    SketchyPhysics Alpha
    90 Posts 26 Posters 27.1k Views 26 Watching
    • KrisidiousK Offline
      Krisidious
      "sniff, sniff..........feeling sorry for myself............"
      Thanks Chris, you have managed to make the one thing on the planet that makes me regret not having a PC.
      Sure sounds like you guys are having a fun time........... 😞
      why not run that Windows Emulator....?
      By: Kristoff Rand
        CPhillips
        @namza said:
        i did that funny work
        you need the last version of sketchyphysics http://code.google.com/p/sketchyphysics/wiki/LatestVersion
        Very cool. That is the simplest self moving machine I have seen. πŸ˜„
        • N Offline
          namza
          i made it afer a lost of test. The problem is that now i CAN'T ( !!) reproduce this machine. It goes with join and groups but all depends of what do i have to join ans what do i have to group ...and in wich order .....
            CPhillips
            By the way. I see you made your track out of blocks. That is fine, but you can also just edit the floor. Any staticmesh (like the floor) can be edited at a per face level and will still work.
            [url=http://www.sketchucation.com/forums/scf/sas/SketchyPhysics/avance3c-track.skp:33txugzx]avance3c-track.skp[/url:33txugzx]
              CPhillips
              You can use the joint connection tool to examine the way the joints are connected. In this case each of the 3 cylinders is grouped with a hinge. And the bars are just connected to the hinges.
              Joint connections can be confusing at first.
              • N Offline
                not registered yet
                Chris,
                That is nothing short of amazing. I'm awestruck. I'm curious as to why and what it took (in general terms) to create this.
                Mark
                P: marsol
                  CPhillips
                  Chris,
                  Mark
                  Thanks Mark.
                  The why is because its fun.πŸ˜„ I like making things that actually behave the way you'd expect.
                  What it took was a good physics engine (newton) and a lot of work. I have been working on it on and off for over 2 years. Its currently around 10k lines of ruby but I have probably written and discarded 20k.
                  Some of that 10k is code that isn't even enabled yet. SketchyReplay for example records animations and features some non-linear editing. Here is an example. Note the camera behavior and the rewind stuff at the end.
                    architectboy
                    So, I've set up a Sketchy Physics competition for anyone who is interested in modeling with Sketchy Physics.
                      Krisidious
                      is there or could there be, a way to turn on a shader, that would shade or highlight the area in which SketchyPhysics was available with in the model.
                      know what I mean? there is an area in which the Physics work and one where it does not, I'd like to see that area...
                      By: Kristoff Rand
                        architectboy
                        Yea, for some reason objects seem to stop moving about 200 feet from the origin.
                          Krisidious
                          that's because the Physics are not global... it's just a small area around the axis...
                          By: Kristoff Rand
                          • N Offline
                            not registered yet
                            Very cool plug in!
                            If I move the sketchyphysics tool window any other toolbars that are open on my second monitor close.
                            P: SABBA
                              CPhillips
                              You can adjust the size of the world under Plugins->Physics Settings. Adjust world scale to make it bigger or smaller. Note if you make it too big small things will stop working.
                                CPhillips
                                Very cool plug in!
                                Hm. Thats wierd. Ill look into it.
                                • N Offline
                                  not registered yet
                                  @cphillips said:
                                  Any other comments or feedback?
                                  Has anyone used the SketchySolids toolbar? I am thinking that it is almost worthy of being a separate plugin.
                                  Where can I download SketchySolids?
                                  P: Invader ZIM
                                    Krisidious
                                    is there a way to convert a regular group or component into sketchy solids?
                                    By: Kristoff Rand
                                      CPhillips
                                      Right click it and use the Set Shape menu.
                                        CPhillips
                                        There are some pretty good user generated demos popping up on 3d warehouse. Here are a few good ones!
                                        http://sketchup.google.com/3dwarehouse/details?mid=f27b91714ea5752a87d6d7c29947ae22
                                        http://sketchup.google.com/3dwarehouse/details?mid=4ceb45eacc729c5ea611269c93d910
                                        http://sketchup.google.com/3dwarehouse/details?mid=fefb0ae5c3399f426e49a9db8e76daf1
                                        http://sketchup.google.com/3dwarehouse/details?mid=d972bcb8198c5770ac03d4486f1f7520
                                        And a good YouTube video:
                                        http://www.youtube.com/watch?v=YQquRx7rmkk
                                        • N Offline
                                          not registered yet
                                          Can I use a spring like a piece of elastic?
                                          What I would like is that the model starts with the elastic stretched, so that once the simulation begins it will try to shrink to zero length (or some other predefined minimum length) pulling any attached object with it.
                                          Where-as the spring seems not to exert any force on attached objects until it is either streched or compressed from the start position.
                                          Ampa
                                            CPhillips
                                            Ampa
                                            It doesn't do that yet. Ill add it to my todo list.
                                            Thanks Ampa.
                                            • 3 / 5
