    [Tutorial > Modeling] How would you model this? (wood stove)
    18 Posts 7 Posters 20.9k Views 7 Watching
    • boofredlayB
      boofredlay
      Second panel.
      Push cut profile through and intersect with model.
      http://www.sketchucation.com/forums/scf/sas/Tutorials/Stove-Leg/4.jpg
      Delete unwanted and make it a component.
      http://www.sketchucation.com/forums/scf/sas/Tutorials/Stove-Leg/5.jpg
      Copy, mirror and rotate.
      http://www.sketchucation.com/forums/scf/sas/Tutorials/Stove-Leg/6.jpg
      • boofredlayB
        boofredlay
        And last...
        Edit component, intersect with model and delet unwanted.
        http://www.sketchucation.com/forums/scf/sas/Tutorials/Stove-Leg/7.jpg
        Clean up and add details etc...
        http://www.sketchucation.com/forums/scf/sas/Tutorials/Stove-Leg/8.jpg
        I hope this helps.
        • T
          tomsdesk
          Bernard, I had a bright idea and it seems to have worked:
          Trace the leg (better than I did), push/pull it, copy/rotate to cross, intersect with model, erase out the wings (now you have a nice wood table leg), copy each of the outside faces and move inward to create the metal thickness, erase out the inside material to create the cast shape. Lastly, smooth the edges.
          Neat! I didn't know I had it in me...thanks for the fun puzzle. Best, Tom.
          Edit: (So you guys are the reason I timed out so many times, this thread was empty when I started trying to post :`)
          stoveleg.skp
          2.5D Trees & Shrubs!
          • boofredlayB
            boofredlay
            Ooof. It seems my model has been intersected πŸ˜’
            Edit, it seems we are in force tonight!
            Like so.
            http://www.sketchucation.com/forums/scf/sas/Tutorials/Stove-Leg/9.jpg
            I also noticed that the corners were rounded, you could explode the components into one and smooth the edge.
            • KrisidiousK
              Krisidious
              I'd like to move this to the Tutorial section or Boo, you could create a new thread there with this valuable information in it...?
              By: Kristoff Rand
              • T
                tomsdesk
                No, you had it (modelhead...I've lost or don't know your name), mine doesn't smooth as much as the reality requires. Still, I won't be a-scared of table legs anymore, Thanks!
                • GaieusG
                  Wow! Great stuff! I was only away a few hours and I find three solutions to something that has been worrying me for months. This is just how the old @Last Forums used to be. It makes me feel right at home - though a bit guilty at not having made many contributions myself.
                  Many, many thanks Eric, modelhead and Tom. I'll go through each solution and post the finished model - for those interested in early Queensland Crown wood stoves - after I get the stove back from Toowoomba in a couple of months.
                  Greatly appreciated. πŸ˜†
                  (Bernard Hagan)
                  • GaieusG
                    Bernard,
                    I've got fairly vivid [and mixed] memories of one of these stoves.
                    It was during my Gauguin period πŸ˜’ , living dirt poor in an unfinished house, in the middle of a banana plantation, on the ocean side of Buderim.
                    It was chop the wood, light the fire, boil the water......for a cup of tea...or a bath.
                    And just the thing to cook the the Sunday roast on.....say during the rainy season in January πŸ˜‰
                    Stu
                    • GaieusG
                      ust to show off [I doubt there is anyone who could actually use them] - here's a pair of legs for a No 7 Crown wood stove.
                      Thanks again to the boys - Eric, modelhead and Tom. You can be very proud of your student - I am.
                      Stu - like yours, my childhood memories of these types of stoves are of
                        - burning toast propped up with a fork at the open door of the firebox
                        - having a hot bath in an old galvanized iron tub on the kitchen floor in front of it
                        - the smell of stews and roasts that filled the kitchen.
                      Dad was a carpenter but worked at the meat-works in Rocky and built the house around us on weekends. It was on 8 foot stumps, Queensland style, and we used a ladder instead of stairs for the first few months. I was about 7 or 8.
                      It was a great adventure. Just imagine what the reaction to that would be today.
                      I'm having my present stove converted to gas once it's renovated - can't put up with soot and all that cleaning - getting too old [and green] for that.
                      (Bernard Hagan)
                      Stove Leg.skp
                      • boofredlayB
                        boofredlay
                        Kris/Boo...let me know if you would like me to put a more detailed profile-followme-intersect with model method together. I'd be happy to if you are consumed with other things...let me know...cheers
                        Bruce, I will not have time to start a tut this morning, I can get to it tonight. If you want to start a thread go ahead, then I can tack on to it. That way we can have 2 methods in the same thread. What do you think?
                        If it is ok with Bernard, post one of the pictures from this thread of what was requested.
                        And if you do, please post a link from here to the new tut thread.
                        • boofredlayB
                          boofredlay
                          It has already been moved/copied. Thanks Coen. No need to re-do.
                          • T
                            tomsdesk
                            What I love about this group, this forum (this program): this thread says it all! Three distinct paths to the same solution...shared...then utilized. Plus, now I get to think about the next problem a little (or a lot) differently.
                            Sweet!
                            Yeah Eric, Bruce, Bernard!
                              dylan
                              Another great thread!
                              Really useful seeing the methods shown to complete this. There is alwayss loads to learn with this program
                              Dylan
                              http://dmdarchitecture.co.uk/
                              • GaieusG
                                ...although the moderators may have other thoughts about whether our little session has any value??...
                                No Bruce, moderators do not consider value. They may - at the very most - consider a topic/thread to be more useful elsewhere. Value is added by the users.
                                (I've been following the topic with excitement! πŸ˜„)
                                • GaieusG
                                  Here is a tutorial showing the processes I used. It may be of value to those of you wanting to create
                                  other complex curves - eg. appliances, automobiles and organic solids.
                                  Thanks to Eric, Bruce [modelhead] and Tom who showed me how - and to Coen who slimmed down the size of this tute file.
                                  (Bernar Hagan)
                                  StoveLeg Tutorial.zip
                                    dylan
                                    Very nicely explained Bernard, that makes the process seem quite simple!
                                    Dylan
