    SketchyPhysics 3.7.4
    48 Posts 16 Posters 97.2k Views 16 Watching
    • F
      faust07
      Another presumptuous question ... Is it feasible to expand "Animation Export" in "Sketchy Replay" with an input function, so that freely selected image formats can be exported, not just the current viewport size? - Such as it now is possible in MS-Physics. 👍
      • P
        PituPhysics
        Hello Faust. I could not solve, I asked Anton...
          jumpjack
          @anton_s said:
          SketchyPhysics is a real-time physics simulation plugin for SketchUp created by Chris Phillips.
          See extended versions maintained by PituPhysics: http://sketchucation.com/forums/viewtopic.php?f=61%26amp;t=62453
          SP 3.5, the unofficial release, comes with many bug fixes
          SketchyPhysics 3.7.1
          SketchyPhysics 3.7.1 Release date: December 23, 2015. Copyright © 2009-2016, Chris Phillips
          It remains just for 32-bit SketchUp to use.
          I'm a bit confused...
          V.3.2 was the last one from Chris Phillips, now stopped?
          Than a new branch named "3.5.x" was started? By Anton_S ?
          Then a NEW branch named "3.7.x" was started? By PituPhysics? Or this is the continuation of 3.5?!?
          What does "It remains just for 32-bit SketchUp to use" mean? That a 64-bit version exists?
          3.5.x branch.
          3.7.x branch
          • P
            PituPhysics
            Faust07!
            Anton created a new 'sketchy_replay.rb' file. Now you can freely adjust the image size.
            I created a .exe integrator. It's work in SU14 or newer.
            Download from webpage or this link.
            jumpjack!
            The first time Anton further developed the original SP 3.2 from Chris Phillips.(3.3.0 - 3.5.6)
            Then I further developed.(3.6.0 - 3.7.1) I no longer making several editions.
            64-bit SketchUp is not supported. Use the MSPhysics, it is much more advanced, although still under development. But it works flawlessly.
            • F
              faust07
              That's great! I will test it this evening. Thanks so much, Anton and Pitu!
                jumpjack
                @pituphysics said:
                jumpjack!
                Thanks, now it's clear.
                But then SP is no more being developed by anyone?
                Which one is the best to simulate mechanisms? SP or MS? For example, to build two gears which move together in sync. I find very uncomfortable SP in this (at least in old versions), when I had to set up by hand each single tooth!
                • P
                  PituPhysics
                  Gears each plugin to do it the same way. Select all the teeth, 'Shape' -> 'Convex Hull'
                  One of them with a motor to another in a hinge.
                  • F
                    faust07
                    Regarding animation export: the image format selection and the export work very well - super! A small improvement would be desirable... Setting the start frame in "export animation" - "export settings" works neither as choice of the beginning point of exporting the recorded simulation nor as frame number in the filename. No matter what you type in, both start at zero.
                    And to stop an export before end is nearly not possible...
                      John Sarak
                      About Sketchy Physics
                      If anyone want to help.
                      Since one week I'm trying to install the "SketchyPhysics" in my laptop with WIN 10 and. 64x
                      But, I can not to.
                      Any try is losed. I have try any method. In "Reference---> Extensions" I can see it but it doesn;t work. Its bar does not disapear.
                      Can anyone help me to how to download with right way?
                      • F
                        firedrake
                        is there any way to use this with a 64 bit system, im using a mac and its only available in 64 bit
                        • F
                          faust07
                          SketchyPhysics works only on 32 bit systems. No way to port it.
                          Please try MSPhysics by plugin author Anton S.
                          Search for MSPhysics under Board index - Plugins.
                            mr1Andersen
                            Hello.
                            In MSPhysics, you can stop motion and freeze the scene.
                            After pressing the STOP button, the figures remain in their places and do not return to their original positions.
                            This is very convenient if you want to find the position of the object after its movement.
                            Does it make it possible to make such a "freeze" button in SketchyPhysics?
                            The "freeze" button is a stop button2 (End simulation without re setting positions nor erasions emitted bodies).
                            • F
                              faust07
                              I'm not sure if anyone is developing SketchyPhysics any further. But if I remember correctly, you can achieve the same result by pausing the simulation and saving a copy of the model during the pause. The state of the model is then frozen in this copy.
                                mr1Andersen
                                Hello.
                                How to change settings for ( corkscrew joint ).
                                • sketchartist023S
                                  sketchartist023
                                  QUESTION: How small can an object be before sketchyphysics no longer recognizes it as accurate or active, etc? I made a model and when I scale it down things do not move anymore. I even changed the densities etc but they need really high densities to, for example, drop. That makes everything very heavy.
                                  So, it seems as if light object (say if I were to model a ping pong ball at 1/8th scale[example]), the physics are no longer accurate or at times even work.
                                  Just need to know what those limits are so maybe I can model things larger, then scale them afterwards, knowing they will work still. Thank you very much! 😎
                                  • luckyvacL
                                    luckyvac
                                    HI Chris, I would like to know how to program the AND function in the representation of the automation as an attachment. This is a paper cutter which should only cut a sheet if the operator's two hands are busy pressing the two buttons <<a>> AND <<b>> at the same time.
                                    With :
                                    • Servo29773 to raise or lower the operator's right hand.
                                    • Piston 19574 to press one or two buttons depending on the position of the operator's right arm.
                                    Thank you very much . Good year !
                                    Jean-Luc
                                    massicot mov.skp
                                    • H
                                      hclmed
                                      Is SketchyPhysics available for Sketchup 2022?
                                      • 3 / 3
