for the job?
                    • FrederikF
                      Frederik
                      @thomthom said:
                      Nice renders!
                      I was going to ask the exact same question... 😄
                      Cheers
                      Kim Frederik
                      • EdsonE
                        Edson
                        congratulations to both of you. very good renders and very interesting project. i am sure your friend must have been pleased by your renders.
                        http://www.mahfuz.arq.br
                        • K
                          kwistenbiebel
                          @frederik said:
                          @thomthom said:
                          Nice renders!
                          First, thanks for those comments!.
                          The question you pose is a dificult one.
                          For exteriors I prefer the unbiased solutions (Maxwell and Fry), but they perform poorly for interiors when you consider the Render times (count in days for an indirect lit interior).
                          On the other hand, the so called 'biased' engines (Podium, Vray) perform better in terms of speed for interiors but (sometimes) need a bit more tweaking (photoshop) to obtain comparable realism.
                          So to me, there is no real winner here.
                          The magic solution to me would be to have a 'hybrid' render engine that calculates an unbiased solution ('brute force'methods like MLT and all sorts of pathtracing) with a little help of some 'biased' code to clean difficult indirect lit parts.
                          The only engine,capable of doing something hybrid like that for the moment, are certain engine presets in Vray , but it is more a biased solution (like Irrmap or light cache) with a little 'unbiased' added ( 'QMC', also called 'Brute force').
                          Let's see what the future brings.😉
                          • marked001M
                            marked001
                            these are awesome, kwisten.. i'm having a tough time deciding which versions i like best 😄 i'm kind of leaning towards fryrender i think...
                            http://www.revision21vis.com
                            instagram: revi21on
                            • K
                              kwistenbiebel
                              Thanks Marked 😄
                              I must admit I had to level light/color in Maxwell because of the strange orange/red overcast the physical sky seems to produce in 1.5.
                              I don't know about the new update 1.6 that has just been released today.
                              Fryrenders Physical sky doesn't seem to have that colorcast...but at the risk of being dull?
                              I am not sure. Chema (developer of Fry) announced that upcoming 0.9 version will have improved colors for their physical sky...
                              Vray has a really nice color bleeding going on with their sky system.
                              However, for exterior shots, renderings can easily look washed out and need some leveling in post.
                              Oh well, nothing is perfect 😄
                              • K
                                kwistenbiebel
                                Thanks Edson.
                                Just to point out one of the handicaps of the unbiased render engines: you can still see some noise on the interior walls, while this image has been cooking for more than 10 hours. (the exterior parts were clean already after 1 hour though).
                                http://i140.photobucket.com/albums/r3/kwistenbiebel1/small13.jpg
                                • FrederikF
                                  Frederik
                                  Well... What can I say... But I'm sure that you're going to be pleased with next KT2008 release... 😉
                                  My lips are
                                  http://www.kerkythea.net//users/Frederik/Anim-Icons/Lips-sealed.gif
                                  Cheers
                                  Kim Frederik
                                  • K
                                    kwistenbiebel
                                    Hi Frederick,
                                    You make me curious 😄
                                    I know Indigo has a 'hybrid' option, but it is a mix of different 'unbiased' calculations (PPT+ MLT, BiPT + MLT, etc...) so it's actually adding 'slow' to 'not so slow' 😄 (I think Indigo is a good render engine BTW)
                                    However, the mix of 'biased' + 'unbiased' I only saw (sort of) in Vray...
                                    Are you indicating that Kerkythea will go that route?
                                    Sounds interesting...
                                    • I
                                      ilay7k
                                      hello!
                                      I like maxwell tests...
                                      So have you try new MR 1.6 + 1.1 skp-exporter?
                                      I look at plugins_improv_bug.doc
                                      SketchUp toolbar was implemented for Maxwell SketchUp tools
                                      All the cameras for all the SketchUp pages are exported to the Maxwell MXS file as inactive cameras for possible later use in Maxwell Studio.
                                      Full support for SketchUp texture manipulation added – texture rotation, skewed textures, and photo-manipulated textures are supported.
                                      Maxwell Command Line parameters can be entered directly in the SketchUp dialog
                                      Image search path support was implemented into the SketchUp export dialog - it is now possible to specify the path for missing textures.
                                      Ruby dialogs were rewritten using the Maxwell Render color scheme
                                      Visible Render area indicator was added to the Ruby script
                                      Pick focal length and Show render area were integrated in the camera dialog
                                      Protect geometry and Low priority switches were added to the export dialog
                                      Reset all options in the export dialog was implemented
                                      Fixes:
                                      GMT offset was wrong on OSX Intel machines - fixed.
                                      Materials were updated to use the new internal material mechanisms
                                      Default tone mapping options is set properly now
                                      MXI export switch works properly again
                                      Film width/height controls were added back to camera dialog
                                      Entities with different SketchUp texture clones were exported as a single object - fixed.
                                        matt77
                                        Hi Biebel,
                                        All very good images. I'm impressed with the fryrender ones. Unless I've missed something i cant seem to find the plug-in or exporter for SU on there website. Where abouts did you find it?
                                        Any info would be appreciated
                                        Matt
                                        • I
                                          ilay7k
                                          Hello Matt
                                          feversoft gives it(in full package) for registered users...
                                          • U
                                            urs0815
                                            KT2008 😮 does it mean that the new version of KT comes out only in 2008? 😲
