    Mouse Question
    9 Posts 3 Posters 8.9k Views 3 Watching
    • Joe WoodJ Offline
      Joe Wood
      Folks, I have this combo
      https://www.amazon.com/gp/product/B003VANO7C/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
      which only had one USB for both the keyboard and mouse. The mouse's scroll wheel doesn't work now so I can't orbit.
      can I use another mouse with its own USB or will that cause a conflict??
      Joe Wood
      woodsshop.com/
      • BoxB Offline
        You should have no issues adding another mouse. Unless the 'scroll wheel issue' isn't within the mouse itself. If the mouse is simply broken then you should be able to add another mouse and dongle and continue to use the keyboard.
        • Joe WoodJ Offline
          Joe Wood
          Very good. How do I check to see if it isn't within the mouse Box? It's only 5 months old.
          Joe Wood
          woodsshop.com/
          • Joe WoodJ Offline
            Joe Wood
            I found this, says it's working properly.
            Joe Wood
            woodsshop.com/
            • BoxB Offline
              Is it not working for anything?
              What sort of symptoms?
              Did it just stop working or was it faulty for a while?
              Have you unplugged it and tried again?
              Have you restarted your computer?
              Lots of guesses but nothing specific to go on.
              • Joe WoodJ Offline
                Joe Wood
                Yeah the scroll wheel just stopped working a few days ago. Actually the scroll wheel works for scrolling but not when I press it for orbiting. I'll try unplugging it!
                Joe Wood
                woodsshop.com/
                • BoxB Offline
                  The tiny micro switch that is the obit button can break, as can any of the individual sensors that are the workings of the mouse. If all the pluging and unplugging and restarting etc doesn't make it work, and if it really isn't working in other programs on your PC, for example scroll wheel click in a web browser should bring up a double arrow icon that lets you scroll without using the wheel, and if you have tried it on another PC and it isn't working, then it sounds like a hardware issue with the mouse itself. Not to mention the amount of junk in your PC fan, you could have a similar issue inside the mouse.
                  • Joe WoodJ Offline
                    Joe Wood
                    yeah OK I have another mouse I can use, thanks for the good advice!
                    Joe Wood
                    woodsshop.com/
                    • Bryan KB Offline
                      What Box said. ๐Ÿ‘
