    Bonkers faster logging. New extension for developers
    3 Posts 2 Posters 440 Views 2 Watching
    • AdamBA
      AdamB
      DevLog v1.0 is a high performance logging extension for SketchUp. Its built from the ground up to be very fast - currently can handle around 2,000,000 log lines per second. I built it because puts really isn't made to handle lots of logging that you often need when debugging during development.
      RBZ attached below. Let me know your thoughts!
      Here is a short vid explaining a bit more::
      DevLog explainer
      RBZ installer attached
      dlog.rbz
        Can you please explain more about its function and use...
        • AdamBA
          AdamB
          Sure TIG. As shown in the video, its just an extension that opens a window so that when you execute Ruby:
          DevLog.info("Hello world")
          It shows in the log window. You can filter on log level and there are:
          DevLog.warn("oo, something might be bad")
          DevLog.error("oo, this is an error")
          DevLog.fatal("oo, I cannot continue")
          When you close SketchUp, the entire log file is saved to %Temp%
          USP: Its around 4000x faster than puts
