    SketchyPhysics Alpha
    90 Posts 26 Posters 27.1k Views 26 Watching
    • N Offline
      not registered yet
      This is a great plugin - congrats of the work so far.
      Noticed one other bug: pressing Ctrl+Z (Undo) while the simulation is running causes seriously bad things to happen! Can Undo be disabled temporarily?
      Some more playing…
      I decided to create a chain, and tried in a number of ways…
      1. Create rings (torus) and arrange them so that they interlock in 3d space. Why does this not work? I assigned Shape:convexhull, but this is obviously not correct.
      2. Create rectangular 'chain links' where each 'link' is made of 4 cuboids. This should overcome the convex hull issue and be easier on the maths 😄 Indeed it works! But looks ugly!
      3. A different sort of chain… Created a linear array of cubes and inserted a ball joint between each one. At this stage I have a vertical column of swinging cubes, but they all act independently. And I can't work out how to correctly group the joints with the cubes to create a single chain of linked cubes. What is the correct way to do this?
      P: Ampa
        CPhillips
        Yeah, Ill mark it as a bug.
        A whole torus marked as convexhull will really resemble a solid wheel. If you want to create linked torus you need to break each segment of the torus apart into a convex hull and then group all the pieces. I did it once and it takes a while.
        @ampa said:
        1. A different sort of chain… Created a linear array of cubes and inserted a ball joint between each one. At this stage I have a vertical column of swinging cubes, but they all act independently. And I can't work out how to correctly group the joints with the cubes to create a single chain of linked cubes. What is the correct way to do this?
        Group each of the ball joints with one of its two connected links and then use the JCT tool to connect the other link to the ball joint.
        I should warn you that the ball joints aren't very stable when you connect them like this. The chain will fly wildly out of control if you try to move it too fast. This is a limitation of the underlying physics engine.
          CPhillips
          "Google Guy" has an example.
          Error 404 (Not Found)!!1
          (sketchup.google.com)
          • N Offline
            not registered yet
            Chris, thanks for the pointers. It all makes sense now 😄
            Weee I have a dangle chain type thingy! I never knew how much I wanted one of these.
            I look forward to further development, you've made a great tool / toy.
            Ampa
              bellwells
              Hi Chris,
              I had left a post over on the Google Groups about this, but thought I should mention it here as well. The strange images of guys playing crochet, etc are under the SketchPhysics directory at dhtml-suite-for-application>demos>demos-images. I would think they could be deleted??
              Absolutely love this script.
              Ron
                diana
                I am having a lot of fun with this script. Playing with the example files mostly; bowling, playing pool, trashing all the things that go round and up and down, tossing the doll about (got his head stuck through a wall once), etc. It's very entertaining! I realize it could be used as a tool as well, but I just want to play.
                • N Offline
                  not registered yet
                  I was looking at giantmonster.tv today, and wondered whether one could use SketchyPhysics as an easy rigging tool for SU?
                  The code already exists to define joints between different objects, along with movement tollerences (max and min) so by turning off gravity a rag-doll becomes a posable-doll.
                  What do you think?
                  So I had a look at the SketchyPhysics options… turning off Gravity is easy to do; but I was unclear about what the other options did…
                  Density: presumably affects the mass of objects when they collide.
                  Framerate: defines the amount of discrete time that passes during each itteration?
                  Worldscale: er - no idea 😄
                  I was trying to recreate space - ie no gravity or friction, but couldn't find a way. My objects always slow down, as if through air resistance. Is this possible?
                  Ampa
                    CPhillips
                    What do you think?
                    Ampa
                    Possible in theory. But it would require some fairly big changes to the non-ruby code.
                    @ampa said:
                    Yes. It isnt much use now. It will be important in future versions.
                    Ampa
                    Yes. 1 is the minimum. Higher numbers will appear to go faster but wont be as smooth.
                    Ampa
                    This is how big the world is. Use bigger numbers to increase the size of the world.
                    Ampa
                    There inst any air friction that I know of. I am not sure why your objects would slow down in zero g.
                    • N Offline
                      namza
                      ping pong machine
                      pingpong4b.skp
                        CPhillips
                        @namza said:
                        ping pong machine
                        Very nice! It looks as cool as it works.
                        You should upload to 3d warehouse(use sketchyphysics tag).
                        • N Offline
                          namza
                          @cphillips said:
                          @namza said:
                          ping pong machine
                          ok its done
                          • N Offline
                            namza
                            funny mouvement mooving cylinder or rotate box
                            Hyperboiloid_mouvement.skp
                            • N Offline
                              namza
                              the same with balls
                              ball roundabout.skp
                              • N Offline
                                not registered yet
                                Hey Chris, where can I download SketchySolids Toolbar and how do I drag objects? I ot a LOT of trouble with that.
                                Invader ZIM
                                  CPhillips
                                  SketchySolids is part of SketchyPhysics.
                                  There are instructions and a tutorial on dragging on the homepage:
                                  (code.google.com)
                                  • N Offline
                                    not registered yet
                                    (code.google.com)
                                    I got this really bad error here. Can you help me?
                                    Invader Zim
                                      CPhillips
                                      That picture is almost unreadable. But I think the problem is you don't have the files in the right place. Follow the instructions here:
                                      http://code.google.com/p/sketchyphysics/wiki/LatestVersion
                                        Masta Squidge
                                        If the "staticmesh" creates an object that followed the actual geometry of whatever it is, wouldnt it make sense simply to make all objects mesh objects though not static?
                                        wouldnt that do away with all the work of having to change each item, and fix the problem with making a closed torus into nothing more than a cylinder from the viewpoint of the program?
                                        Im sure there is a reason for it, but wouldnt it be easier to work with if all object were made as "mesh" objects that follow the geometry of the item, then you would only need to assign static, frozen, or ignore values to each item.
                                        Also, as was posted before, pressing "Ctrl-Z" while in a simulation causes objects to "explode" and move around the scene. Its not easy to fix.
                                        AND, sometimes when i make a floor when the "default" scene is acticve, then delete the default floor to play with the four objects, after they go out of the boundary of the default scene floor, they drop through the newly placed floor (yes its a solid object) while items i have made have no trouble with it at all.
                                        All in all, very nice work.
                                        Oh, and by the way:
                                        Hi guys!! Im new here (obviously) and am currently in the process of being miserable with this plugin, and the two videos i have seen on it dont teach me anything more than how to place a hinge and stack up objects during a simulation.
                                        If anyone would like to perhaps give me a hand with this, i would be grateful, as any "tutorials" that i find dont really teach me anything.
                                          CPhillips
                                          Sorry, I just noticed this post.
                                          The problem with "static mesh" objects is they can't move. That is why all the other shapes exist. The closest to what you suggest is "convex hull". But it isnt perfect and a lot slower.
                                          I fixed the ctrl-z problem in the next version due in the fall. Ill look into the other bug.
                                          As for tutorials: I haven't updated the ones on the website because most people are posting models to 3dwarehouse.
                                          http://sketchup.google.com/3dwarehouse/search?q=sketchyphysics&styp=m&scoring=d
                                          You can also ask for help in the SketchyPhysics forums:
                                          http://groups.google.com/group/sketchyphysics/topics
                                          Oh, and by the way:
                                            Masta Squidge
                                            Thats why I mentioned the idea of making a "Mesh" option to go along with static mesh. While Static Mesh is, well, static, Mesh would not be static.
                                            • 4 / 5
