Missing plugin toolbar icons
Good afternooon from Vienna,
today I realized that all the icons of two SU plugin toolbars( IFC Manager and SU Podium) are missing. Instead of the coloured pictures only grey arrays are displayed. The menus can be opened, but there must be any graphic problem. Could anyone please explain how to resolve that issue?
Many thanks and kind regards, Christoph -
Start by ensuring SketchUp is installed correctly. Close SketchUp, find the installer file you downloaded or get it from sketchup.com/download/all and right click on it. Choose Run as administrator from the context menu. Then select Repair. Also check with the manufacturer of your graphics card and install their latest drivers. After that do a cold reboot of your computer. After you restart your computer open SketchUp and install the current version of each of the extensions.
Thank you for your hints. I followed those suggestions, but the icons still are not displayed.
So I will play around with that issue. If I can find the daemon causing the problem,, I will post it here.
Regards Christoph -
In what folder Are these extensions installed? Did you install the extensions correctly? What is display scaling set to?
