    First Podium Test
    extensions
    14 Posts 8 Posters 10.8k Views 8 Watching
    • tinanneT Offline
      tinanne
      Wow, Pete, that is awesome! I have gotten your emails, but running out the door for Soccer playoffs. GO TEAM!! If they win tonight, they go to the championships!!!! WOOHOO
      I'll look at the stuff later, thank you, again, so much!
      Bruce, sure no prob. I'll do it when I get back.
      Executive Director : American Society of Architectural Illustrators
      AIP 30 Competition opens soon. ASAI.org
      Architectural Rendering
      • tinanneT Offline
        tinanne
        Notes from Pete....
        when you render try to keep geometry to a minimum, so what's happening is the render engine is rendering the entire house, if you could put kitchen on a layer or select geometry you require and create a new .skp with just what you want in render you can reduce render time by 80%.
        I never used bumps (which would really make it 'pop') that's something that you need to adjust your workflow to when you upgrade to newer version.
        I don't even know what "bumps" are. I know, it's very sad 😳
        I checked again and figured out that with the 1.4.1 version 2 point perspectives were not completely compatible, the stove top plates will not render as lines without weight do not render with any render engine, you need to make circular shapes and add a color or texture.
        I played around with it a little more, skippy attached, and it still took forever. http://www.sketchucation.com/forums/scf/sas/Gallery/kitchen.skp 😞 There are still missing materials? Not sure what I did wrong or different. I kept the settings the same as what you sent, I think?
        You will notice a big geodesic omni ball in view, that's my way of soft lighting in foreground (most folk hate it as it blocks view, i use it as it controls burn spots by occupying area of falloff.
        Could you explain this {the 3rd grade version} a little further.
        curious about the materials... you changed some materials, what was the reason for this? Also, regarding shadows... on, off, sun shading.... which is best for interior renderings?
        Versions... When will 2.0 be available? and will it be compatible with 2pt perspectives?
          I don't even know what "bumps" are. I know, it's very sad Embarassed
          Bumps are images that will make your surfaces (well, practically) "3D". Instead of me (an also newbie in the rendering "industry") going into the details, see these textures here and where there are the "diffuse", "Bump map" and "specular map", you will see little question marks. Go there and see what it say about.
          http://www.arroway.de/textures/04/en/index.html
          • tinanneT Offline
            tinanne
            Well that explains it! πŸ˜„ Thanks Gaieus.
            • DanielD Offline
              Daniel
              Tinane, I've encountered the same problem with disappearing textures. Its usually in grouped items (especially nested groups). Don't feel so bad about your render time. My first real rendering took over three days - but everyone said it looked great! LOL
              You should post your rendering in the gallery forum, when finished.
              My avatar is an anachronism.
                sepo
                V2 is still some time away. Really not at liberty to discuss the details but I can tell you that quality and speed will be way better than it is now.
                The V1.5b3 should be available sometimes this week. It is much faster than 1.4.1 depending on preset used. It also makes possible to do interiors with sun only. For more details join the crowd at the forum.
                • tinanneT Offline
                  tinanne
                  I took another stab at it with some post-processing in PS. Using V1.5b2
                  • soloS Offline
                    That looks awesome and with the post processing it defines the lines and creates a unique style, your style.
                    Congratulations, and great image.
                    • tinanneT Offline
                      tinanne
                      and yet another test....
                      • boofredlayB Offline
                        boofredlay
                        Exellent. And with the black and white outside it feels like it is snowing. Love it!
                        • N Offline
                          Nick W
                          Nice work, Tina. The last kitchen render is great - the added depth and realism of the shadows in combination with your style are stunning. Keep posting your progress. πŸ˜„
                          http://www.nrwiesneski.com
