    Medeek Project
    106 Posts 3 Posters 13.2k Views 4 Watching
    • medeekM
      medeek
      Version 1.2.3 - 05.14.2024 thru 05.15.2024
      • Fixed a minor bug with the estimating module (wall header library initialization).
      • Fixed a minor bug with the estimating module (wall material library initialization).
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      medeekM 1 Reply Last reply
      • medeekM
        medeek @medeek
        Version 1.2.4 - 08.04.2024
        • Added a duplicate title block assembly check to the regen module for all title blocks.
        • Enabled wall sheathing 2 within the Medeek Estimating Module for wall assemblies.
        design.medeek.com
        • medeekM
          medeek
          Version 1.2.5 - 02.28.2025
          • Fixed a critical bug with the estimating module (wall sheathing 2).
          design.medeek.com
          • medeekM
            medeek
            Version 1.2.6 - 02.09.2026
            • Added a line type option for major grid lines of the grid tool.
            • Added the major grid line option to the General tab of the Global Settings.
            With the latest versions of SketchUp there is a bug with the stipple pattern for construction lines and as a result it is nearly impossible to differentiate major grid lines from minor grid lines. Since this bug has never been resolved (at least to my knowledge) by the SketchUp team, I have determined that simple work around would be to replace the construction lines in the grid (major grid lines only) with regular lines or edges. Now one can actually tell them apart.
            This option can be toggled in the General tab of the Global Settings.
            Personally I prefer the dashed construction lines for the major grid lines but in newer versions of SketchUp solid lines are probably the better option.
            design.medeek.com
            • medeekM
              medeek
              First look at the Floor Plan printed output (11x17 Ledger):
              design.medeek.com
              • medeekM
                medeek
                The API connector/bridge seems to be working, just need to do some more testing and also add the roof:
                design.medeek.com
                • medeekM
                  medeek
                  First look at a very basic DXF export of the Floor Plan. I now have my own DXF export engine, it may prove useful.
                  design.medeek.com
                  1 Reply Last reply πŸ‘
                  • medeekM
                    medeek
                    The first attempt was a bit crude in my opinion. After some fiddling with fonts and dimensions things look a bit more presentable:
                    design.medeek.com
                    • medeekM
                      medeek
                      I'm trying to get it to slow down so you can see the step by step build process.
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 1.2.7 - 07.29.2026
                        • Added the Medeek Builder toolbar
                        • Added the "Draw Garage" tool to the Medeek Builder toolbar.
                        • Added a print option (floor plan only) to the Garage Builder Tool.
                        • Added a DXF Export option (floor plan only) to the Garage Builder Tool.
                          Enabled the Garage Builder so that it can fully interact with the Medeek API calls: Wall, Truss and Foundation.
                        Note that in order to use this new feature the latest versions of the Wall, Truss and Foundation extensions will be required.
                        design.medeek.com
                        • medeekM
                          medeek
                          Tutorial 7 - Garage Builder (16:14 min.)
                          This tutorial introduces the new Garage Builder tool for the Medeek Project Plugin. The tool provides an intuitive floor-plan interface where users can configure a four-wall garage, drag and position garage doors, man doors and windows, preview each elevation, and adjust basic wall, roof and slab-on-grade options.
                          Garage plans can be saved and reused along with their project data and additional wall settings. The Garage Builder also supports architectural-scale printing, PDF output, adjustable grid snapping and 2D DXF export. Once the design is complete, the tool uses the Medeek Wall, Truss and Foundation APIs to generate fully editable native Medeek assemblies directly within SketchUp.
                          This initial release is intended as a proof of concept, with additional roof, foundation and advanced configuration options planned for future updates.
                          design.medeek.com
                          • medeekM
                            medeek
                            From the get go the Garage Builder was a proof of concept, and it does seem to work reasonably well. However, I'm now contemplating creating a slightly more complicated version of this tool called the House Builder. I will probably initially not include the roof or foundations for the first iteration and primarily focus on the wall layout engine (that is what is most important).
                            Thoughts? Is there any interest for such a tool?
                            In some way it may resemble what Chief Architect does, you create your layout in 2D, fully dimensioned and then like the Garage Builder it can with the push of a button translate that into a full 3D model on demand.
                            The current algorithms that produce the DXF or printed drawing (PDF) will need to be further developed and augmented so that we can auto-dimension a much more complex floor plan, this should become very interesting.
                            The goal is to be able to create, at a minimum, something like this in the House Builder tool:
                            I've also been giving the auto-dimensioning some serious thought and even as attractive as this may seem, there will always be cases where the user will need to manually intervene and add or subtract dimensions. So I will need to build some sort of user driven dimensioning system that will allow manual override but somehow coexist with a fully automated dimensioning system.
                            In addition to dimensions we will also need to enable some sort of annotation system with text blocks and text with leaders (this is giving me AutoCad vibes).
                            This in and of itself is a full on project, we may have to take this in stages.
                            design.medeek.com
                            • medeekM
                              medeek
                              The House Builder is a fair bit more complicated than the Garage Builder so I have my head buried in the code for a few days with little to show for all my work. Here is a first look at some of the interface with a few random walls arranged for testing.
                              Notice the Start and End markers, similar to the Wall plugin. These will be an optional feature that can be toggled on or off. This is turning out to be a very interesting project and also quite challenging.
                              design.medeek.com
                              • medeekM
                                medeek
                                First look at some walls with dimensions added:
                                I was going to setup an auto-dimension algorithm. However after building the manual dimension tool I found it so easy to use that I don't really see a reason to bother with auto dimensioning. What you see here I was able to do in about 2-3 minutes.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  I still have some rough edges to work on in the UI but progress is being made:
                                  All dimensions are associative, there is no concept of an orphaned dimension, however I may eventually change my mind on that. The nice thing about associative dimensions is that when you change the location of a wall or opening all of the dimensions auto-update.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Starting to work on the updated Elevations tab. Remember this is simply for preview purposes and not really designed to give a high fidelity (rendered) views of the structure/house.
                                    Also I haven't even started with the roof yet. I'm still trying to figure out how involved I want to make that. I could just have it take the wall perimeter and build a complex roof (all hip) using my weighted straight skeleton algorithm. Additionally I could also allow the user the ability to modify certain roof planes (ie. gable, dutch gable, half hip etc...) I will need to give this some additional thought.
                                    The same applies to the foundation (SOG vs. Stemwall) and then if a stemwall we need a floor framing plan. Also what do we do with a multi-story house? I think I've opened another can of worms.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      I've also added a "visibility reference" icon/tool. This allows one to not only toggle off the grid but also to toggle on or off the 1st level walls below the 2nd level walls. This should aid in lining up walls on different levels.
                                      I'm also working on multi-levels, so things are getting interesting.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Adding the ability to move edges and vertices:
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          We can also add and delete vertices:
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            After adding some geometry: Rim Board, Sill Plate, Opening Headers and Joists.
                                            design.medeek.com
                                            • 3 / 6
