    • دخول
    3D Truss Models
    Scheduled مثبت مقفل منقول Plugins
    1.5k المشاركات 31 Posters 869.7k المشاهدات 30 Watching
    تحميل المزيد من المشاركات
    • من الأقدم إلى الأحدث
    • من الأحدث إلى الأقدم
    رد
    • رد بموضوع
    يجب عليك تسجيل الدخول للرد
    هذه المشاركة محذوفة. فقط من لهم صلاحية الإشراف على ا لمشاركات يمكنهم معاينتها.
    • medeekM غير متصل
      medeek
      اخر تحرير بواسطة 1%
      After struggling with the code for almost 8 hours I give you a fully parametric, asymmetric complex roof (primitive):
      http://design.medeek.com/resources/trussplugin/images/truss_su542_800.jpg
      View model here:
      3D Warehouse
      (3dwarehouse.sketchup.com)
      I will now need to spend a day or two just trying to break it and I also need to enable the gable end option.
      All of the menus and tools are working correctly now and seem to be quite robust. I will spend the next couple of days finishing up the roof primitive geometry (and testing). After that I would like to enable sheathing and cladding along with the roof labels and then I will probably release an update so everyone can test it out further and help me unearth any bugs I may have missed.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      1 رد آخر رد رد اقتبس 0
      • medeekM غير متصل
        medeek
        اخر تحرير بواسطة 1%
        If you take a look at these two roofs you will notice that in the second case the lower ridge has degenerated into the steeper roof plane:
        http://design.medeek.com/resources/trussplugin/images/truss_su544_800.jpg
        http://design.medeek.com/resources/trussplugin/images/truss_su543_800.jpg
        I didn't think it was possible but there are certain configurations where a standard straight skeleton will not generate the expected roof. This is a good example of that.
        The complex roof module will not be able to automatically handle these types of situations.
        This is where the secondary roof module will need to come in.
        design.medeek.com
        • medeekM غير متصل
          medeek
          اخر تحرير بواسطة 1%
          Throwing all sorts of curve balls at this module to see if I can break it. Ultimately one can always break anything if you try hard enough, especially with something as complex as some of these roofs get.
          Overall I'm pretty happy with it, I've addressed the issue with inside corners and now all is working as expected. Here is a recent test example of a roof with planes and pitches all over the place:
          http://design.medeek.com/resources/trussplugin/images/truss_su545_800.jpg
          View model here:
          3D Warehouse
          That being said there is always further testing that can be done. I'm sure there is some state I have not thought of that someone will get the plugin into that will break it.
          I think it is time to move on to the gable end option. Once I get that working I think the utility of this new module will start to become apparent.
          design.medeek.com
          • medeekM غير متصل
            medeek
            اخر تحرير بواسطة 1%
            I haven't quite started into the framing geometry just yet but I'm already one step ahead thinking about how certain junctions are going to need to be framed up.
            Two hip rafters meeting at a ridge is pretty standard and I think I have that one handled however the junction where a valley rafter meets a flying hip and ridge is a little more uncertain. Any information on how some of these framing junctions should be made would be very helpful.
            design.medeek.com
            • medeekM غير متصل
              medeek
              اخر تحرير بواسطة 1%
              Gable End option (within the edit roof panel menu) is now providing stable results:
              http://design.medeek.com/resources/trussplugin/images/truss_su546_800.jpg
              View model here:
              3D Warehouse
              The roof primitive module for asymmetric complex roofs with gable and hip ends is now complete. Granted there is still room for additional options like dutch gable and half hips but I will leave those for another day.
              I will now turn my attention to sheathing and cladding as well as the roof plane labels (name and sqft).
              One thing I forgot to add into the overall roof parameters/options is anything for battens and cross battens. I can add it in if I receive some positive feedback on that feature, otherwise I will move on and start into the sheathing module first thing tomorrow.
              design.medeek.com
              • medeekM غير متصل
                medeek
                اخر تحرير بواسطة 1%
                Version 2.5.1 - 10.02.2019
                • Enabled the "Edit Roof Plane" tool, allowing for customized roof planes within complex roof assemblies.
                • Added the gable end option for complex roofs within the "Edit Roof Panel" tool/menu.
                design.medeek.com
                • medeekM غير متصل
                  medeek
                  اخر تحرير بواسطة 1%
                  Version 2.5.1b - 10.03.2019
                  • Added logic so that customized roof planes can co-exist with the "Move Roof Edge" and "Edit Roof Outline" tools of the complex roof module.
