Surface Development
Hello All,
I am designing a multi-panel clad corten steel flat box type dormer. The manufacturer needs a flat development of each panel surface to be able to laser cut from a flat sheet. I have more than 100 panels to do, and I was wondering if there is a up-to-date plugin that would help out in the process.
I have tried Flattery, but I can not get it to work without Sketchup freezing, so I assume it has not been updated for the 2022 version. Are there any other similar plugins available?
Many thanks in advance.
