    MUZWalls + Layout update 4.3.0
    2 Posts 2 Posters 96 Views 2 Watching
      Muzwalls Newcomers
      1. Automated Drawing Set Generation
        Single-Press Document Creation: In one action, MUZWalls sets up standard scenes in SketchUp (level-by-level floor plans with active section cuts, exterior/interior elevations, building sections, and individual framing elevations) and generates a linked .layout document.
      Pre-Mapped Pages: Each generated scene corresponds to a dedicated page inside LayOut, structured with viewports and drawing titles.
      1. Live BIM-Style Metadata & Labels
        Intelligent Annotations: Every wall, door, window, column, and room built with MUZWalls stores internal metadata (element numbers, dimensions, sill heights, fire ratings, U-values).
      LayOut Label Tool Integration: When you point LayOut's native Label tool with leaders at any MUZWalls component, it dynamically extracts and displays those attributes without manual typing.
      1. Bi-Directional Schedules
        Auto-Generated Tables: Window schedules, door schedules, room finishes, wall assemblies, and structural column schedules are exported as structured tables.
      Single-Click Refresh: If you modify sizes, counts, or wall thicknesses in the SketchUp model, re-exporting the data updates the linked tables in LayOut so schedules and model viewports stay synchronized.
      1 Reply Last reply πŸ‘
      • jujuJ
        juju
        Is there a settings section where we can map our own (custom) tags / layers that can then be used by the extensions / plugins?