                  Previously, moving roof edges would potentially shift the customized roof planes if certain roof edges were removed or consolidated. I think we have now achieved a fully parametric status with the various tools all working together.
                  design.medeek.com
                  • medeekM غير متصل
                    medeek
                    اخر تحرير بواسطة 1%
                    After giving it some further consideration I’ve decided to enable dutch gable and half hip options for custom roof planes rather than leave it for later. If I include these options now it will force me to keep my other more specific algorithms general enough to handle all cases. The geometry calcs required to generate the roof primitive for these two other configurations is really not that difficult and actually provides a rather intriguing challenge.
                    design.medeek.com
                    • medeekM غير متصل
                      medeek
                      اخر تحرير بواسطة 1%
                      First look at half hip complex roofs:
                      http://design.medeek.com/resources/trussplugin/images/truss_su548_800.jpg
                      (textures added to roof primitive for effect)
                      Notice the additional "setback" parameter in the menu. Also a half hip roof plane has both hip and gable parameters with the non-applicable parameters grayed out, as shown.
                      Similar to a gable end, the half hip can only be applied to certain roof planes, the plugin automatically restricts this placement.
                      The overhang of the half hip is governed by the gable overhang parameter, hence the overhang under the hip options is grayed out.
                      Now, on to the dutch gable...
                      design.medeek.com
                      • medeekM غير متصل
                        medeek
                        اخر تحرير بواسطة 1%
                        First look at dutch gable complex roofs:
                        http://design.medeek.com/resources/trussplugin/images/truss_su549_800.jpg
                        After I setup the system for the half hip this one fell out without too much trouble.
                        View model here:
                        3D Warehouse
                        Now it is time to move on to the sheathing and cladding, but first I need to add in some options for battens and cross battens.
                        design.medeek.com
                        • medeekM غير متصل
                          medeek
                          اخر تحرير بواسطة 1%
                          Version 2.5.2 - 10.04.2019
                          • Added the half hip option for complex roofs within the "Edit Roof Plane" tool/menu.
                          • Added the dutch gable option for complex roofs within the "Edit Roof Plane" tool/menu.
                          • The "Edit Roof Plane" tool has been made non-persistent to further improve stability.
                          (Click on image for animation)
                          design.medeek.com
                          • medeekM غير متصل
                            medeek
                            اخر تحرير بواسطة 1%
                            First look at roof sheathing:
                            http://design.medeek.com/resources/trussplugin/images/truss_su550_800.jpg
                            Roof cladding is a little more involved because of the cladding extension parameter.
                            design.medeek.com
                            • medeekM غير متصل
                              medeek
                              اخر تحرير بواسطة 1%
                              A few more kinks to work out in the sheathing module, but overall it is working better than expected and it wasn't nearly as hard to code as I initially thought it would be.
                              View model here:
                              3D Warehouse
                              Still a bit more work to do with sheathing when the dutch gable option is utilized. As you can tell from the model the sheathing is not tucking under the gable end overhang just yet. I will be addressing this tomorrow.
                              design.medeek.com
                              • medeekM غير متصل
                                medeek
                                اخر تحرير بواسطة 1%
                                The rebuild time on this model takes about 1.5 seconds. That is just with the roof primitive and sheathing.
                                http://design.medeek.com/resources/trussplugin/images/truss_su551_800.jpg
                                The question is what will the rebuild time be like for a model/roof this complex when all of the rafters and other accoutrements are included?
                                View model here:
                                3D Warehouse
                                design.medeek.com
                                • medeekM غير متصل
                                  medeek
                                  اخر تحرير بواسطة 1%
                                  Version 2.5.3 - 10.05.2019
                                  • Added sheathing for complex roofs.
                                  • Fixed the sheathing at the gable overhang for dutch gable complex roofs.
                                  http://design.medeek.com/resources/trussplugin/images/truss_su552_800.jpg
                                  As shown in the image the sheathing with a dutch gable roof tucks up under the overhanging gable end.
                                  View model here:
                                  3D Warehouse
                                  With this fix I think we are now 100% with the sheathing. I will begin the cladding next.
                                  design.medeek.com
                                  • medeekM غير متصل
                                    medeek
                                    اخر تحرير بواسطة 1%
                                    I've been thinking about connecting roofs together, for example a gable roof connecting to another building where the roof meets the wall. For this type of scenario it might be useful to have an option for a cutoff end (gable end with no overhang etc... I'm not sure exactly what to call this.
                                    P.S.
                                    It's funny where my thoughts take me when I take a breather from the code, I guess even when I'm on break I'm still contemplating what needs to be done with these plugins. I just realized that I can enable one additional option in addition to all the other options (ie. gable, dutch gable, half hip). I will call this a "CONNECTION". Basically you will be able to connect one roof to another (secondary roof). However, rather than having a separate module for the secondary roof I just realized that with the connection option complex roofs can become secondary roofs, so an additional module is not necessary.
