    [Plugin] 3D Text Editor
    202 Posts 50 Posters 199.2k Views 49 Watching
      TIG Moderator @atelierpaar
      @atelierpaar
      Basic 3dText is not 'editable', you need an extension like this -
      https://sketchucation.com/pluginstore?pln=tt_texteditor
        Dave R @atelierpaar
        @atelierpaar it works fine in SketchUp 2025 for me. As TIG implies, the 3D text needs to have been created with this extension in order to be editable. Also make sure you have the current version of TT_Lib2 installed. It is required by this extension.
        This is done in SketchUp 2025.
        Editable Text.mp4
          I suspect you need to reinstall this extension [and perhaps some others?]
          Extensions don't automatically 'port' over from an earlier version of SketchUp when you install a newer one -
          although v2025 does have a new extension to let you do that -
          but it's not 100% foolproof, and reinstalling them manually does let you do some tidying up and housekeeping, to keep your extensions 'lean-and-mean'...
            jjtakestheworld
            Hi, Can i add custom fonts to the list? I use a lot of specific brands fonts which are installed on my machine but i cannot see them in the drop down list?
            TIGT 1 Reply Last reply Reply Quote 0
              TIG Moderator @jjtakestheworld
              @jjtakestheworld
              If the font is installed it should be listed.
              However, I think that only ttf fonts show
              otf fonts don't...
              J 1 Reply Last reply Reply Quote 0
                jjtakestheworld @TIG
                @TIG Ah legend. I've just converted a OTF to TTF and it's found it. Thanks
                  puttea
                  I work with two monitors, SketchUp runs on the right screen. The editor always opens in the left screen. Is it possible to let it open on the right screen or let it remember the location where it was used the last time?
                  Dave RD 1 Reply Last reply Reply Quote 1
                    Dave R @puttea
                    @puttea what version of SketchUp? What operating system?
                      puttea
                      @Dave R SketchUp 2025 Pro on Windows 11
                        Close Sketchup. Go to user/AppData/Local/SketchUp/SketchUp 2025/SketchUp and open PrivatePreferences.json. Look for "ThreeDTextDlg". What are the "x" and "y" values? Edit those to move the dialog onto the correct screen. This is what it looks like on my computer.
                        And here's the dialog relative to the top left corner.
                        Note that the user/AppData folder is normally hidden so you'll need to make hidden folders visible in File Explorer.
                        Did you install SketchUp 2025 correctly? That requires right clicking on the downloaded installer and selecting Run as administrator. If you didn't do that it's possible that Windows is preventing SketchUp from making suitable updates to PrivatePreferences.json. To ensure SketchUp is installed correctly, close SketchUp, find the installer in your Downloads folder, right click on it, choose Run as administrator, and when prompted, click Repair. No matter what, it won't hurt to do it.
                        P 1 Reply Last reply Reply Quote 1
                          puttea @Dave R
                          @Dave-R Thanks!
                          • 11
                          • 11 / 11
