    [Plugin] Scale Face to Target Area - TIG
    46 Posts 11 Posters 32.2k Views 11 Watching
    • L
      luozhan
      Thanks TIG. It's a very useful tool. Is there a way to scale the other faces with the same ratio? The plugin only scale the selected face, but the remaining faces remain unchanged as shown below:
      Please let me know. Thank you so much again!
      Best regards,
      Leo
      • L
        luozhan
        Never mind. I finally figured it out after I look into the rb code. I just use the scale tool and type in a ratio = square root of (new area/old area).
        • O
          ovaleks
          The one who causes is like the one who does .Teşekkür ederim tig
          • O
            ovaleks
            https://img.onl/OCybYb
            Hello, thank you for the plugin. It's great.
            How can I equalize the areas in the photo I sent? Equal area
              The plugin isn't intended for that use.
              I assume you ask how to add lines across a single face to end up with four faces of equal areas...
              How about this for an idea...
              Get my CofG tool.
              Delete any edges that spit the face, so that it's now one.
              Give that face a thickness with PushPull, so it's a solid volume, then group it.
              Now use CofG on the group, and the center of the volume is marked.
              Edit the group and add a line across it through this center marker.
              This should now have equal areas for the two parts.
              Copy the group to one side and now re-edit the group and PushPull one side till it disappears.
              Now you have a part with the half-area.
              Repeat the edit on the group copy, this time erasing the other half.
              Now you have two groups containing equal area parts.
              Repeat the whole process on each group to end up with four groups containing 1/4 area parts.
              Edit the groups and delete the unwanted faces/edges so you end up with single faces.
              Viewing sideways and selecting by fence is a quick way to leave just the top face.
              Arrange the 4 groups so that they align on the cut edges.
              If desired, explode the 4 groups so that the 4 faces join along the cuts.
              You can total/measure the whole starting area, the 1/4 parts are easily calculated and then checked against this.
              O 1 Reply Last reply
              • O
                ovaleks
                Get my CofG tool.
                tig, excellent explanation, I will try and work on it, thank you, I follow you closely, your help is invaluable, thank you for your interest, best regards, tig
                • O
                  ovaleks @TIG
                  @TIG said in [Plugin] Scale Face to Target Area - TIG:
                  Get my CofG tool.
                  After a lot of experimentation, the mobile areas are close to each other but not exactly the same.
                    Each of the 'splitting' lines must be drawn exactly through the CofG AND parallel to one of the 'axes' of the CofG [i.e. suspension-point markers].
                    If you are not very careful, then the results won't be exactly 1/2 or 1/4 of the whole.
                    What are you dividing, and how accurately does it then need to be split up ?
                    O 6 Replies Last reply
                    • O
                      ovaleks @TIG
                      @TIG I am thinking of using it in land drawings, it is an equitable distribution, Autocad lips meet the current situation at this address, dear,Tig. I probably can't use this in Sketchup.https://www.dropbox.com/s/0ptateu3rkrh9mo/Separate Area.VLX?dl=1
                      I will work again as you described, I kept you busy, thank you. Dear tig.
                      • O
                        ovaleks @TIG
                        This post is deleted!
                        • O
                          ovaleks @TIG
                          • O
                            ovaleks @TIG
                            • O
                              ovaleks @TIG
                              • O
                                ovaleks @TIG
                                • 3 / 3