                                    I will need to give this considerably more thought but I think this direction I need to go. There will need to be some options for connection type (another roof, a wall or a roof and a wall). I will need to explore the possibilities, this is going to get interesting.
                                    design.medeek.com
                                    • medeekM غير متصل
                                      medeek
                                      اخر تحرير بواسطة 1%
                                      If things weren't complicated enough with complex roofs, they just got a lot more complicated.
                                      Rather than having two or three different types of connections I think it makes more sense to sub divide it into two additional options and then a connection is simply a connection. You end up with two additional options: TERMINAL and CONNECTION
                                      With terminal it is very similar to a gable end however the roof just ends, no overhangs, no outlookers etc... This would be used when framing the roof up to a wall that is parallel to the roof edge. Theoretically this same type of roof could be achieved with the CONNECTION option however it would remove the requirement for selecting a primary roof (or solid) to connect to, and just simply end the roof in a squared off fashion.
                                      The CONNECTION option is a bit more interesting. To get the results that we want we need to make this end treatment as general as possible. One could potentially connect to any group or component in the model or to another Medeek complex roof assembly. I will need a tool within a tool which allows the user to select the primary roof/object that they would like to connect to.
                                      1. If the selected group is a Medeek roof assembly then the primary roof will also store that it is being connected to by a secondary roof, and the secondary roof will list the instance name of the primary roof it is connecting to.
                                      2. If the selected group or component (must be a solid) is a non-Medeek roof assembly it will also store and list the instance name of the primary object that the roof is connecting to.
                                      Here are shown a couple of possible connection scenarios:
                                      http://design.medeek.com/resources/trussplugin/images/truss_su554_800.jpg
                                      Connecting to another complex roof at an oblique angle and below the fascia line.
                                      http://design.medeek.com/resources/trussplugin/images/truss_su553_800.jpg
                                      Connecting to a non-Medeek roof (solid group).
                                      To keep this option from completely spiraling out of control we must make the assumption that the only roof planes impacted by the connection will be the two adjacent and orthogonal roof planes that are either side of the connection roof edge (the connecting roof plane technically does not exist). I'm sure there will be users who try to subvert this requirement in certain design situations, so some logic to check this limitations may need to be implemented.
                                      design.medeek.com
                                      • medeekM غير متصل
                                        medeek
                                        اخر تحرير بواسطة 1%
                                        When you are connecting a roof into an arbitrary solid (ie. walls) you may end up with something like this:
                                        http://design.medeek.com/resources/trussplugin/images/truss_su555_800.jpg
                                        View model here:
                                        3D Warehouse
                                        You will notice I've modified the roof primitive to emphasize the gable overhang. The key takeaway is that a roof connection should be treated like a gable end condition but with a certain amount subtracted away. That way if you do have a situation like the one shown, you will get your rakeboard etc... The trick of course is too make sure the logic is smart enough to identify these potential configurations and then adjust for them.
                                        design.medeek.com
                                        • medeekM غير متصل
                                          medeek
                                          اخر تحرير بواسطة 1%
                                          http://design.medeek.com/resources/trussplugin/images/truss_su556_800.jpg
                                          I've exploded the model so you can get a better idea of all the elements in the assembly.
                                          Note, that the roof outline group will always be at the same Z height as your input points or (top of wall plate).
                                          Due to overhangs and your roof pitch the roof primitive may extend below the outline, hence the reason I hide the roof primitive layer when initiating the edge move tool or roof plane edit tool.
                                          For cladding I still need to do some work due to the roof extension parameter, this complicates the geometry slightly since the cladding is not based on the same face (edge points) as the sheathing is.
                                          design.medeek.com
                                          • medeekM غير متصل
                                            medeek
                                            اخر تحرير بواسطة 1%
                                            First look at cladding with the cladding extension active:
                                            http://design.medeek.com/resources/trussplugin/images/truss_su557_800.jpg
                                            As you can see asymmetric roofs tend to complicate things slightly but regardless the correct lateral extension is achieved (0.75"). I will need to go back into the other rafter roof modules and correct this feature, I don't think I have it quite right.
                                            Because of the possibility of fascia and the cladding extension parameter, the cladding becomes a bit more involved not only for hip roofs but also along the rake edges of dutch gables, gables and half hips. All of these roof end conditions have unique solutions when it comes to cladding, and unfortunately it requires a fair bit of logic and coding on my part to make it happen.
                                            The interesting thing about what I do is not so much about the programming, but more the manipulation of the data and the topological and geometric problems I am able to solve, with nothing more than a well written API, some ruby code, and at times some serious mental contortions. I have certainly become well acquainted with the Geom module in the SketchUp API.
                                            design.medeek.com
                                            • 61
                                            • 62
                                            • 63
                                            • 64
                                            • 65
                                            • 74
                                            • 75
                                            • 63 / 75
