    Eliminating the Background?
    5 Posts 3 Posters 1.2k Views 3 Watching
      GreenToaster
      Hello,
      I would like to be able to print out orthographic views with dimensions (I'm doing this now, but the background provides visual clutter). I'd like to be able to eliminate the background - no sky, no horizon, et cetera.
      Is there a way to do this?
      Thanks,
      GT
      If you really want something you won't ever stop pursuing it.
      • AnssiA Offline
        Anssi
        Open the Styles dialog. Select the Edit tab. Push the Background icon. Untick Sky and Ground, and set the Background colour to white (or whatever you like)
        Anssi
          White is the best choice for nothing to print at all for sure - from native SU.
          Also set white (after setting everything Anssi said) if you want to have a transparent (i.e. NO) background in LayOut (provided you are using it).
            GreenToaster
            This is very good info - I tried it & it's just what I needed - THANKS! πŸ˜„
              bump
