Catamaran
Thanks Dave R!
You're welcome Joe. I had to buy a new USB-C dock to connect to my older monitors, so you might consider that as well. USB-C in to dual Display Port out. Plus extra USB ports. Alogic is who makes mine. About $80 compared to other at $100+. I think they make the same for HDMI out as well.
Aft deck block out complete. Started on some detailing.
Reworked the aft deck canopy yet one more time. I did not like the outboard windshield pillar angles. Too bug-eyed.
Steady progress Good show
Thanks tuna!
Cleaning up and beginning detailing. Pipe Along Path for wheel. The rest is just shape and then Push/Pull. The canopy support beam was Follow Me tool using a path line made by Tools On Surface. It needs some clean up where it joins the hull.
Some close-ups.
Cleaning up and adding more details. Upper cabin windows were too high. Mast swivel completed. Radar bridge created. Other details re-proportioned.
Roughing in the forward areas. At this point, all the main structures are built.
You be launching her soon matey!
Bryan, what's that forward boom? Don't think I've ever seen one on any boat.
Lines off form checking.
Wow check out the architects website! Some beautiful designs!
Shuttleworth Design - Home
Shuttleworth Design is a multi-award winning design consultancy that has been working with an international client base at the forefront of yacht design, engineering and naval architecture for more than 35 years. Yacht Designs. Multihulls, Monohulls, Superyachts, Catamarans, Trimarans. Power, Sail. Racing, Cruising. Boat Plans. John Shuttleworth, Orion Shuttleworth,
(www.shuttleworthdesign.com)
Thanks Joe!
That's for a jib sail. Sometimes the jib sail is connected to the main mast and sometimes it's not. And sometimes it's connected to the mainsail boom and sometimes it's not. This design, from the plans, shows it connected to both. (I had to look this up)
yeah I think this is the same design as yours and it has that boom out front.
https://www.nauticexpo.com/prod/pedigree-cats/product-20671-478489.html -
Yep. Shuttleworth seems to be a name associated with very nice boats. I did not know this when I picked it. It just looked nice and the plans were available for free.
where do you get the plans? Got a link?
https://www.nauticexpo.com/prod/pedigree-cats/product-20671-478489.htmlThat's it exactly. The Aero.
Being my first boat, I'm taking some, uh, liberties with the design.
Google search, plans for Shuttleworth Aero.
What you see in my posts are all I could find. Each image had to be scaled when imported.
More detailing and proportion change of some objects. And example was the radar bridge was too tall.
Hull sections committed and exploded to join all pieces in order to create waterline paint stripe.
Fore-deck and helm details next and rigging for very last.
Things are really coming together Bryan. Excellent work
Thanks tuna!
Stern steps completed. Non-slip pads are the black rectangles.
Vector Push/Pull to move the stern bulkhead forward and then stairs made with triangles on center-line and the regular Push/Pull to extrude outward. Then some fiddling with the outboard edges to get them flush to inner hull. Then Bevel tool on the step edges. Not perfect geometry, but it will pass a close up.
Coming along nicely, she looks great.
