FREDO CURVILOFT
Hi is there a problem with CURILOFT 2.0a?
Unless I have straight lines, Loft by Spline gives me the message
"Error in the construction of the Junctions - Try to change the parameters."
I have tried it with two co-planar lines created by the arc tool and offset using the offset tool and I still get the same message
HOW do we get support from FREDO????
Strange. I cannot reproduce it.
Can you attach the model and give some details on which SU version you use.
