    [Plugin] Component Comparison
    62 Posts 24 Posters 54.7k Views 24 Watching
      Hmm... Component Replacer?
        This is yet existing 😄
        Random Component Replacement by Sdmitch 😉
        (Random of a same element = Copy ! 💚
        • F
          faust07
          Could be Faces To Components by HDPV (S4U - Huynh Duong Phuong Vi)...
          • gudio83G
            gudio83
            is it compatible with Sketchup 2015 x64?
              Yes.
              Are you experiencing issues since you ask?
                AcesHigh
                Oh ThomThom, I wish you had more time to improve this plugin, the potential is so great.
                And I have a problem with it... hope you can help or tell me what's wrong.
                Your plugin DOES NOT WORK with Chris Fulmer's LOOSE TO GROUPS plugin.
                I tried it with several models and before writing this post, to be sure of what I was going to write, I created a 1x1x1 cube and multiplied it.
                Then I run Chris Fulmer's tool and it surely converted the cubes to objects. They are absolutely the same.
                Your plugin however doesn´t recognize them. 0 definitions replaced!
                Any idea what may be happening? Why does groups created by LOOSE TO GROUPS are not recognized by your plugin? There must be something "deep down" going on!
                  AcesHigh
                  well, now I do not know. I created several cube groups by myself (did not use Chris Fulmer's plugin).
                  And Component Comparison still did not work.
                  Exploded the cube groups and created the groups one by one (instead of multiplying a group). Still did not work.
                  WTF?
                  • brodieB
                    brodie
                    It's been awhile since I've used it but just found the same thing as Aces, that it's not working in 2015 with Loose2Groups for some reason. Bummer 😕
                    • V
                      vico44
                      Same for me, I got this in the Ruby Consol :
                      Error: #<NoMethodError: undefined method length' for nil:NilClass> /Users/vico/Library/Application Support/SketchUp 2016/SketchUp/Plugins/tt_cc.rb:182:in get_transformation_difference'
                      /Users/vico/Library/Application Support/SketchUp 2016/SketchUp/Plugins/tt_cc.rb:117:in block in replace' /Users/vico/Library/Application Support/SketchUp 2016/SketchUp/Plugins/tt_cc.rb:107:in each'
                      /Users/vico/Library/Application Support/SketchUp 2016/SketchUp/Plugins/tt_cc.rb:107:in replace' /Users/vico/Library/Application Support/SketchUp 2016/SketchUp/Plugins/tt_cc.rb:29:in block in module:TT_CompComp'
                      SketchUp:1:in `call'
                      But with a simple model it works...
                      don't find why...
                      • T
                        tomaszdrgas
                        @AcesHigh Does it work with groups.. I just installed it on 2023 but seems not to work.. I have other replace components plugin which works only with components.. not groups
                          rv1974
                          Search here groups to component ruby. And definitions from smustard
                          • 4 / 4
