    SU crashes when exporting as .dxf file
    1 Posts 1 Posters 201 Views 1 Watching
      Alohaa
      Recently SU crashes every time I try to export an object as .dxf.
      I have tried 3 times.
      Is there a known solution for that problem?
      Incidentally, there is a problem with this object that may have something to do with the crash:
      there are 2 holes in it. When I look at it from above, I can only see one hole; I have to rotate a little in space to make the second one visible.
      I then copied the object into a new SU file: I can see both holes and the export also works!
      Update: now, even if I close SU normally, I get the message that it has crashed!!
      Kind regards
      Alohaa
