    SketchyPhysics 3.7.4
    48 Posts 16 Posters 95.1k Views 16 Watching
    • F Offline
      faust07
      Regarding animation export: the image format selection and the export work very well - super! A small improvement would be desirable... Setting the start frame in "export animation" - "export settings" works neither as choice of the beginning point of exporting the recorded simulation nor as frame number in the filename. No matter what you type in, both start at zero.
      And to stop an export before end is nearly not possible...
        John Sarak
        About Sketchy Physics
        If anyone want to help.
        Since one week I'm trying to install the "SketchyPhysics" in my laptop with WIN 10 and. 64x
        But, I can not to.
        Any try is losed. I have try any method. In "Reference---> Extensions" I can see it but it doesn;t work. Its bar does not disapear.
        Can anyone help me to how to download with right way?
        • F Offline
          firedrake
          is there any way to use this with a 64 bit system, im using a mac and its only available in 64 bit
          • F Offline
            faust07
            SketchyPhysics works only on 32 bit systems. No way to port it.
            Please try MSPhysics by plugin author Anton S.
            Search for MSPhysics under Board index - Plugins.
              mr1Andersen
              Hello.
              In MSPhysics, you can stop motion and freeze the scene.
              After pressing the STOP button, the figures remain in their places and do not return to their original positions.
              This is very convenient if you want to find the position of the object after its movement.
              Does it make it possible to make such a "freeze" button in SketchyPhysics?
              The "freeze" button is a stop button2 (End simulation without re setting positions nor erasions emitted bodies).
              • F Offline
                faust07
                I'm not sure if anyone is developing SketchyPhysics any further. But if I remember correctly, you can achieve the same result by pausing the simulation and saving a copy of the model during the pause. The state of the model is then frozen in this copy.
                  mr1Andersen
                  Hello.
                  How to change settings for ( corkscrew joint ).
                  • sketchartist023S Offline
                    sketchartist023
                    QUESTION: How small can an object be before sketchyphysics no longer recognizes it as accurate or active, etc? I made a model and when I scale it down things do not move anymore. I even changed the densities etc but they need really high densities to, for example, drop. That makes everything very heavy.
                    So, it seems as if light object (say if I were to model a ping pong ball at 1/8th scale[example]), the physics are no longer accurate or at times even work.
                    Just need to know what those limits are so maybe I can model things larger, then scale them afterwards, knowing they will work still. Thank you very much! 😎
                    • luckyvacL Offline
                      luckyvac
                      HI Chris, I would like to know how to program the AND function in the representation of the automation as an attachment. This is a paper cutter which should only cut a sheet if the operator's two hands are busy pressing the two buttons <<a>> AND <<b>> at the same time.
                      With :
                      • Servo29773 to raise or lower the operator's right hand.
                      • Piston 19574 to press one or two buttons depending on the position of the operator's right arm.
                      Thank you very much . Good year !
                      Jean-Luc
                      massicot mov.skp
                      • H Offline
                        hclmed
                        Is SketchyPhysics available for Sketchup 2022?
                        • 3 / 3
