    [Plugin] Parametric Modeling - v0.0.7 - 03 June 2021
    86 Posts 31 Posters 123.5k Views 31 Watching
      alotharian
      Hi Samuel,
      Excellent plugin. Having played with it a little (creating a dynamically resizable cabinet) I got some feature suggestions:
      1. Navigating in the Node Editor: Currently the Left Mouse button is used to move a node, or move the whole scene (when clicking outside of a node). In a busy screen it would be helpful to have a separate button for the scene moving, e.g. the Middle Mouse Button
      2. Variable names: In a complex editor screen with plenty of nodes and connecting lines it is difficult to find the source of a connected variable. So, when a variable got connected it would be excellent to see the name of the source beside Variable X (even if the long ones wrapped).
      3. Cancelling a node placement: Clicking on a node icon AFAIK, now we must place the node and then delete if it was accidental or wrong. It would be nice to have the cancelling feature by hitting the ESCape.
      Thanks for your awesome work.
      regards,
      Rian
      • samuel_tS Offline
        samuel_t
        Simon Joubert created a great schema that makes use of latest evolutions of "Move" node.
        https://i.ibb.co/cLND9Fn/Parametric-Modeling-Sketch-Up-Plugin-Tiling-Demo.gif
        You can download it here. Right-click. Save link as...
          tavuro
          Excellent plugin. A suggestion, you need a list box to enter text and be able to select the options. Thanks
            patriarch
            Nice useful plugin. There are several questions. Is it possible to add components that exist in the model to an assembly? And is it possible to insert lines and planes, profiles? Can I create components instead of groups? And it would also be nice to have the function of renaming existing groups.
            • samuel_tS Offline
              samuel_t
              @patriarch said:
              Nice useful plugin.
              I'm glad to hear that πŸ˜„
              @patriarch said:
              Can I create components instead of groups? Is it possible to add components that exist in the model to an assembly?
              You can only do parametric operations on a parametric group but you can copy a regular component that exists in model and paste it as a parametric group. To do so: right click on a component in main SketchUp window and select "Parametric Modeling > Extract Shape From Group Or Component".
              You can also convert a parametric group to a regular group. To do so: right click in void inside Nodes Editor and select "Freeze parametric entities". Then, convert it to a regular component in main SketchUp window.
              Yes. Right click on lines in main SketchUp window and select "Parametric Modeling > Extract Shape From Curve Or Edges".
              You can rename parametric groups inside Nodes Editor. For regular groups, you can use "Outliner".
              • W Offline
                WhiteShadow
                Need help here, how to do it in SketchUp?
                Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users like electroscientistX.
                Imgur (imgur.com)
                I have to make those snake skin like things, any idea how to do it?
                  Mariotalluto
                  Absolutely amazing plugin ! Thanks for make it free
                  Looking for some example/tutorial cause i am completly lost. I want to create basic paramtric building (volume + balcony),but can't find the way to do it
                  Thanks !
                  • samuel_tS Offline
                    samuel_t
                    Imgur (imgur.com)
                    Sorry for the late reply. It's maybe possible to model this "Snake Skin". Here's an hypothetical plan:
                    1. Download Tiling.schema. Make sure downloaded file ends with ".schema", not ".txt".
                    2. Open Nodes Editor.
                    3. Right click in void to display context menu… Click on "Import schema from a file". Select "Tiling.schema".
                    4. Design elementary shape with SketchUp native tools or other plugins. Let's call this shape a "Tile".
                    5. Make a "Tile" component. Right click on this component in main SketchUp window. Select "Parametric Modeling > Extract Shape From Group Or Component". "Tile" appears as "Draw shape" in Nodes Editor.
                    6. Replace "Draw box" node with "Draw shape" node. Connect "Draw shape" with other nodes.
                    7. Use "Copy" node(s) with "X/Y/Z Position" formula(s) to spread "Tile/Draw shape" in 3D space.
                    • samuel_tS Offline
                      samuel_t
                      Thanks for your feedback!
                      There are videos available on YouTube but it's more a plugin overview... I recommend you to import examples: Open the Nodes Editor. Right click in void to display context menu… Click on "Import schema from a file". Select a ".schema" file. Study how nodes are filled and connected. There is also a Wiki.
                      • TraupmannT Offline
                        Traupmann
                        Some of the supplied schemas require particular models for them to be expanded correctly. Can you please provide those models?
                        I have been using Parametric Modeling for a while. I find it very useful in solving some problems. I hope you are continuing the effort.
                        • samuel_tS Offline
                          samuel_t
                          When you export a parametric schema, everything visible in the Nodes Editor is stored in the .schema file, even custom shapes (extracted from SketchUp viewport).
