    โ„น๏ธ Licensed Extensions | FredoBatch, ElevationProfile, FredoSketch, LayOps, MatSim and Pic2Shape will require license from Sept 1st More Info
    Alphabet to sketch(up)
    204 Posts 7 Posters 959 Views 7 Watching
    • ntxdaveN Offline
      ntxdave
      Glad my stupidity could help. ๐Ÿ˜‰ It will be interesting to see what your book is about.
      BTW, I am trying to learn Krita. It looks like a good piece of software and I have watched several videos. I am struggling a little with the brushes and the way layers work. It is a little hard to watch the videos and remember everything or to pause and flip between the videos and the application. Any recommendations?
      • majidM Offline
        majid
        I am pretty sure you are smart. It was my fault that made it complicated and as you mentioned the topic on the twilight forum suits better.
        Krita was a nightmare for me for the first two weeks. Then I slowly got familiar with it and rushes. The brush system is wonderful but I suggest not getting into it first. I started with very simple drills and tried to master the basics and tools. I use it as an image editor and also a digital painting tool. I have already shared what I have done using Krita.
        • ntxdaveN Offline
          ntxdave
          What tools do you use (mouse, Wacom tablet, or others)?
          Do you have any suggested courses/videos?
          I have some basic problems:
          • I am not a very good artist but I like to try
          • Sometimes (sometimes often) I cannot get any good ideas (probably related to the previous comment)
          • I would like to be able to combine things/thoughts like people like you and Pilou
          • Lastly, I sometimes do not have enough patience in the learning process (maybe it is an aging problem ๐Ÿ˜ฎ )
            Krita is a gaz engine! ๐Ÿ˜„
            i can't advice about 2D Drawing prog (i use only a 23 years prog (PhotoImpact 6) ๐Ÿ˜‰
            A miracle that it works always! โ˜€
            Very very sufficient for anything! It can even make website! ๐Ÿ˜‰
            All other 2D progs for the fun of research : Free Verve, Vervette online, Project Dogwaffle Particle (for its particles), Sketchbook for classic drawing, Sisley a Fotosketcher light for modify an image, ...
            3 Rabbit are free Wombo
            Abstract: Sysley of course all that is infinite! ๐Ÿ˜„
            • majidM Offline
              majid
              It seems that Pilou has a bunch of mazing offers...! Thanks for sharing.
              I am wondering what will happen in near future by implementing AI?
                Yep and they have just one year existing! ๐Ÿ˜ฎ
                The speedy progress is terrifying! ๐Ÿ˜ฎ
                  Ten years ago... ๐Ÿ˜‰
                  • ntxdaveN Offline
                    ntxdave
                    Majid, Pilou
                    I need some help. I am tyring to learn Krita but somehow I have really messed things up. When I try to draw an object, say a rectangle or elipse, when I click to end drawing the object, nothing is showing up. I have tried to change the color and no matter what I do, it does not show up. I cannot figure out what is messed up.
                    Also, what dockers to you have set up in the app? How do you set up the default options for using the application?
                      I relunch krita first time from 2015 ๐Ÿ˜„
                      I believe you must make first Menu File / new
                      Select a format and go! ๐Ÿ˜„
                        Open the Particle Dogwaffle 9 ๐Ÿ˜„
                        Always fun! ๐Ÿ˜„
                        • ntxdaveN Offline
                          ntxdave
                          I figured out my mistake and it was so elementary that I am beyond embarrassed to admit what it was. ๐Ÿ˜ฒ ๐Ÿ˜ณ
                            No problem i had this same problem during 3 seconds before to find the trick! ๐Ÿ˜‰
                            It's a sort of variation of the stolen letter by Edgar Poe! ๐Ÿ˜Ž
                            • ntxdaveN Offline
                              ntxdave
                              My comment was related to drawing in Krita โ—
                                Yes I understood that! ๐Ÿ˜‰
                                Else if by hasard you open the Particles 9 ๐Ÿ’š
                                https://s6.postimg.cc/t0pl4c5pt/pandora_box.jpg
                                https://s6.postimg.cc/qozypkhgx/partic02.jpg
                                https://s6.postimg.cc/5012lthup/partic01.jpg
                                  Else more than we can imagine in one life! ๐Ÿ˜‰ (just scroll)
                                  • majidM Offline
                                    majid
                                    Thanks, Pilou for the link, there are some amazing results. Although in some cases the relationship between the significant and signifier is so that discerning the "Alphabet" is hard.
                                    Also, I am doing the final touches on my book and hope to be able to share it.
                                    P.S. here is the link to some pages of the book. Sorry for the low quality:
                                    https://drive.google.com/file/d/1zb1Hdr4cUDl1TL4rfUgRb39tFIaE4dpi/view?usp=sharing
                                    • majidM Offline
                                      majid
                                      It would be much appreciated if, please give me some feedback on my book!
                                        Very cool beginning if you go up to "Z" ? ๐Ÿ˜Ž
                                        Original exercice with constraint! โ˜€
                                        • majidM Offline
                                          majid
                                          Thanks for your comments, Pilou!
                                          Shared pages are parts of the book. The book already covers A-Z and some extra tips. It is up to 180 pages...
                                          • ntxdaveN Offline
                                            ntxdave
                                            @majid said:
                                            โ€ฆsome extra tips...
                                            Just curious, what kind of tips? Could you share an example?
                                            • 11
                                            • 4 / 11