                          A parametric schema can be exported from a model then imported in another model, without geometry loss. The only things not embedded in .schema files are materials textures.
                            Traupmann
                            Perhaps I am doing something wrong. I started with a blank (new) Sketchup model, then use Parametric Modeling to Import a Schema. I get the Schema, but not any structures of any sort in the model space.
                            Here are screenshots of the Decking On Pedestals.schema.
                            • samuel_tS Offline
                              samuel_t
                              I don't see your screenshots. Did you forget to attach them?
                              • samuel_tS Offline
                                samuel_t
                                Maybe an error is occurring in background. Can you try to:
                                1. Open the Nodes Editor.
                                2. Open the SketchUp console.
                                3. Import a .schema file in the Nodes Editor.
                                4. Execute this code in the SketchUp console:
                                ParametricModeling;;ParametricEntities.redraw
                                1. Report the error here?
                                  Traupmann
                                  1. Execute this code in the SketchUp console:
                                    CODE: SELECT ALL
                                    ParametricModeling::ParametricEntities.redraw
                                  Excuse my ignorance, but by Sketchup Console do you mean Ruby Console?
                                  if so, an error report is in the text file below.
                                  I have included the SketchUp file as I attempted to execute it.
                                  Ruby Console Error Message.txt
                                  SketchUp File.skp
                                  • samuel_tS Offline
                                    samuel_t
                                    Yes, I meant the Ruby Console πŸ˜‰ Thanks for the error log. I suspect a conflict between Layers Organizer and Parametric Modeling plugins. Can you try to:
                                    1. Disable temporarily Layers Organizer plugin.
                                    2. Restart SketchUp.
                                    3. Import again a schema in the Nodes Editor?
                                      Traupmann
                                      The disabling of the Layer Organizer worked for all of the provided schemas but two. The files are below.
                                      Decking on Pedastals Results.skp
                                      Curved Shelf Result.skp
                                      Here is a schema I developed
                                      Arch.skp
                                      Can you advise how to pass schema files?
                                        manyakteam
                                        Hello. This is an amazing tool for me. It has immense potential. I am a lecturer and I teach this plugin to my students, especially. Know it is currently under development, so I think you will consider my suggestions.
                                        All my problems are with nodes πŸ˜„ First, it would be great if they could be locked, grouped, and ungrouped with a right-click option.
                                        The undo and redo shortcuts do not work as I expected. For example, when I accidentally add a box to a crowded node screen, the "ctrl+c" combination does something else instead of removing it.
                                        Especially in complex jobs, nodes get mixed up. To prevent this situation, you can add icons that can be personalized (such as color, geometric shape) on the upper right corners of the nodes.
                                        Finally, if windows run in tabs, you will have done an excellent job of efficiency. My English isn't very good, but I wanted to congratulate you and give you an idea of what I think can be improved. Wish I knew a little bit of coding and could help you. Respects πŸ˜„
                                        • samuel_tS Offline
                                          samuel_t
                                          Hello. This is an amazing tool for me. I am a lecturer and I teach this plugin to my students, especially.
                                          Hello. This kind of feedback makes me very happy! πŸ˜„ It's one of the reasons I code and share plugins.
                                          A lot of things are not documented. Parametric Modeling plugin Wiki really deserves some love 😳
                                          To be honest, the developement of this plugin is in stand-by. I'm busy by other projects. That's said, suggestions are always welcome πŸ˜‰
                                          This sounds not "easy", but a must-have option! I agree.
                                          About organization, one can add "Post-it" nodes. Right-click in void then choose "Add a comment node".
                                          Try to press "Escape" to cancel... If it's too late: right-click on the node then choose "Remove this node".
                                          Yes, I could add more visual landmarks. I note your idea.
                                          SketchUp HTML Dialog API (used by this plugin) don't support tabs, but I could add tabs inside the plugin's window...
                                          Thanks. Where do you come from? I'm curious πŸ˜›
                                          Parametric Modeling plugin code source is online.
                                          Respects πŸ˜„
                                          Best regards πŸ˜„
                                            manyakteam
                                            Hello again.
                                            I am from Turkey and I teach in the field of woodworking industry. I use many different plugins, but "Parametric Modeling" is very convenient especially for cabinet type furniture after creating a library. So, I always tell my students about the power of open source and how they can contribute to it. πŸ‘Š
                                            As I mentioned in the previous comment, excellent results can be achieved if something is added to reduce the clutter in projects with many nodes. I hope you continue to improve. Thank you again for what you do.
                                            • 3 / 5
